Old 05-10-2018, 01:16 PM   #3291
M0nk3y
Originally Posted by smg1138 View Post
So, I tried installing my new brake Centric rotors last night and could't get the stock rotors off. After almost 80k miles I guess they've rusted on to the hub. Any advice on how to get them off?
If they’re OE rotors, you have holes which you can put a bolt through and slowly wrench.
The bolt pushes against the hub face and will force the rotor off.
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
smg1138 (05-10-2018)
Old 05-10-2018, 01:20 PM   #3292
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
hit it with your purse
The Following 4 Users Say Thank You to DocWalt For This Useful Post:
2superblus (05-16-2018), Icecreamtruk (05-10-2018), justinco (05-10-2018), justint5387 (05-11-2018)
Old 05-10-2018, 01:21 PM   #3293
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Ok thanks! Anybody know the bolt size and thread pitch I'll need to use?
smg1138 is offline   Reply With Quote
Old 05-10-2018, 01:22 PM   #3294
M0nk3y
M8 X 1.25 Bolt IIRC
Kyle H. - #89 STX
Old 05-10-2018, 02:08 PM   #3295
tony_r
tony_r's Avatar
Drives: '15 STX
You can use the spare tire holding bolt on the rotors, it's the same size and pitch IIRC.
tony_r is offline   Reply With Quote
Old 05-10-2018, 05:20 PM   #3296
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
all you need is a BFH
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
The Following User Says Thank You to Simmons For This Useful Post:
DocWalt (05-11-2018)
Old 05-10-2018, 05:48 PM   #3297
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
For future reference when working on cars that don't have the hole in the hub face of the rotor, you can always put a big bolt through one of the holes for the caliper bracket, and thread it through a couple big washers and a nut in between the bracket and rotor. Bolt will push on the rotor when you thread it all the way in you can wrench it against the rotor. Tighten it up, loosen and rotate the rotor, tighten again. It'll pop.
trippinbillies40 is offline   Reply With Quote
The Following 3 Users Say Thank You to trippinbillies40 For This Useful Post:
cjd (05-10-2018), DocWalt (05-11-2018), smg1138 (05-10-2018)
Old 05-10-2018, 10:52 PM   #3298
Nduby52
Drives: Toyota frs86
Random question. Anybody try 265/35 on 18s. Re71r’s or 18s illegal?
Nduby52 is offline   Reply With Quote
Old 05-11-2018, 07:55 AM   #3299
trippinbillies40
Drives: '22 WRB
They're not illegal. Just heavy.
Old 05-11-2018, 09:42 AM   #3300
smg1138
smg1138's Avatar
That's totally legal for STX, but it won't be as fast at 17's. I believe 265 is as wide as you can go for RWD cars in this class though.
Old 05-13-2018, 09:39 AM   #3301
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
Got no torque to tell them. lol
tigermack is offline   Reply With Quote
Old 05-15-2018, 08:00 AM   #3302
CoolHandMoss
Drives: 2013 FRS
I tried out my 350/275 spring setup this weekend. The co-driver took first in class out of 10. The car gripped great and handled nice and predictably. Easier to drive than on 400/400 for sure in most features. I still haven't quite figured out how to drive it yet so I can't say it's great all around yet. But I like it. It definitely handles bumps better. I will say it does roll significantly more even with a Perrin front bar set on stiff, so transitions require a little more anticipation. Another benefit of the softer springs is that the low speed damper adjustments make huge differences. A total of 3 clicks of change (2 rebound and one compression) on the front took the car from balanced to extremely loose. Settings still are not perfect but it's nice to have that level of control. Just thought I'd post some feed back on my softer spring experiment. So far I like it.
CoolHandMoss is offline   Reply With Quote
The Following 2 Users Say Thank You to CoolHandMoss For This Useful Post:
JohnJuan (05-15-2018), tigermack (05-15-2018)
Old 05-23-2018, 02:08 PM   #3303
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Are 17x9 a must or can you get away with 17x8.5 and still be competitive?
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 05-23-2018, 02:09 PM   #3304
M0nk3y
All you’re sacrificing is contact patch. Sure you’d can get away with 8.5” but it’s in your favor to upgrade
Kyle H. - #89 STX
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
