#43 |
#44 |
Drives: Brz
#45 |
Infinity Q50
You're welcome.
#46 |
| The Following User Says Thank You to humfrz For This Useful Post: | Tokay444 (05-08-2018) |
#47 |
#48 |
Thanks
I didn't read the whole thread but I am pretty used to the electric power steering. I found it has good feed back especially compared to other cars out there. As I understand there is a physical connection to the rack and pinion and it is just an electric motor providing the assist as compared to a hydraulic system.
On the street it is totally fine. The "issue" I have with it is on track days. I guess it gets hot/overheats. In situations where you need to counter steer there seems to be a dead spot. Not sure how to describe it but it feels different and then you feel the "resistance" again. Sorry for bad explanation but I am accustomed to it now but the feeling is still always weird.
#49 |
Only happy when it rains.
Drives: series.blue
speaking of my Yaris, I can't believe I actually broke the cruise control stalk the other day. I'm going to have to see if CTScott still has some. I'm also crazy enough to wish I could put my wheels from the Yaris on to my BRZ, 6.5 lbs per wheel sounds so much better than 16 or more....
| The Following User Says Thank You to why? For This Useful Post: | Kaotic Lazagna (05-08-2018) |
#50 | |
The PS is a feedback loop so when you turn the wheel the computer senses this and gives assist in the direction you are turning. Under high loads where the motor is near max output and you rapidly change directions, I would the motor would still be going the other direction for a split second before reversing. Simracing wheels do this really bad. It’s referred two as backlash so they added a second motor and the two motors are always loaded in opposite directions to avoid the slight lag. Higher sampling rates could also combat this. This is all speculation of course. |
#52 |
Steering hasn't changed. In fact they are now using the exact same parts in the new gen Impreza.
| The Following User Says Thank You to Tcoat For This Useful Post: | Riftur (05-09-2018) |
#53 | |
Drives: GR Corolla
I'm sure Scott can make some more. 6.5 lb. Wheels on the twins would really free up some of that crank up. Haha |
#55 |
| The Following User Says Thank You to Tokay444 For This Useful Post: | humfrz (05-08-2018) |
#56 |
Those 17 steering wheels are brutally slippery when new. Was one of the things that jumped out at me when I test drove one. It is just a poor choice for materials and I am not surprised to hear they don't get better.
| The Following User Says Thank You to Tcoat For This Useful Post: | bkharmony (05-08-2018) |
| handbrake wire and reverse wire location Australia gt86 | rsingh | Electronics | Audio | NAV | Infotainment | 0 | 01-16-2017 09:12 PM |
| Help me identify this wire! Extra wire around battery after clutch job | YouShallKnow | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 12-09-2014 02:04 PM |
| Swapping steering wheels with a new tC steering wheel. | jonathan9573 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 12-20-2013 11:45 PM |
| Steering Feel Question Concerning Tic Solid Steering Bushings | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 10-31-2013 04:52 PM |
| Reverse Wire Tap wire Location? | Norkoastal | Electronics | Audio | NAV | Infotainment | 2 | 10-19-2012 10:22 AM |
