Old 04-17-2018, 09:53 AM   #603
D_Thissen
D_Thissen's Avatar
Originally Posted by Totalrecall View Post
Is this normal, My Base timing idle in gear above speed threshold only goes to 1800, VS pic above. And all my edits are grey.... Is it safe to continue?
V4.01 tune with definition from @elBarto
Yep that's normal, you just have to rescale that table.
Old 04-18-2018, 09:12 AM   #604
jerryzilla
jerryzilla's Avatar
Drives: 2016 Subaru BRZ Series.Hyperblue
Originally Posted by MrStickers View Post
Got a video?
jerryzilla is offline   Reply With Quote
Old 04-19-2018, 04:39 AM   #605
MrStickers
Drives: 2013 Subaru BRZ Premium
Originally Posted by jerryzilla View Post
Sounds great! Didn’t change initial enrichment?
2000 BMW 323i
MrStickers is offline   Reply With Quote
Old 04-19-2018, 07:22 PM   #606
jerryzilla
jerryzilla's Avatar
i think i changed it to 1.8
Old 04-20-2018, 08:43 AM   #607
hestekinj
Drives: 2014 BRZ - WRB
Burble videos
Thought I would post a couple quick videos I took last night. Shot with a gopro, running an external mic mounted to the rear license plate. I'm currently running the 'overrun' method using the values that Vin posted a while back
+10 @ 2500
+5 @ 3500
+2.5 @ 4500
0 @ 5500
https://drive.google.com/drive/folde...LQ?usp=sharing
Pretty happy with the results, although I might try something like 5 or 6 @ 2500, to get a little more burble in lower RPM. With my exhaust setup, you have to rev it out quite a bit to get the good burbles. I'm running a Tomei UEL, stock over/front/mid, and a Topspeed pro1 axle back.
It's worth noting that for most of these I was also feathering the throttle as it seemed to produce more burbles.
hestekinj is offline   Reply With Quote
Old 04-23-2018, 11:09 PM   #608
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
Anyone know why only this table would be screwed up?
All my files look like this with the v2 and v4 roms and open flash definitions.
Just this one table that I've noticed it on.
murdoc is offline   Reply With Quote
Old 04-23-2018, 11:22 PM   #609
steve99
Drives: FT86
The definition file is incorrect, do not edit that table that shows that corruption. else you may need a new ecu :-).
use the defs here.
http://www.ft86club.com/forums/showthread.php?t=126180
you will need to mod the def id strings to suit your V4 tune calid
DO NOT use the V4 defs on V2 tunes in USA
Old 04-24-2018, 09:44 AM   #610
D_Thissen
D_Thissen's Avatar
Originally Posted by D_Thissen View Post
I'm running this setup right now: +10 @ 2500, +5 @ 3500, +2.5 @ 4500, 0 @ 5500.
Some quick dashcam footage.
[ame="https://www.youtube.com/watch?v=aHKfhTpvFVI"]FRS Exhaust - YouTube[/ame]
Old 05-06-2018, 03:33 AM   #611
Hella Basa
Hella Basa's Avatar
Drives: 2014 Subaru Brz Limited
Originally Posted by elBarto View Post
I think those are still the old def's of the v1.x tunes. Since then alot of tables have been discovered.
This is a B01C:
B01C V4 def
But it's probably the same as bababooey's upload.
Same principle, only for V4 tune and remove any other B01C def.
Do I need to use that specific B01C def? because the one that comes in with the original v4 have the overun fueling labeled as ALPHA
EDIT: I read through the thread and found my answer. I didn't like the throttle version because it was too jerky
So far I have copied everything. I will try tomorrow! Thanks!
Hella Basa is offline   Reply With Quote
Old 05-06-2018, 08:03 AM   #612
redhalo
Drives: MY20 Hakone Toyota 86
use the defs here.
I have the same table as above, but my understanding is that I cannot use those defs as I have a 2017 (K00D). Are the included defs for K00D incomplete?
redhalo is offline   Reply With Quote
Old 05-09-2018, 08:19 AM   #613
steve99
Drives: FT86
Download latest tune pack from oft it may fix def problem
Old 05-10-2018, 03:07 AM   #614
redhalo
Is there one more recent than 4.03, that's what I have.
Old 05-10-2018, 06:08 AM   #615
steve99
Drives: FT86
I dont think so the def must be wrong so dont change those tables
Ill have a look when im back from china in a few days
Old 05-10-2018, 07:56 AM   #616
tomm.brz
Drives: brz 2017 hksv2
shiv's v4 defs have some broken tabs and are incompleyr!!
use the defs steve provided to us, they are perfect
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 04:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 05:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 07:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-17-2014 11:07 PM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 02:12 PM
