Old 07-03-2012, 07:46 AM   #1
denverizzles
What voids he warranty?
So obviously i'm sure most of us on this forum is going to mod this bad boy, but what mods specifically are going to void the warranty? I don't really plan on doing anything internal or FI for a couple years to let the market mature a bit, but would lets say, intake, header, exhaust void the warranty?
denverizzles is offline   Reply With Quote
Old 07-03-2012, 07:49 AM   #2
os86
Drives: 2jz
dont hack that ecu . I mean dont flash it
os86 is offline   Reply With Quote
Old 07-03-2012, 07:50 AM   #3
denverizzles
Lets say I do flash the ECU, many companies offer a "back to stock" flash now. Is that detectable?
Old 07-03-2012, 07:53 AM   #4
os86
Drives: 2jz
I am pretty sure all ECU's will have a log in it to determine that.
Old 07-03-2012, 08:00 AM   #5
atledreier
Drives: GT86 DGM
Most modern ECUs have a 'flash counter' that counts the number of reflashes they have gotten. Now, the trick is to reset this counter, which the software might or might not do. I have the choice on my Golf TDi package to reset the counter or not. It becomes tricky when Subaru issue a patch for some issue and that ECU is flashed during a service, making the flash counter default to more than '1'....
atledreier is offline   Reply With Quote
Old 07-03-2012, 08:12 AM   #6
denverizzles
so far it seems as if the ECU flash is what voids the warranty. So if I "assume" correctly, bolt-on will typically not void the warranty?
Old 07-03-2012, 08:14 AM   #7
os86
Drives: 2jz
Stuff like exhaust, intake etc etc. will not void warranty.
Old 07-03-2012, 08:25 AM   #8
HunterGreene
Hail Magnet
HunterGreene's Avatar
Its not so much what voids the warranty, but if mods you have done can be determined to have caused the problem that you are trying to make the warranty claim about. It is very rare that you will do something to void the warranty outright, but with each mod you do, it is harder and harder to make a warranty claim if something goes wrong. Basically, you have to be able to prove that the mods didn't cause the problem.
Now, an ECU reflash/reprogram, if it could be proven, could make it very difficult to make a claim. Another example is the "Launch Control" fiasco (aka, the "Void Warranty" button) that hit the GT-Rs after their premier.
Old 07-03-2012, 08:52 AM   #9
beirouty
Drives: 2008 audi Q7, 2000 Lexus RX300
i think it depends on the country ?
in dubai, i have read the warranty agreement toyota offers with their cars, ANY modification to the car or engine voids warranty. thats what it says on their website too.
i guess that excludes changing the tires/rims, battery and painting the car.
beirouty is offline   Reply With Quote
Old 07-03-2012, 08:58 AM   #10
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
Drives: 1982 XX KE70
Anything that makes the car more fun usually voids warranty........
BOSOZOKU STYLE BITCH........
FT-86GOD is offline   Reply With Quote
Old 07-03-2012, 09:54 AM   #11
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Before i got my car i was talking to the head manager and he said, exhaust, intake, suspension, and splitting wires for power (I have blue lights on my car) will not void my warranty. This was in the U.S. and not sure if this will carry on to anyone.
WolfsFang is offline   Reply With Quote
Old 07-03-2012, 10:11 AM   #12
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
My biggest concern is ECU. I want to do I/H/E w/ a lightweight crank pulley and that's about it for engine mods but I want to have it tuned afterward to maximize what I'm getting out of these.
I like the idea of flashing back to stock for a dealership visit and then flashing back to the prior program but if there is a counter to tell how many times the ECU has been flashed I need to know that I'll be able to read it after a trip to the dealer and reset it to the same point for the next trip.
I'm not sure if this is even doable. I've never had a new vehicle tuned before. My Evo was used when I got it and it was never an issue.
Chewie4299 is offline   Reply With Quote
Old 07-03-2012, 10:24 AM   #13
Fenrir
Drives: Mazdaspeed 3
Correct, in the USA there is a law that a dealership or shop that is refusing warranty work (under standard warranty coverage) must prove that the aftermarket modification is what caused the failure, just as HunterGreene said. I have a fully-bolted and tuned MS3 that's had tons of warranty work done on it (for little things like TSBs and such), and my dealer never gave me any trouble.
Best advice would be to ask your dealer (or wherever you're taking the car for service) if they are mod friendly. I've seen dealers who will take cars that have built motors and run warranty repairs, and I've seen dealers who won't even touch a car if it has something simple like an intake on it. Even with the new(ish) law, some dealerships will fight you the whole way, and it's not worth the trouble unless you really have nowhere else to go.
Fenrir is offline   Reply With Quote
Old 07-03-2012, 10:26 AM   #14
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
NOTHING voids the whole warranty in the US.
The only thing that I could see that would do it would be having the car declared "totaled".
Otherwise, the Magnuson-Moss Warranty Act prevents a dealership from voiding your warranty due to a modification. The dealership has to show that the modification is the cause of the issue in order to deny a warranty claim. So they can't say no to fixing taillight condensation because you got aftermarket wheels. But they can deny your claim on a blown motor if you've had your ECU tuned.
So consider what you want to do with the car and what parts of the car are effected by your mods.
Extended Warranty? huangddg84 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 33 11-03-2014 01:50 PM
Warranty and Self-Maintainance? Heero CANADA 2 06-30-2012 09:21 AM
Extended Warranty kevinnivek8877 BRZ First-Gen (2012+) — General Topics 30 06-14-2012 05:00 PM
Warranty? Ad8707 CANADA 4 06-10-2012 08:11 PM
Extended Warranty? FoxtrotRomeo-Sierra Scion FR-S / Toyota 86 GT86 General Forum 4 05-31-2012 01:02 PM
