Old 08-22-2013, 09:16 AM   #281
Mikem53
Drives: FR-S 6MT
Originally Posted by smbstyle View Post
Yes I believe @Dave-ROR did some testing and found a pressure drop when installing the oil cooler, and that 0w30 fixed the issue, but I'd check with him to verify.
If your using a higher viscosity oil to add pressure, are you still lacking flow because of the OC? Pressure and flow are two different things here..
Mikem53 is offline   Reply With Quote
Old 08-23-2013, 09:44 AM   #282
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Originally Posted by WolfpackS2k View Post
My Subaru service adviser specifically said to run a heavier weight oil if I plan to track the car.
I went with 5-40 just for last weekend and my daily driving temp went from ~204 up to ~212 immediately.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following User Says Thank You to Deep Six For This Useful Post:
WolfpackS2k (09-05-2013)
Old 08-23-2013, 10:10 AM   #283
SpeedLab
Drives: White
Sans-thermostat plate here, with a 1qt core, daily temps are right about 185-190F at the sandwich plate in stop and go during the day. Temps are about 175-185F during the cooler night time. Oil is 0w30 German Castrol.
I'll be logging and watching temps at VIR next week to see what sort of heat is generated. Logging peak/hold via a prosport sender and comparing to OBDII. The factory and my sender are quite close to each other, so it will be interesting to see how wildly they vary.
It's probably pretty important to add to the thread - oil temps are going to vary greatly depending where you are taking your reading. If you are using OBDII (torque, etc), you will probably see a more inaccurate reading, as opposed to an aftermarket gauge and sender. I wouldn't live or die by the obdII readings. You may even see a 30F+ difference between the reading at the filter and a reading in the pan.
SpeedLab is offline   Reply With Quote
Old 08-23-2013, 03:05 PM   #284
SkullWorks
Drives: SSM LT MT BRZ
Originally Posted by maj75 View Post
And where would one find these for sale? I went to a Robispec site and could find no listing for an oil cooler, sandwich plate or anything to do with engine cooling. In fact, no engine part were listed at all...
A link would be appreciated. I am prepping my car for an October Sebring HPDE and need to get a move on.
I am the designer and manufacturer of the sandwich plate, We are still working on getting the production numbers up to try and support everyone let down by other offerings. currently we are just trying to keep up with Robi's orders for his cooling solution but in the coming weeks we will be able to batch these far more effectively. We are working VERY hard to keep these reasonable in price even though obviously there is far more involved here than a simple Cast adapter with no thought to integration on a specific platform...did I mention made in the USA form domestic source 6061-T651 Aluminum and 304SST for the center post, ORB fittings to the AS spec and I make the ORB-AN's in house because I couldn't find offerings in the aftermarket that actually met the AN spec for ID with the optional radius entry?
@robispec
The Following 6 Users Say Thank You to SkullWorks For This Useful Post:
CSG Mike (08-23-2013), Deep Six (08-23-2013), ImperiousRex (08-23-2013), robispec (08-23-2013), WolfpackS2k (08-23-2013), wootwoot (08-23-2013)
Old 08-23-2013, 07:21 PM   #285
Lonewolf
Lonewolf's Avatar
Drives: Moped
@robispec
I love it when you talk dirty like that...
Old 08-23-2013, 07:58 PM   #286
OrbitalEllipses
Drives: Attitude
SkullWorks (08-23-2013)
Old 08-23-2013, 08:20 PM   #287
Deep Six
Deep Six's Avatar
I happen to be one of those waiting patiently.
I will not track anymore without the cooler as 270+ will take its toll eventually.
[SIGPIC][/SIGPIC]
Old 09-03-2013, 07:19 PM   #288
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by ATL BRZ View Post
Did you get that fixed yet?
I bypassed it if that's considered a fix. Not a priorty since it's not the primary track car anymore.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-22-2018, 08:07 AM   #289
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
how much did it cost you to make a DIY oil cooler, and how was it holding up? thank you
BRZ RN is offline   Reply With Quote
Old 04-25-2018, 09:25 AM   #290
CatDaddysBBQ
Drives: '13 FR-S
I know this thread is ancient and plenty of people have probably covered everything a ton of times, but I recently installed the mishimoto 19-row cooler and an AEM temp gauge (mounted the sensor into the mishimoto sandwich plate).
My first track day with it won't be for a few weeks, but so far so good. The kit went together REALLY easily and fit perfectly aside from needing to shave a bit of extra plastic off the oil fill cap to clear the temp probe from that side of the sandwich plate. Zero leaks, everything flows nicely and the gauge has shown me how freaking effective the 19-row cooler is. Holy cow.
CatDaddysBBQ is offline   Reply With Quote
Old 04-25-2018, 11:43 AM   #291
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
use quality parts and it won't be an issue.
Parts list here: http://www.ft86club.com/forums/showp...&postcount=126
Its around $400 iirc, but that was years ago so prices may have gone up. RacerPartsWholesale.com is cheapest (and linked in the list I shared)
Old 04-25-2018, 01:20 PM   #292
CSG Mike
CSG Mike's Avatar
Keep those banjo bolts tight. I've seen more than a few engine bay fires from them backing out under heat/vibration/pressure.
Re-torque them the night before your track day, and regularly re-torque them to make sure they fail.
Heck, even safety wire it if you can.
CatDaddysBBQ (04-26-2018), Icecreamtruk (04-26-2018)
Old 04-25-2018, 02:13 PM   #293
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
Wrong Thread!
Joesurf79 is offline   Reply With Quote
The Following User Says Thank You to Joesurf79 For This Useful Post:
Code Monkey (04-25-2018)
Old 04-26-2018, 09:45 AM   #294
CatDaddysBBQ
Drives: '13 FR-S
Will do. I've been peeking every few days now, but good to know - i'll definitely make it part of the routine around track days. Thanks!
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
Oil Cooler kit for FI applications, getting one? JoeBoxer Forced Induction 84 01-20-2013 09:48 AM
Cooler than drifting! Rampage Other Vehicles & General Automotive Discussions 8 04-03-2012 12:55 AM
