Old 12-08-2016, 03:16 PM   #1
dillanp86
dillanp86's Avatar
Drives: 2010 Acura TL
Normal LTFT??
My LTFT is constantly between -5 to -2. After the engine is warmed and I give it some WOT, it will flatline at 0.00 and MAYBE go up to 2.67ish. Just wondering if this is normal before going to OFT E85. Currently running stage one OFT. Car is bone stock besides OFT.
Thanks
dillanp86 is offline   Reply With Quote
Old 12-08-2016, 03:21 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Thanks
Normal
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-08-2016, 03:22 PM   #3
dillanp86
dillanp86's Avatar
Originally Posted by Kodename47 View Post
Normal
I love you thanks. E85 here I come
Old 12-08-2016, 03:23 PM   #4
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
Generally speaking, your car is fine. LTFTs between -5% and +5% indicate relatively balanced fuel trims all things considered. Since you are hovering around -5% at idle, your car is running slightly rich (pulling fuel, hence the -%). At WOT, all fuel trims (STFT and LTFT) peg at 0% as the car switches from closed loop to open loop, so your observation is exactly as expected.
To be 100% sure of everything, we would need to know your STFTs as well. If they are wildly off, it could indicate a problem depending on the direction. Also good to know if you have any mods that affect air or fuel flow/metering or exhaust gas travel paths.
theadmiral976 is offline   Reply With Quote
Old 12-08-2016, 03:25 PM   #5
dillanp86
dillanp86's Avatar
STFT levels are constant around -1 to +5. Nothing too crazy.
Old 12-08-2016, 03:25 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
Seeing as LTFT is set by the consistency of STFTs, I'm pretty sure we know what the STFTs are likely to be
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-08-2016, 03:26 PM   #7
theadmiral976
Ah, sorry, didn't see your mod list. OFT maps generally cause a slight rich condition as they want to be safe to mitigate differences in fuel quality. Assuming your STFTs are +/-5%, everything is perfectly fine.
Old 12-08-2016, 03:26 PM   #8
dillanp86
dillanp86's Avatar
Help needed! Check engine light after weird traction lights.
https://r.tapatalk.com/shareLink?url...1&share_type=t
Can u guys check that? I posted last night about the same issue but out the wrong title and go 1 reply.
Old 12-08-2016, 03:27 PM   #9
theadmiral976
Yes, I agree that this is true assuming the STFTs are fluctuating in a reproducible manner based on throttle input and load. However, my understanding is that if there is a variable issue causing the STFT values to swing, the LTFTs may not reflect STFTs accurately. Maybe I'm wrong...
Old 12-08-2016, 03:32 PM   #10
theadmiral976
Steve is very knowledgeable. I agree with his response: i.e. clear the codes and see if they return. If they do, your best bet is to go to the dealer (after flash back to stock). In terms of the OBDII connector, I don't remember off the top of my head, but I'm pretty sure that several pins are unused by OFT (hence they're missing in the OFT-side plug).
Old 12-08-2016, 03:34 PM   #11
theadmiral976
Awesome! Looks good to me.
Old 12-08-2016, 04:14 PM   #12
Tokay444
Generally speaking, anything below +/-8% is considered nothing to worry about.
Old 12-08-2016, 04:23 PM   #13
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Check your fuel trims at idle and 2500 RPM. You want them less than -/+10%. LTFT + STFT is your total fuel trim and that's what you want under 10.
guybo is offline   Reply With Quote
Old 05-07-2018, 09:55 PM   #14
Sel_brz17
Sel_brz17's Avatar
Drives: BRZ 2017
MY Stft trim hovers arund -3%, which i think is fine.... myltft on the other hand hovers around -19% on idle and -15% while driving. I do believe its bc i got an injen intake on there. SHould i be worried? I really dont wanna take off injen intake but will do so if needed. What can happen if I continue to run my car at these readings? Thank you!
Sel_brz17 is offline   Reply With Quote
Where are LTFT data stored? RustySocket Software Tuning 17 03-21-2026 11:53 AM
Diagnosing high positive LTFT Tectoniic Software Tuning 22 05-03-2022 02:24 AM
strange LTFT bee_are_zee Software Tuning 11 05-17-2016 07:28 PM
LTFT reading oft mike7792 Software Tuning 1 02-01-2016 09:21 PM
high ltft at idle, my how to fix it(not fixed yet) trdric Software Tuning 16 06-18-2015 10:27 PM
