Old 05-04-2018, 02:00 AM   #1
Andyxin
Drives: 2017 BRZ WR blue PP
swaybar angle with endlinks
Hey! Just bought a set of adjustable endlinks for my brz and I have watched some videos on how to install and adjust them on our twins. Most of them mention how to get rid of preload but none of them talks about which angle should the endlinks make with the sway bar. Since my car is lowered, the angle of endlinks and sway bar is not same as stock anymore and from my understanding the angle is important for sway bar working properly. How did you adjust your endlinks? Thank you for any input.
Andyxin is offline   Reply With Quote
Old 05-04-2018, 01:29 PM   #2
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
This is a great question and I'm looking forward to the responses. My car is lowered and has adjustable anti-roll bar endlinks on both ends, but my setup was done by a local race shop and I'd like to understand the mechanical considerations for setting things up properly.
RJasonKlein is offline   Reply With Quote
The Following User Says Thank You to RJasonKlein For This Useful Post:
Andyxin (05-05-2018)
Old 05-04-2018, 02:32 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I would imagine you would just want the links to be 90 to the roll bar at ride height. That way at full twist you don't get bind.
Old 05-04-2018, 04:57 PM   #4
norcalpb
norcalpb's Avatar
What kind of suspension do you have?
The Following User Says Thank You to norcalpb For This Useful Post:
Yoshoobaroo (05-05-2018)
Old 05-05-2018, 02:30 PM   #5
Andyxin
I’m using AST 5100
Old 05-05-2018, 03:27 PM   #6
norcalpb
norcalpb's Avatar
It won’t matter how much you’re lowered, but it’ll matter how much shorter the shock body is than OEM. But keep in mind the strut is at an angle, so depending on how much camber you have you’ll want to calculate how much shorter than the endlinks need to be. If the shock body is 1” shorter, you’ll wanna shorten .8” or something because the shock is the hypotonous in the hypothetical 90 degree triangle if that makes sense.
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
Andyxin (05-05-2018), RJasonKlein (05-05-2018)
Old 05-06-2018, 05:16 AM   #7
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I will disagree. I am suggesting you want the links to be just over 90 degrees so that during travel they pass through 90 degrees. The only end links I found that fitted this criteria, after using 1 or 2 different links, was to go with these:
Yes, they look cheap and nasty but they were able to cut to the length I wanted.
https://www.whiteline.com.au/product..._number=W23180
FS: OEM Front Swaybar Assembly with Endlinks MicheleAbbate Brakes, Suspension, Chassis 13 05-18-2022 06:59 PM
DIY - Rear Swaybar and Endlinks - Perrin F1point4 DIY (Do-It-Yourself) Guides 11 07-26-2018 03:27 PM
FS: Whiteline Front Swaybar Endlinks bombardius Brakes, Suspension, Chassis 2 04-16-2016 10:50 AM
FS: [NSW] Password JDM Rear Swaybar Endlinks eckoflyte Australia Classifieds 1 10-25-2014 06:53 AM
Ground Control Swaybar Endlinks GC_Adam Brakes, Suspension, Chassis 6 01-02-2013 01:08 PM
