| DIY (Do-It-Yourself) Guides For all DIYs. |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
DIY - Rear Swaybar and Endlinks - Perrin
Houston86.com back with another DIY guide. Today we are covering the install of @PERRIN's 16mm Rear Swaybar and Endlink. Although it is Perrin centric, this applies to most vendor's products.
For comprehensive pictures of the items, theory, review, etc check out this thread http://www.ft86club.com/forums/showthread.php?t=22020 This install was pretty easy. You don't need expensive niche items. Just basic hand tools, jack stands, and a floor jack. Definitely feel more confident that the car will be able to handle more power when those options come out. Please use this guide in addition to the service manual and the vendor's official instructions. As always I am not responsible for damage done to yourself or your vehicle. Always remember to be safe. ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-01 by VictorN07, on Flickr ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-02 by VictorN07, on Flickr ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-03 by VictorN07, on Flickr ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-04 by VictorN07, on Flickr ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-05 by VictorN07, on Flickr Backside of the Rear Stabilizer Bracket ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-06 by VictorN07, on Flickr ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-07 by VictorN07, on Flickr ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-08 by VictorN07, on Flickr You could raise your car on a lift. Kept it simple going with Jack stands; they give plenty of height to get in there. ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-09 by VictorN07, on Flickr ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-10 by VictorN07, on Flickr ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-11 by VictorN07, on Flickr Forgot to add the text to repeat on the other side ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-12 by VictorN07, on Flickr ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-13 by VictorN07, on Flickr ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-14 by VictorN07, on Flickr ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-15 by VictorN07, on Flickr ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-16 by VictorN07, on Flickr ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-17 by VictorN07, on Flickr ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-18 by VictorN07, on Flickr Perrin does not say to grease the faces of the spacers. I chose to do this because I think metal on metal contact will create noise. Like any urethane bushing, you will have to periodically check and regrease ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-19 by VictorN07, on Flickr ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-20 by VictorN07, on Flickr ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-21 by VictorN07, on Flickr ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-22 by VictorN07, on Flickr Perrin does not say to grease the outside of the swaybar bushing. I chose to do this because the OEM bushing was greased that way. Like any urethane bushing, you will have to periodically check and regrease ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-23 by VictorN07, on Flickr ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-24 by VictorN07, on Flickr I should add the hardware is supplied with the kit. As for torquing the bolts, I started with the Rear Swaybar, then the control arm, last the endlink/swaybar connection ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-25 by VictorN07, on Flickr ![]() 20121111-Perrin_RearSwaybar_Endlink_DIY-26 by VictorN07, on Flickr
Drives: FR-S, Exige S, Miata
Great write up as usual. Will you be supercharging this car? Looking forward to that write up if so.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield '95 Miata (Montego Blue) |
Photo Specialist
If we do, we will cover it!
Engineer
Drives: WRB 2022 Subaru Brz
Do your really need new end links when just replacing the sway bars. My car is not lowered, and none of its suspension components are changed. Wouldn't the stock end links be fine?
Photo Specialist
I think for normal driving it should be fine. If you drive it hard (say auto-crossing or road racing) then you run the risk of the stock endlinks bending under the increased stiffness of the swaybar.
Drives: SWP BRZ
great DIY. don't you need to only rase vehicle on rear side for this DIY? just wondering
Props to a VERY thorough/detailed write up!
Mountain Runner
Drives: 2013 Subaru BRZ Limited 6MT
I know it's been like 2 years and change,but here goes nothing. If i only get the rear Perrin 16mm sway bar and only use the softest setting (only 130% the stiffness of the original sway bar) would i be fine using stock endlinks? I feel like the OEM end links wouldn't really have a huge problem with ony 30% more stiffness... I'm only interested in changing the rear sway bar right now, and I only want a tiny bit more stiffness in the rear to dial out some of the understeer that the car exhibits during short and tight autocrosses. Am I on the right track? (no pun intended) @F1point4
I'd say using the stock endlinks will be OK to use with our 16mm bar. It'd still work better with upgraded endlinks though. If you're looking to pick up one of those bars, send me a PM, thanks!
#10 |
Drives: 2013 White-Out FRS
Sorry to revive an old thread, but will this install affect my camber? No need for alignment again after right?
I live my life one quarter-pounder at a time.
#11 |
The bar is for less body roll, it won't affect camber. Shouldn't affect alignment either.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#12 |
Necroing a useful thread. Has anyone use the Perrin endlink on the stock sway bar? If so, how did you setup the spacers in the rear LCA?
| Tags |
| diy, endlinks, perrin, polyurethane, rear swaybar |
| Perrin Rear Shifter Bushing Install | F1point4 | DIY (Do-It-Yourself) Guides | 55 | 10-21-2021 02:39 PM |
| Perrin 16mm Rear Swaybar and Polyurethane Endlinks Review | F1point4 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 07-26-2018 06:15 PM |
| FS: Perrin Rear Shifter Bushing | green_comet | Australia Classifieds | 2 | 11-07-2012 02:04 AM |
| Perrin Rear Sway Bars at Redline360 | Redline360 | Brakes, Suspension, Chassis | 0 | 06-28-2012 10:38 PM |
