Old 05-01-2017, 01:19 AM   #715
Sgt.Gator
Drives: 2005 STI Race Car- 08 Spec B DD
Congrats on keeping it in one piece for 1.5 years without a dry sump. Impressive!
Sgt.Gator is offline   Reply With Quote
Old 05-01-2017, 06:36 PM   #716
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Thanks! Our motor build gets the oil pressure up but I'm sure the Accumulator kit has helped with cornering Gs as we've seen over 2G with our Time Attack FRS. It's cheap insurance for sure!!!
Element Tuning is offline   Reply With Quote
The Following User Says Thank You to Element Tuning For This Useful Post:
RavioliG (09-01-2017)
Old 05-04-2017, 08:25 AM   #717
Bfranklyn86
Drives: GT86 Harrop S/C
Originally Posted by Element Tuning View Post
You have to split the cases so as long as a full build which is about 27 hours.
Firstly, that's an awesome build, great to see people keeping the FA20 rather than jumping ship, and sorry to hear it finally let go.
I was just wondering about the rods you used. I was aiming to keep the stock pistons as a way of saving money if I decide to build my engine, but was told I'd struggle to get aftermarket rods that would fit.
Did you have to machine the rods to get them to fit the pistons?
Sorry if the answer to this is somewhere in the last 50 pages!
Bfranklyn86 is offline   Reply With Quote
Old 05-07-2017, 02:49 PM   #718
Element Tuning
Yes you have to clearance the rods to run those pistons but also the tops need to be machined some and the DI pocket isn't correct for the FA20 direct injection.
While I made it work, it was mostly for us to test the DIT parts without buying a WRX. I also have infinite control over the DI with the Hydra EMS and I'm not sure you could get optimal results from the OEM ecu in that regard.
Forged rods and pistons (for boosted applications) are the only way to go if you have opened up the motor. Don't get me wrong those pistons are strong and honestly would have never failed had I not run that motor super lean.
TachyonBomb (06-05-2017)
Old 09-01-2017, 09:25 PM   #719
RavioliG
Poor Adult Male
RavioliG's Avatar
Drives: 2013 Subaru BRZ
Ok Element you win take my money
RavioliG is offline   Reply With Quote
The Following User Says Thank You to RavioliG For This Useful Post:
sato (09-02-2017)
Old 09-05-2017, 04:18 PM   #720
Element Tuning
Happy to help you to the next level
Old 02-07-2018, 12:31 AM   #721
FunnyGopher
Drives: 2015 BRZ Limited
What a good thread this is. So much information, thank you so much!
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
Old 02-28-2018, 10:23 PM   #722
Williampreza
Williampreza's Avatar
Drives: 2017 Ice Silver BRZ Limited
Has anyone seen the most recent Engine Masters episode regarding oiling (How Oil Kills Power)? Apparently they resolved high rpm oil pressure loss (and corresponding power loss) by simply reducing the overall volume of oil in the system. Of course it's more complicated than that, but I thought I'd throw this in to get this discussion going again.
I realize that most of us have chalked up high rpm oil pressure loss to cavitation on the part of the oil pump. Just want to confirm that turbulence due to excess windage at high rpm has been ruled out. Pls no flames. Honest question. Thx!
Here's a link to the video. It's a pay site so it may do you no good until they post the vid on YouTube.
https://www.motortrendondemand.com/d...r-/0_iqs4grke/
Williampreza is offline   Reply With Quote
The Following 2 Users Say Thank You to Williampreza For This Useful Post:
sato (05-11-2018), Ultramaroon (03-01-2018)
Old 03-01-2018, 03:55 AM   #723
FunnyGopher
T-minus 1 month until I can watch this video...
Old 03-22-2018, 10:19 PM   #724
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
Thanks for making this thread.
Surok is offline   Reply With Quote
Old 05-08-2018, 12:00 PM   #725
ermax
ermax's Avatar
Originally Posted by Nigelr32 View Post
No way. I have no idea when the change was made, I just noticed the difference on a rebuild of my 2012 engine. I believe there were issues with the cam timing? This may be something to do with it??
I have a 2012 and a 2014, this is how I found the difference. The earlier engines have a different part no for left and right rocker posts, later they're the same.
Heres a pic of the left and right next to each other..
Are you sure this changed on the 2014? I ask because I am doing a rebuild right now on my early MY2013 and noticed bank1 has the small holes under the rockers and bank2 has the big holes. Did they go to small holes on both banks on the 2014?
Old 05-08-2018, 12:26 PM   #726
Ongky
Ongky's Avatar
Drives: 2013
I am rebuild MY 2013 and when i bought from Subaru... The size is different
Sent from my ONEPLUS A5010 using Tapatalk
Ongky is offline   Reply With Quote
The Following User Says Thank You to Ongky For This Useful Post:
ermax (05-14-2018)
Old 05-13-2018, 11:20 PM   #727
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Anyone know if it's ok to use the newer smaller hole rocker posts on the older 2012~13 heads?
JimmyMac is offline   Reply With Quote
Old 05-14-2018, 01:50 AM   #728
steve99
Drives: FT86
Their is whole set of updated parts, valves rocker etc you must use all new parts as slightly different sizes do not mix and match old and upgrade parts
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 02:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 05:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 12:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-17-2013 11:24 PM
