Old 12-16-2012, 10:15 PM   #1
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
(Back up!) FS in FL: Drag DR-31 17x9" Square setup 5x100 (or 5x114.3) +38
Same wheels sold here - http://www.ft86club.com/forums/showthread.php?t=22795
3 of them look brand new, one has very minor rash, you can barely see it when tires are mounted but I wanted to be completely open with these. The close of the wheel in the pictures is the tiny rash. Again, the other 3 are virtually perfect.
They are 17 x 9 with an offset of +38.
I am completely open to wheel trade with another set of 5x100 wheels.
I do not want OEM wheels from a BRZ/FR-S, TC, SRT-4, Corolla, but 5x100 STi wheels or select WRX wheels will be considered. 17s are preferred but 16s will be considered.
There are NO tires included, they are just as pictured. I don't need tires from you so you can have someone dismount yours before the trade.
I was planning to run STX in 2013 but money just isn't there for me to be anywhere near competitive so I am continuing to run RTR (Stock class), so I no long need these. I'm not one for running super fat tires on the street so I'd rather have some 7-8" wheels on the street so I can run 215-225s.
If purchased outright, $425.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline
Old 12-17-2012, 06:23 PM   #2
Kido1986
Dodging cones
Kido1986's Avatar
Bump!
Kido1986 is offline
Old 12-17-2012, 06:54 PM   #3
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Bummer, Henry--sorry they didn't work out for you...
Accurate description on these, guys.
TTT
GTB/ZR-1 is offline
Old 12-17-2012, 07:04 PM   #4
Kido1986
Dodging cones
Kido1986's Avatar
TTT
Thanks. I just can't afford to compete on the STX front and I really did enjoy running the car in RTR so I figured I'd continue running it. Doing to do another set of 215 RS3s, custom CBE, get a good filter, wait on Strano to finish the FSB, play with the alignment and once I have the $770 to spend, I'll go Koni. Hope to have everything except Konis on by Dixie. Maybe I'll get lucky and find the Koni money by then though.
Kido1986 is offline
Old 12-18-2012, 06:00 PM   #5
Kido1986
Dodging cones
Kido1986's Avatar
Bump!
Kido1986 is offline
Old 01-10-2013, 03:21 PM   #6
Kido1986
Dodging cones
Kido1986's Avatar
Sold!
Kido1986 is offline
Rays 57 Xtreme - 18x9.5 +40 - Square setup No Limit Motorsport Wheels and Tires 16 01-21-2013 02:59 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
FS in FL: Drag DR-31 17x9" Square setup 5x100 (or 5x114.3) +38 GTB/ZR-1 Wheels and Tires 1 12-06-2012 07:22 AM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
