Old 04-26-2018, 02:08 AM   #1
5150
5150's Avatar
Drives: 2017 86
Perrin 25mm rear swaybar overkill?
Right now I have fortune auto 500 coilovers and perrin 22m front sway bar and stock rear sway bar (16mm). My friend has a perrin 25mm rear swaybar and Im wondering if that will make my rear end too snappy for drifting.
5150 is offline   Reply With Quote
Old 04-26-2018, 08:59 AM   #2
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
are you having an issue with it rotating? most drifter guys i know of are trying to soften the rear as much as possible to gain more grip and yank the rear bar completely. 22mm is massive on this chassis, a stock wrx 16mm is a fairly substantial increase in rear bar and is super cheap. stock is 14mm btw
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 04-26-2018, 09:20 AM   #3
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
That is a huuuuge rear bar. I'd bump up to an 18 to better match your front 22. I run that combo and found it stayed pretty close to factory balance. This doesn't take into consideration what the Fortune coilovers have also done to your balance.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 04-26-2018, 09:22 AM   #4
wparsons
wparsons's Avatar
Diameter alone isn't all that matters... there was some hollow and solid bars available.
That said, Roadcone is right that most drifters want the rear as stable as possible.
flickr
Old 04-26-2018, 09:37 AM   #5
venturaII
venturaII's Avatar
I was wondering if that was the case myself, but a quick Google seemed to indicate that it's a solid bar. Even hollow, it'd be a poor match for the front, IMO...
The Following User Says Thank You to venturaII For This Useful Post:
wparsons (04-26-2018)
Old 04-26-2018, 04:30 PM   #6
norcalpb
norcalpb's Avatar
No 25mm solid is way too thick. If you want to try sliding the car via stiffer rear bar, try out the OEM 08-14 STi rear bar. This 18mm bar should be plenty to get the effect you are looking for, and if that isn’t enough I’d start looking at smaller front bars.
Massive sway bars on this Subaru chassis can make the car do some funny things.
Old 04-26-2018, 07:04 PM   #7
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I'm running Perrin adjustable bars, 19mm in front, 16mm in back. Front in the middle, rear on soft.
The car ends up perfectly neutral on my setup. I think the 16mm bar has significant oversteer to offer in the hard setting.
Old 04-27-2018, 12:03 AM   #8
5150
5150's Avatar
Drives: 2017 86
I see, I have the 2017 86 so the rear sway size is 16mm, should I put the stock front sway back in the front and get a 14mm sway for rear?
Old 04-27-2018, 12:12 AM   #9
norcalpb
norcalpb's Avatar
That would be the same balance, just more body roll.
Try stock front 18mm with an 18mm rear.
2017 stock is 18/16, did you find this wasn't enough for drifting?
Old 04-27-2018, 09:51 AM   #10
Yoshoobaroo
TRACKBREAD
I'd say your front bar is big, unless you have really stiff springs.
Side note: the Perrin 16mm can be significantly stiffer than the stock 2017 16mm, it's adjustable.
Old 04-27-2018, 11:17 AM   #11
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
2017 stock is 18/15
The Following User Says Thank You to nikitopo For This Useful Post:
Racecomp Engineering (04-27-2018)
Old 04-27-2018, 12:43 PM   #12
norcalpb
norcalpb's Avatar
Originally Posted by nikitopo View Post
2017 stock is 18/15
Are we sure about this? I thought I saw someone measure it with a caliper and it was 16mm.
Old 04-27-2018, 12:47 PM   #13
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
http://www.ft86club.com/forums/showp...1&postcount=41
norcalpb (04-27-2018)
Perrin 16mm Rear Swaybar and Polyurethane Endlinks Review F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 07-26-2018 06:15 PM
DIY - Rear Swaybar and Endlinks - Perrin F1point4 DIY (Do-It-Yourself) Guides 11 07-26-2018 03:27 PM
Stock Struts, arms sway bar. Perrin rear swaybar Ashikabi Brakes, Suspension, Chassis 13 01-22-2017 07:15 PM
