Old 05-06-2018, 02:12 PM   #15
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Love mine, and various mods... Just about 60,000km on my 2013 model.
Full exhaust, Sprintex supercharger, brake upgrades and flex fuel kit. The rest costly cosmetic stuff.
Hasn’t missed a beat, no issues at all.
The next question for me will probably be “modded SC 86 or new Supra” in 2019
Assuming the supra is any good of course.
I like driving!
86 South Africa is offline   Reply With Quote
Old 05-06-2018, 02:24 PM   #16
Originally Posted by lionbacker54 View Post
not even crickets
Side (05-07-2018)
Old 05-06-2018, 03:01 PM   #17
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
2013 58,000 mi, suspension bits + cat-back exhaust:
Failed TOB
Failed cam tower / timing chain cover seals
Water in tail lights
Everything fixed under warranty. That's it! Not too bad!
90% highway driving (MYYYYY boring, 80mi/day commute), 10% flogging it on mountain roads, no competitive events.
Ganthrithor is offline   Reply With Quote
Old 05-06-2018, 03:11 PM   #18
cjd
cjd's Avatar
Drives: 2017 BRZ
Ummm. I'm not sure how many miles. I'm going to guess between 1300 and 1400.
Only issues I have so far are expensive parts from reputable companies not actually fitting properly. That's just one part really, and I'll be fixing it along the way.
Oh, and the stock parts I pulled off - people want me to give them away. Mostly the tails, OE Brembo setup, and OE shocks. (yes, I got the BRZ PP and then removed the PP. That sounds bad... hah.)
Old 05-07-2018, 12:35 PM   #19
arkanist
Drives: 2016 BRZ Limited, Stock
31k Miles
Gruppe-s UEL + Supertek high flow air filter + Ecutek tune
No issues I didn't directly cause (suspension issues from hitting a big rock in the middle of the road and taillights cracked after closing the trunk but I had been lightly rear ended months prior so I blame that.)
75/25 highway / city
arkanist is offline   Reply With Quote
Old 05-07-2018, 01:22 PM   #20
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
13' Manual
63K Miles
Header, FP/OP, stock catback, CAI, Crank pulley, oil cooler, modded OFT stg 2(v2) tune.
BBK, Tein Flex Z(Lowered about 1.75inches), RacerX LCA and toe arms, Perrin swaybars and endlinks.
Stock tires with 225 ECS, 17X9 57DR with 245 RS3's(currently) for play.
Issues: Right front hub bearing, condensation in the taillights(IDGF), bumper gap under headlights.
Since I bought the car 3 years ago it has gotten about 10 track days and a couple autocross events. It was a daily driver untill last winter. Now it is mostly a toy, fun nice day car. Hopefully I didn't jinx myself by buying a spare motor recently.
Old 05-07-2018, 01:25 PM   #21
Teseo
Drives: frs
- 120,000 miles
- 2014
- TRD dropping and exhaust. 1.5 inch drop on RSR Superdown springs
- Blew up TOB and destroyed clutch by being too foolish to change it when it started yelling at me. Not one single other issue.
- 98% highway 1% city 1% spirited.
Oh, it is an FRS but thought I would play anyway
You will let the second owner to change spark plugs?
Teseo is online now   Reply With Quote
The Following User Says Thank You to Teseo For This Useful Post:
Tcoat (05-07-2018)
Old 05-07-2018, 01:31 PM   #22
If they seem to need it by then.
Old 05-07-2018, 02:19 PM   #23
Teseo
Drives: frs
13' Manual
63K Miles
Nop, you are staying on safe side in case shit happens. Prepare for worst expect the best
Old 05-07-2018, 02:23 PM   #24
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The real reason I bought it was it was a 33k mile motor for 400 bucks delivered to my house. The guy I bought it from works at a local Toyota dealer that bought it, pulled the heads and oil pan. Plastigauged all the rod bearings and checked it out. Reassembled and tried to sell it for a lot more. No takers so I got it for what he had in it.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Tcoat (05-07-2018), Teseo (05-07-2018)
Old 05-07-2018, 02:48 PM   #25
Teseo
Drives: frs
I will try the same thing as you of finding other engine
Old 05-07-2018, 02:55 PM   #26
aimforapex
aimforapex's Avatar
Drives: car
my old FRS
2013
100,000 KM
daily driven, track 6 times a year, autocross 5-7 times a year.
No issue, not even TOB.
aimforapex is offline   Reply With Quote
Old 05-07-2018, 04:19 PM   #27
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
only issues I have had was because of crappy mods that should not have been. I only have 19k miles on it though. Well the biggest problem is I am somehow turning into a wheel whore because I can't afford the ridiculously expensive wheels I want. So I bought cheapie lighter wheels and then a pothole that I didn't even see bent the crap out of one of the wheels. I am annoyed because I have beaten the ever living crap out of the Volks on my Yaris for over a decade and they are still perfect.
why? is offline   Reply With Quote
Old 05-07-2018, 04:51 PM   #28
mazeroni
Drives: 2013 Scion FR-S Series 10
- 58,xxx miles
- 2013
- Bought in 2015 @ 26,xxx
- SpeedFactory V1 Catback
- 50% highway 50% city
- 2~4 time daily I do 3rd gear pulls to red line during highways merges
- Frequent 2 to 1 shifts then run it back out through the top of 2nd for luls
- No track or AutoX
- Burns almost no oil and the oil is always clear even after 5,000 miles (my oil change interval)
- Normal noises that are worsening over time (not concerned)
- Silver Ignition paint is holding up well, doesn't show swirl marks, but could use a $$$ detail job.
- Eurostyle headlights have shitty seals and aren't looking too good.
- Condensation in taillights but they aren't fogging or yellowing.
- +1 for fabric seats that still look the tops
mazeroni is offline   Reply With Quote
Update on Auto Boosted Miles and Issues jeschris45 Engine, Exhaust, Transmission 4 02-04-2018 01:00 AM
41K+ Miles No issues SeanRTR Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 36 08-21-2017 09:10 PM
2013 - MT - 18k miles - Issues. tbrocato Issues | Warranty | Recalls / TSB 13 10-11-2014 10:49 AM
BC BR coilovers for sale. 3k miles on them with no issues at all! Just changing it up NickFRS Brakes, Suspension, Chassis 11 03-14-2013 02:44 PM
