#1 | |
Proud of BOXER
Drives: Subaru Boxer
Perrin/Mocal oil cooler - Torque spec for center bolt
Does anyone know the torque spec for the center bolt that runs through the middle and holds the Mocal sandwich plate and spacer together?
During my last oil change I must've inadvertently loosened the center bolt when I removed the oil filter. This caused a decent oil leak since there was a few mm play in the stack. I took everything apart, cleaned it, and put it back together making sure to lube the double orings on the Perrin spacer as well as the flat Mocal gasket. I went hand tight/snug on the center bolt, but I checked it today and it's leaking again. I can slightly rotate the sandwich plate left and right so it seems like that center bolt loosened up again. So yeah, anyone know the proper torque spec for this bolt?
#2 |
Drives: Crapcan
25 ft-lbs
I wrote it on the underside of my hood with paint pen when I installed. |
#3 | |
Proud of BOXER
Thanks man. This is helpful for when I have to take it apart and clean it all up again on Friday when the engine is cold.
I also reached out to Perrin for the torque spec. Will post their reply here.
#4 |
Drives: 2013 FRS
But how do you actually torque it? Have you found a socket that fits or did you shave one down? Asking because I'm looking for a solution as well.
#5 | |
Proud of BOXER
I used a 27mm socket when I hand tightened mine, but it wasn't QUITE thin walled enough to fully sit flush around the bolt. Was still enough to grip it though.
#6 |
Drives: Crapcan
#7 | |
Proud of BOXER
Too bad you aren't local. We could have an oil cooler bolt tightening party.
No homo.
#8 |
Drives: Crapcan
LOL
Honestly you could probably get away with taking a grinder to a cheap socket. You really only need to add a bit of bevel to the bottom to get it to seat well. Even if you go through it or it gets thin, it is not that big of a deal. The torque spec is pretty low for a fastener of that size. |
#9 | |
Proud of BOXER
Perrin got back to me and also confirmed 25lbs. I guess I missed it when I checked the PDF of the installation instructions: "Fully tighten thermostat housing adapter. Using a 27mm socket, tighten to roughly 25ft lbs"
So it was there all along. Der duh der. Sorry for making a pointless thread. Anyway, it would be nice if someone (Mocal?) made a special socket specifically designed to tighten these center bolts.
#10 |
#11 | |
Proud of BOXER
I reached out to Mocal to see if they have a recommendation for a socket that will work.
#12 | |
Proud of BOXER
Here is their reply:
"Hello, Finding a suitable thin wall socket might not be the easiest thing. Generally use a open end wrench works fine. Tight is similar to a filter: snug and 3/4 turn. Regards, Eric Weller BAT Inc. / MOCAL USA" What's interesting is that he doesn't confirm the 25lb torque spec that I mentioned in my email to him, he just refers to tight as being snug and then 3/4 of a turn. Hm.
#13 |
I'll chime in with a couple issues I've noted with the Mocal adapter.
| Perrin Oil Cooler - Mocal Plate Spacer Bolt - Damn Bolt | Gopherboy6956 | Engine, Exhaust, Transmission | 16 | 11-23-2017 11:56 AM |
| FS: parts: ace header, FBM Mocal oil cooler, perrin CAI, and seibon VS style.. | Howardwei | Engine, Exhaust, Bolt-Ons | 21 | 06-22-2017 10:51 PM |
| Perrin Crank Pulley, Mocal/Setrab Oil Cooler, Mazworx Header Flanges | smellslikecurry | Engine, Exhaust, Bolt-Ons | 21 | 06-30-2014 06:50 PM |
| Mocal/Mishimoto Bolt On Oil Cooler Setup, SOLD | Philly758 | Engine, Exhaust, Bolt-Ons | 6 | 12-11-2013 04:47 PM |
| Camber bolt torque spec | ayau | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 01-09-2013 10:30 AM |
