Old 05-07-2018, 10:58 PM   #15
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Originally Posted by Sel_brz17 View Post
MY Stft trim hovers arund -3%, which i think is fine.... myltft on the other hand hovers around -19% on idle and -15% while driving. I do believe its bc i got an injen intake on there. SHould i be worried? I really dont wanna take off injen intake but will do so if needed. What can happen if I continue to run my car at these readings? Thank you!
Are these logs or real time looking at it? There's a maf scaling thread on here so that's where to start. LTFT is stored in buckets and I think that thread explains it iirc.
If that's what the logged readings are actually averaging to, you should be fine to do nothing about it for normal driving, though your AFR in the upper rev range might be a bit off. Solution is to rescale the maf. The scale for that intake might be posted somewhere, or you can do it the long way. Or maybe the manufacturer has it available.
Old 05-07-2018, 11:02 PM   #16
Sel_brz17
Sel_brz17's Avatar
Drives: BRZ 2017
THANK you so much! Would i be fine running e85 on the current ltft as well?
Sel_brz17 is offline   Reply With Quote
Old 05-07-2018, 11:17 PM   #17
Spuds
The Dictater
Spuds's Avatar
Well if you do, your ltft will change quite a bit at the least. Other than that . If it were my car, I'd run a tune. There's a post on here where that was discussed by folks with much more experience than me. I'd suggest finding that.
The Following User Says Thank You to Spuds For This Useful Post:
Sel_brz17 (05-08-2018)
Where are LTFT data stored? RustySocket Software Tuning 17 03-21-2026 11:53 AM
Diagnosing high positive LTFT Tectoniic Software Tuning 22 05-03-2022 02:24 AM
strange LTFT bee_are_zee Software Tuning 11 05-17-2016 07:28 PM
LTFT reading oft mike7792 Software Tuning 1 02-01-2016 09:21 PM
high ltft at idle, my how to fix it(not fixed yet) trdric Software Tuning 16 06-18-2015 10:27 PM
