Old 04-25-2018, 03:19 PM   #15
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
Originally Posted by Timmy_Jones View Post
All things equal, a catted setup will be quieter than a catless. The Berk setup probably has a hi-flow cat, thinner material and may be a bit wider? So yes, it would absolutely be louder than stock.
I see. I mean, I'm ok with loud, just not eardrum-destroying rasp. So, basically I have 2 remaining pieces (fp/op) to add to my exhaust system to complete a 2.5" setup of all aftermarket parts.
I have CAI, a catless header, and a resonated CBE. I'm trying to see how much more dampening minimum I can get away with to avoid increasing rasp and drone, and without decreasing the volume I have. So basically:
1. decrease rasp if possible or keep it the same, but do not want increase
2. increase volume or keep it the same, but do not want decrease
3. keep minimum drone
I know changing the frontpipe from stock will only be an increase in x no matter what since stock was designed to be quiet, but I want to offset any increase in rasp/drone.
The JDL catted fp (without the resonator) with the op is what I had settled on. I'm not sure if its high-flow. But its in my cart right friggin' now and ready to lock & load!!
In my mind this works out to achieve all 3 things on my checklist. But I'm not 100% certain.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
Old 04-25-2018, 03:52 PM   #16
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Lakitu View Post
Wait.. Some months ago people here said catted is quieter than no cat, and in my mind that made sense since the sound has to travel through a material, and I based my entire setup and everything off of that. But it's incorrect?
The reason why Berk is louder than stock is not because of any material differences, it's because 1) the resonator is gone, and 2) the HFC is a smaller volume than the factory catalytic converter. The larger size factory catalytic converter functions as a resonator, most people overlook this when swapping out to aftermarket headers or front pipes when asking about sound.
Aftermarket HFC are smaller because 9 out of 10 makers of catalytic converters make it smaller for "more flow" and also because it's less material cost.
You can't hear it if you use a stock exhaust, but I measured 3.7db louder than stock Berk FP vs stock, everything else is stock.
[ame="https://www.youtube.com/watch?v=J2LGLH7K1Cs"]Berk HFC front pipe Scion FRS Subaru BRZ exhaust sound clip - YouTube[/ame]
Stock everything as tested on this day was 83.7db
The first one doesn't sound that bad to me. The 2nd has a split second of ear-piercing rasp. Do not want.
You can only hear it outside the car. Inside you can't hear it.
[ame="https://www.youtube.com/watch?v=jDf0bUg-bpQ"]Circuit of the Americas - 29 April 2016 3:00.78 in my Subaru BRZ - YouTube[/ame]
This is the only clip I have of the catless setup in the car, unfortunately there's too much wind noise due to the placement of the camera.
Originally Posted by Horrid_Funk View Post
I'm not following. A high flow cat is louder than a stock cat, sure. Are there uncatted front pipes that have a db increase of less than 4db? I don't think I've looked at the db increases for front pipes (if there even are many recorded), honestly curious.
The only video I did not record before was Fujitsubo front pipe w/ stock everything...the db meter read the same between stock and Fujitsubo FP though.
Here's video of a Blitz exhaust with stock front pipe vs Fujitsubo front pipe.
Fujitsubo front pipe 103.3db:
[ame="https://www.youtube.com/watch?v=a7BECUlOtxE"]Blitz Nur-Spec F-Ti + Fujitsubo front pipe Scion FRS Subaru BRZ exhaust sound clip - YouTube[/ame]
Stock front pipe 103.4db:
[ame="https://www.youtube.com/watch?v=n8ny7Y0R4J8"]Blitz Nur-Spec F-Ti Scion FRS Subaru BRZ exhaust sound clip - YouTube[/ame]
Old 04-25-2018, 04:23 PM   #17
Lakitu
Lakitu's Avatar
So what happens if you go from stock frontpipe to a non-high-flow resonated+catted frontpipe? Would you say its pointless since you're buying exactly the same part again? Or would there be any difference?
Old 04-25-2018, 04:39 PM   #18
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Not sure if that exists since almost all aftermarket catted front pipes are going to use high flow cats. JDL ultra quiet front pipe is should be the best for flow and quiet.
I have the HKS Dual resonated front-pipe which is great for sound and flow. However not having a cat is getting to me with the smell in the interior. It looks like I will be switching to the Invidia catted front pipe(60mm). I would go with JDL UQFP but 2.5" piping is too large for my setup to throw in the middle. I currently have Gruppe-S UEL and OP (60mm), HKS DRFP (60mm), HKP Legamax Premium CB (60mm).
If anyone knows of a FP that is 60mm, High flow cat and Resonated please let me know I have been searching everywhere??? Most likely will try Invidia Catted FP and see if its not too loud. Otherwise may be splicing the back of my HKS DRFP to the front of the Invidia.
SuperTom is offline   Reply With Quote
Old 04-25-2018, 06:16 PM   #19
Lakitu
Lakitu's Avatar
Thank you very much. Quick question though, you prefer resonated+catted over just catted? Is it to eliminate some rasp and drone?
Old 04-25-2018, 06:18 PM   #20
Lakitu
Lakitu's Avatar
How does the JDL ultra quiet (dual resonated+catted) compare to stock frontpipe? Same drone/rasp levels but lower volume?
Old 04-25-2018, 06:21 PM   #21
Lakitu
Lakitu's Avatar
So basically if I go for JDL frontpipe, I am going from:
1 cat, 2 resonators, 1 muffler
to
1 high-flow cat, 1 resonator, 1 muffler
So we would classify this as louder and more raspy than what I have now. If that's correct, then fml.
Old 04-25-2018, 06:25 PM   #22
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I don't have cats and the only time I notice the smell is if the wind is blowing it back into my windows, maybe you have an exhaust leak.
Trueweltall is offline   Reply With Quote
Old 04-25-2018, 07:36 PM   #23
SuperTom
SuperTom's Avatar
yes that is what I mean. I don't smell it in the winter but in the summer at a red light with the windows down its terrible. And chicks don't like it
Old 04-25-2018, 07:46 PM   #24
SuperTom
SuperTom's Avatar
I have Dual resonators on my front pipe.
I want 1 cat 1 resonator on my front pipe.
Like stock fp but a free flowing cat and 60mm piping all the way through.
JDL makes this but its 2.5" piping ~63mm. I'm looking for 60mm to keep velocity moving fast which is very important. Most people on the forums throw different sizes on their exhaust without doing research. 2.5" is a bit big on these cars without FI. 2.36" (60mm) is really the sweet spot for NA on this car
read this http://www.gomog.com/allmorgan/exhaustbackpressure.html
Old 04-26-2018, 08:35 AM   #25
Timmy_Jones
Spun
Drives: 23' Supra
Please stop spreading misinformation. Please do some research on why a stock car made more power with a 3" v 2.5" exhaust. Perrin, a reputable vendor did some great research here which was backed by dyno runs.
Please research before making assumptions and trying to inform other people with a poorly written and non-applicable article.
Now, if you want decent (not optimal) performance while keeping volume levels at a lesser level than a larger exhaust you can make a case here.
Timmy_Jones is offline   Reply With Quote
Old 04-26-2018, 09:22 AM   #26
SuperTom
SuperTom's Avatar
The assumption is that 90% of the board is street driven. Yes a larger exhaust will gain more peak hp but most aren't flooring it 24/7 in high RPM range.
My post was more about exhaust component matching. So if you did an ACE header that ends in 2.5"/63mm then you would go 2.5 the rest of the way.
Most of people on here use the less expensive Tomei/ Gruppe-S headers which end in 60mm. So jumping up to a 2.5" after that there will be some velocity loss..
Ive done 2.5" on other 2.0L and you can definitely feel that loss down low on street driving.
Old 04-26-2018, 09:54 AM   #27
Timmy_Jones
Spun
Drives: 23' Supra
Again, you continue to spread false information. Please do some research before posting here. Your post is completely about spreading things that are not true, you are compiling information from other people who didn't do research and dyno and calling it your own experience. I tend to rely on actual dyno runs.
Since you are having trouble with this, let me help: https://www.perrin.com/blog/post/3-0...d-stage-3-tune
Those are ACTUAL results. Please study the graphs closely and notice the gains from Stock to 2.5" and then even further gains from 2.5" to 3". If you have questions about the graphs, I would be happy to assist interpreting the data.
Old 04-26-2018, 10:14 AM   #28
SuperTom
SuperTom's Avatar
your right, I'm wrong. That article was made in 2013 I can't figure out why everyone on forums hasn't put a 3" on their car since then. I would imagine ridiculous sound on a street. My own experience is driving plenty of cars on street and track not just dyno runs from a company trying to sell their parts
Nvidia catless resonated or non resonated front pipe (q300 owners) ArtisticMaru Engine, Exhaust, Transmission 4 05-12-2016 04:44 PM
Catted UEL Header and Catless resonated/dual resonated front pipe? deuncos Engine, Exhaust, Transmission 3 04-23-2016 01:30 PM
Downpipe / Straightpipe Difference? mystic Southern California 18 10-23-2014 12:40 PM
Nameless Overpipe/Front Pipe VIDEOS RESONATED OR NON-RESONATED POST HERE !! ScionFR-S Engine, Exhaust, Transmission 20 05-27-2014 04:36 AM
Anyone straightpipe vids yet? Bounce Engine, Exhaust, Transmission 8 06-11-2012 04:39 PM
