Old 04-08-2018, 11:39 AM   #659
febrz
Drives: silver brz 2013 lmtd
Originally Posted by guybo View Post
I thought it was just my car? I know I have a shitty gasket between the mid-pipe and axleback, I figured it just got worse over time..... maybe I didn't have to order new gaskets after all and it's jut the tune?
Ah well, the axleback gasket and the donut gasket are getting changed out anyway!
The timing change at about 4k-5k makes it SOOOO fkin raspy, it's almost ridiculous. However, I noticed when I was stage 1, that after a 100 miles, it died down a bit, maybe I got used to it? Both my friends who are mechanics said my car was not leaking.
Now I added CATTED EL Headers, and it is still SOOOO fkin raspy, even more ridiculous. I'm pretty sure it's not a leak, I bought new gaskets, replace the old ones, although the new gaskets were all OEM. In addition, I don't hear any hissing or fluttering or ticking either. I thought that getting catted would make EL not as raspy, but this tune makes it very raspy. When I look at other people's set ups , theres are NOT raspy because they got an ECUtek tune.
febrz is offline   Reply With Quote
Old 05-03-2018, 01:22 PM   #660
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
I was just looking for the header on the OFT site today and it's gone. Google search show it, but it's a dead link
It was just there a few days ago... anyone know what's up?
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 05-03-2018, 02:42 PM   #661
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
They probably stopped selling it.
Old 05-03-2018, 03:11 PM   #662
Interesting. They don't show a header for any make on their site now. It isn't just the twins they aren't listing them for. Must be out of the header business.
Old 05-03-2018, 04:09 PM   #663
Teseo
Drives: frs
Maybe after new tune revision no need an a specific header like before (EL or UEL)
Old 05-03-2018, 04:14 PM   #664
Lantanafrs2
Drives: 2013 frs red
Could simply be a problem with their website too
Lantanafrs2 is online now   Reply With Quote
Old 05-03-2018, 06:48 PM   #665
2point0
2point0's Avatar
True. It's been wonky ever since it was revamped.
Old 05-03-2018, 07:29 PM   #666
They only list OFT for all makes. No headers even mentioned anyplace anymore. Don't think that is a site issue.
Old 05-05-2018, 05:06 AM   #667
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Shh! Tcoat would not like this. A generic tune for all aftermarket headers? He said so many times that such tunes give zero gains ...
Old 05-05-2018, 05:35 AM   #668
tomm.brz
Drives: brz 2017 hksv2
nikitopo, Tcoat isn t the only one saying that refining the cam timing for a "standard" header with normal/short tube lenght isnt giving much gains. And it s true, there s not much to gain, cam timings tune is more efficient with catless long tubes header
what you gain changing cam timinga with your stock header, it s just because stock cam timings are inefficent and more towards fuel economy/valve overlap/EGR
but you have a locked tune you can t try it by yourself
nikitopo (05-05-2018)
Old 05-05-2018, 12:55 PM   #669
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I think the EGR is also deleted in my tune:
http://www.ft86club.com/forums/showthread.php?t=103287
Maybe they didn't went too aggressive like Shiv, because they are a bigger company and wanted to avoid issues with cars not passing emission tests. Who knows ...
Old 05-05-2018, 01:03 PM   #670
Lantanafrs2
The cam timing is tweaked to work with the scavenging characteristics of the header be it long tube, short tube etc. There are obviously other considerations but cylinder filling and exhaust scavenging are biggies. I really like my ofh and oft. If I someday need more power, it'll probably be time for a different car.
Old 05-05-2018, 01:15 PM   #671
tomm.brz
yes no doubts your cosworth tune has "better" (performance oriented) cam timings than stock ones.. that is clear.
what i meant, is that if you could modify your tune you could try other cam settings and you could feel that actually if you make small adjustments, you won t really feel big differences of any at all
the reason your cam settings are probably not aggressive (like stage1 tune) is just because you have catted stock header, if you run stage2 or stage2+ you encounter more knock easily specially on high rpm
tuners dont give usually a f*ck about emissions
if you need to pass emissions easily you put a stock tune on or ask them or make yourself a stock tune with p0420 disabled if you have catless header
in italy you pasa emission test with catless header and stock front pipe, that s for sure cause all my friends passed that way
that s for pre my16 car, maybe euro6 emission check ia more difficult
Old 05-05-2018, 07:07 PM   #672
JIM THEO
Drives: BRZ 2018
Same in Greece Tomm...we pass emissions tests with just one cat and quite hot exhaust!
JIM THEO is offline   Reply With Quote
Open Flash Header - Sound and Performance Comparison nlowell Engine, Exhaust, Transmission 41 05-19-2014 06:29 PM
FS: Open Flash Header - SoCal Pickup nlowell Engine, Exhaust, Bolt-Ons 9 05-12-2014 06:29 PM
Open Flash Tablet Andrew025 Engine, Exhaust, Bolt-Ons 3 04-26-2014 05:03 PM
Open Flash Header Catless Clip Vmax911 Engine, Exhaust, Transmission 25 03-08-2014 06:51 AM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
