Old 05-08-2018, 04:48 PM   #1
ckilburn_
Drives: 17 BRZ Limited
Question Warranty Voids
Will an axel back exhaust void my warranty? I've heard Subaru is pretty picky but the parts guy I've talked to hasn't even heard of the term 'axel back' so I assume he's an idiot. any help will be appreciated!
Also***
If any other mods I can do without voiding the warranty, pls lemme know!
ckilburn_ is offline   Reply With Quote
Old 05-08-2018, 04:52 PM   #2
Nothing "voids" a warranty. They can refuse service if the mod could be proved to directly or indirectly have caused the issue but that is about it. An axle back would be hard to prove that it caused any issue.
humfrz (05-08-2018)
Old 05-08-2018, 04:57 PM   #3
ckilburn_
alright, thank you!
Old 05-08-2018, 04:57 PM   #4
ckilburn_
anything else pls post
Old 05-08-2018, 05:05 PM   #5
Nobody can give you a list of what will and will not be accepted. Much of it depends on the dealer and what they will tolerate. Technically speaking if you change ANY part of the car and they can in any way associate it with what failed they can deny warranty.
Transmission went and you have a weighted shift knob. No warranty (maybe).
Door falls off and you have a weighted shift knob. Covered.
bababooey (05-08-2018)
Old 05-08-2018, 07:43 PM   #6
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
I put an axle-back on my car 2 days after I bought it, and took it to a Subaru dealer during the duration of my warranty, and never had an issue. In fact it was never even brought up.
That being said, some dealers are more "sticky" than others on stuff like this, so it could totally depend on how lenient your local dealer is too, and as Mr. Coat up there said, they would only refuse warranty service if the modification was deemed to be a direct cause of the issue that is needing warranty coverage.
Hope this helps.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 05-08-2018, 10:51 PM   #7
Also***
Welcome to the forum, ckilburn......
Your second question is almost impossible to generalize an answer for.
It would depend upon what was modified and what failed on the car.
Using @Tcoat 's guidance and applying common sense, will get you in the ball park ....... however, the dealer/manufacturer has the final say so.
Old 05-08-2018, 11:29 PM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Absolutely nothing went wrong with my car during warranty, so it was a moot point. Well built i would say.
What voids he warranty? denverizzles Issues | Warranty | Recalls / TSB 73 12-18-2017 09:14 PM
Winjet Fog light install voids warranty or causes ECU problems? MuseChaser Cosmetic Modification (Interior/Exterior/Lighting) 6 11-02-2015 09:44 AM
Drilling out voids on wheels thatfilipinoguy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 02-03-2015 05:48 AM
Changing the oil yourself voids warranty? Dexposure Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 03-02-2014 05:40 PM
Painting Calipers voids warranty? jaime3 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 05-08-2013 08:43 AM
