Old 04-05-2018, 11:30 AM   #15
fika84
fika84's Avatar
Originally Posted by lutfy View Post
This is not good has anyone with stock gearing/stage 2 motor experienced this or its because of 'power' and speedier ratio?
Cheers,
Lutfy
If you're not seeing track time I wouldn't worry about it overheating.. He's got a pretty extreme setup..
fika84 is offline   Reply With Quote
Old 04-05-2018, 11:32 AM   #16
lutfy
lutfy's Avatar
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
Au contraire. The car hardly sees the street.
2015 FRS NASA ST/TT5
2022 LR Defender
2023 BMW M2
lutfy is offline   Reply With Quote
The Following User Says Thank You to lutfy For This Useful Post:
fika84 (04-05-2018)
Old 04-05-2018, 11:36 AM   #17
churchx
churchx's Avatar
Drives: 2014 GT86
Or sees .. from above the trailer?
fika84 (04-05-2018)
Old 04-05-2018, 11:50 AM   #18
fika84
fika84's Avatar
Yikes! Then you may want to monitor that shit! Can I assume you have an OS Giken diff as well? Or do you have a different mechanical LSD?
Old 04-05-2018, 12:44 PM   #19
fika84
fika84's Avatar
Originally Posted by mkivsoopra View Post
Unfortunately, no, I don't know. My LSD was stuck locked while on track. When it cooled down, it seemed ok again, but it permanently became an open diff after that.
Does OS Giken have a lifetime warranty? Or did they help at all with replacing it?
Old 04-05-2018, 12:52 PM   #20
mkivsoopra
Will most likely have to pay OSG to rebuild it, but not sure yet. I'm in the middle of swapping in a new unit right now.
mkivsoopra is offline   Reply With Quote
The Following User Says Thank You to mkivsoopra For This Useful Post:
fika84 (04-05-2018)
Old 04-05-2018, 01:28 PM   #21
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
OSG is really good at telling people to get bent. had a friend kill two of their diffs in a E46 ZHP and they told him sorry, sucks to be you and we know its garbage.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
The Following User Says Thank You to Roadcone For This Useful Post:
fika84 (04-05-2018)
Old 04-05-2018, 02:16 PM   #22
fika84
fika84's Avatar
Good to know! Now I don't feel so bad for not buying one! I was under the impression they were the bees knees!!
Old 04-05-2018, 04:14 PM   #23
Roadcone
StreetKart
They might be better on this platform. The only other OSG part i know of being used is a quad disk clutch in a friends 1200whp supra. it seems to do well.
Old 04-08-2018, 08:01 PM   #24
JohnnyGT86
JohnnyGT86's Avatar
Drives: 2014 FRS
I tried this one out. I had to notch some of the fins off to clear the Perrin exhaust.
https://www.ebay.com/itm/SICKSPEED-P...FWgXlJ&vxp=mtr
What are your impressions of the cover so far? happen to have pictures of it installed?
JohnnyGT86 is offline   Reply With Quote
Old 04-09-2018, 10:16 AM   #25
fika84
fika84's Avatar
Definitely serves it's purpose! For the price it works great.. I didn't want to buy the Greddy or Cusco and then have to cut it up.. plus this part doesn't require R&D like a header..
The Following 2 Users Say Thank You to fika84 For This Useful Post:
JohnnyGT86 (04-09-2018), Tristor (05-18-2018)
Old 04-09-2018, 07:13 PM   #26
CSG David
CSG David's Avatar
A properly configured LSD will last quite awhile and will be consistent.
Old 04-09-2018, 07:53 PM   #27
fika84
fika84's Avatar
What diff do you guys run? Any cooling added? Do you think the OS-Giken just couldn't handle the JUN V8 with higher FD?
Old 04-09-2018, 08:19 PM   #28
CSG David
CSG David's Avatar
We have used units including Tomei, Kaaz, Cusco, ATS, OS Giken, Guard, and some Drexler types. Cooling is dependent on how the diff is put together and what your application is. Setup configuration is important to consistency and reliability for its intended application.
The Following User Says Thank You to CSG David For This Useful Post:
lutfy (04-11-2018)
Review soon:OS Giken Super Lock Limited Slip Differential + Greddy differential cover mav1178 Engine, Exhaust, Transmission 5 02-11-2021 01:20 PM
temperature range of differential? jcw99 Engine, Exhaust, Transmission 4 08-04-2017 10:54 AM
What temperature do you put A/C on? FRiSson New England 23 06-13-2016 08:55 AM
E85 and oil temperature jvincent Engine, Exhaust, Transmission 11 11-12-2014 08:53 PM
Color Temperature FRSure Cosmetic Modification (Interior/Exterior/Lighting) 14 01-03-2014 11:19 PM
