Drives: 2017_86 2016_frs 2007_335i
after changed the cat back , the air drag!!!!!
so here is my question
after i changed the cat back for mxp rs ti tip there is a huge empty space between axe and rear bumper i went for a track day the and the highest speed i got is around 145 km/h and follow the by a high speed corner speed around 110-95 km/h all that speed was on the stock toyota 86 stock tires exp the cat back! now i have already order the new brake pad and rotor new rpf1 rim and re71 tires but after that track day , my reverse light wires was lay on my exhaust luckily i found it out before the wires is burn so this lead me to consider the air drag at rear bumper i am going to buy a rear diffuses for help me cover it, but i think it will make the car under steering since there is more down force at back so at this point i need a front lip for sure...... it was just tooo much for fix that air drag any suggestion for create down force at front with out a big front lip? or how to fix that air drag at rear? here is the pics |
#2 |
Drives: Toyota 86 GTS
145kph isn't going to ruffle your hair let alone slow your slow car down further or upset the delicate aero balance of your road car. Leave it as it is and just drive it mate.
#3 |
Drives: 2014 GT86
IIRC from non-lip options hood vents should also reduce lift at front.
And yeah, there are several diffuser or cover options that may cover axleback exhaust to guide air around with less drag. With some exhausts some of them may need some cutting though for clearance. But imho you overblown rear exhaust/bumper parachuting/drag issue a bit and confuse with downforce a bit. Drag rather will slightly hurt your long term fuel economy & acceleration .. even if it's by some 1-2kmh, is it an issue to care for unless you drive competitively for results, not for fun? Ordered stickier tires very probably will allow higher cornering and exit speeds, allowing higher speeds at end of straights anyway (though not sure if RE71R is best choice for HPDE, imho it's easy to overheat it in longer sessions, and it may wear down fast). |
| The Following 2 Users Say Thank You to churchx For This Useful Post: | JazzleSAURUS (04-30-2018), Tcoat (04-30-2018) |
#4 |
Drives: Silver FR-S
How do hood vents reduce lift, and how do they compare vs hood scoops (aero and cooling-wise?)
Sent from my iDroid |
#5 |
Drives: 2014 GT86
Check velox hood vents thread. IIRC there was some data both on temps & lift reduction.
| The Following User Says Thank You to churchx For This Useful Post: | Jajanken86 (04-30-2018) |
#6 |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Jajanken86 (04-30-2018) |
#7 |
Drives: Legacy GT
A diffuser by itself, on a stock, non-flat bottomed car, is probably not going to generate a whole lot of downforce, but on the other hand it won't be nothing. What the diffuser is actually doing is expanding and slowing down the air that is coming under the car as it exits the back. This aids velocity in front of the diffuser, where the downforce is actually created (high velocity = low pressure, low velocity = high pressure). But if you have a lumpy floor and transmission tunnel and diff and subframe and suspension links all there, well, flow is not going to be as smooth or as fast as it could be. That velox part that extends forward is a good start but there's still a lot of lumpy things and open space there.
At the front end, air goes into the front grille, through the radiator, then what? The only place it can go is under the car and out the wheel wells, which creates lift and drag. Giving that air an exit on the top of the car, such as the fenders and hood, will generally reduce that front end lift. Similar thing apples to a scoop- you are pulling air in at the top and increasing the pressure in the engine bay. That means more air going out the bottom and sides and more restriction to flow through the radiator. |
| The Following User Says Thank You to jamal For This Useful Post: | Jajanken86 (04-30-2018) |
#8 |
Drives: 2014 GT86
Regarding aftermarket hoods with premade scoops/vents, worth checking where they are located (front/mid/or rear part of hood, closer to windows) and compare with CFD modelling Velox did for twins aero model. Depending on location there is different pressure above hood, which will help or not air evacuation from below hood. One can move separately bought vents and install in most optimal places. Not much options with aftermarket hoods with integrated vents, where only option is to buy different hood.
#9 | |
Drives: 2014 Scion FRS (Asphalt)
Honestly, I wouldn't worry too much about aero until everything else on your car is already sorted out.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
#10 |
A lot of replacement exhausts do indeed turn the rear bumper into a parachute.
- Andrew |
| The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post: |
#11 |
[ame]http://www.youtube.com/watch?v=quDLzxmJl5I[/ame]
here is the imfo i got !!!! very nice one i wont worry about that now [ame]http://www.youtube.com/watch?v=Fq8hkPobpes&t=744s[/ame] this one is talking about roof but give me alot info too |
| What's Changed? | brzzy | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 11-18-2019 12:27 PM |
| June 7th after Perrin meet drag racing at Portland Raceway or watch us drag! | stockysnail | Northwest | 15 | 06-08-2014 01:08 PM |
| We've Changed Our Name | Vicious LED | Announcements, Contests, Giveaways | 0 | 05-18-2013 02:44 PM |
| (Back up!) FS in FL: Drag DR-31 17x9" Square setup 5x100 (or 5x114.3) +38 | Kido1986 | Wheels and Tires | 5 | 01-10-2013 03:21 PM |
| What do you wish was changed about the brz/frs? | GirlyScions | BRZ First-Gen (2012+) — General Topics | 16 | 06-04-2012 03:26 AM |
