Old 12-01-2016, 01:11 AM   #1
phrosty
ECU reset + warm start = stall
Hi guys, noticing a weird thing happening when I start the car after I reset the ECU -- disconnecting battery, flashing a tune, etc.
If the engine is warm, it'll stall out. I need to give it some revs to keep it alive, and get into gear at higher than idle revs or it'll die. Once it's in gear it's good to go.
If the engine is cold, it starts up and after the initial high RPM it dips down nice and low, not enough to sputter but enough that DRLs will dim out, and then recovers. My assumption is that the cold start routine is giving extra fuel and thus preventing the stall.
After I get it moving, lifting off the accelerator will cause a similar RPM dip as the cold start bit. Either way, after a few minutes of driving the car appears to calibrate and has no trouble starting up after that, warm or cold, and no RPM dip.
Any ideas to the cause or how to diagnose? I don't believe it to be a leak as fuel trims are spot-on, and I hear nothing out of the ordinary. It drives otherwise normally.
phrosty is offline   Reply With Quote
Old 12-01-2016, 01:27 AM   #2
First off, what do you mean by "flashing a tune, etc" .... ??
I suggest you turn the idle screw a half turn clockwise......
(yep, it used to be just that simple)
Seriously, maybe a tuner should take a look at it ..... or, drive it for a while to see it will re-learn the idle setting.
Old 04-08-2018, 07:05 AM   #3
Eazy-V
Did you ever get this resolved? I have a similar issue.
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73
1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress)
2023 Chevrolet Corvette Z51 Stock
Eazy-V is offline   Reply With Quote
Old 04-08-2018, 07:31 AM   #4
steve99
Drives: FT86
Check maf offset after start tables
Check ltft at idle after car as idled for 5 minutes if its high ie over 10% likely maf scaling needs work or you got some sort of exhaust or intake leak.
also look at afr at idle should be around 14.7
idle vacuum should be around -20in Hg or -9psi
Sportsguy83 (04-08-2018)
VDC AND CEL AFTER STALL? AdrianJ05 BRZ First-Gen (2012+) — General Topics 1 08-18-2015 04:23 PM
Stall on startup? Mhenderson Software Tuning 3 06-28-2014 05:27 PM
Stall/Torque Converter DeOppressorLiber Engine, Exhaust, Transmission 44 06-12-2014 01:00 PM
Engine cut out/stall followed by CEL vanetix Issues | Warranty | Recalls / TSB 4 01-16-2014 12:51 PM
Partial Stall's WRB Partial Stall Member's Car Journals 3 06-07-2012 07:53 PM
