Old 04-02-2018, 05:47 AM   #1
JIM THEO
Drives: BRZ 2018
4,3:1 final drive wanted
I bought a MY18 EUDM spec BRZ with 4,1:1 final drive and I am searching for someone that changed recenlty his 4,3:1 final drive and wants to sell his original crown and pinion for some money, of course they should be in perfect working condition!
If you know what other shims, part codes etc needed for installation it would be very helpful.
JIM THEO is offline   Reply With Quote
Old 04-02-2018, 10:16 AM   #2
fika84
fika84's Avatar
There's a lot about final drives and part needed on this forum, you will just need to search and find the info. Best to search using Google and do it as "final drive site:www.ft86club.com"
fika84 is offline   Reply With Quote
Old 04-02-2018, 05:54 PM   #3
JIM THEO
Drives: BRZ 2018
Thanks, I've already done it and the best answer I found is:
http://www.ft86club.com/forums/showp...1&postcount=24
Unfortunately no one seems to know what pinion seal is needed for the "4.56:1 - 41201-19557" gear ratio that best suits my needs thus I am searching for factory crown-pinion unit.
Old 04-04-2018, 11:30 AM   #4
fika84
fika84's Avatar
Page 295 has all the part numbers. Same ones that I used for my 4.88 upgrade. And I put the seals into an IS300 m96 carrier. http://www.ft86club.com/forums/attac...5&d=1449908436
The shims you'll just have to order after you measure everything up... follow the service manual and take your time getting it all right. It's a tedious process and no one can give you all of the part numbers you're going to need up front..
The Following User Says Thank You to fika84 For This Useful Post:
Teseo (04-04-2018)
Old 04-04-2018, 12:31 PM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
The WTB thread is over here
http://www.ft86club.com/forums/forumdisplay.php?f=84
fika84 (04-06-2018)
Old 04-05-2018, 07:18 PM   #6
JIM THEO
Drives: BRZ 2018
Thanks for the answers, Moderators can you move the thread to WTB please?
Old 04-05-2018, 07:39 PM   #7
JIM THEO
Drives: BRZ 2018
I am not talking about shims, I do know each installation requires different shims but what about:
-41201A 9036635133 BEARING, TAPERED ROLLER (FOR REAR DRIVE PINION
REAR)
-41201B 9036630093 BEARING, TAPERED ROLLER (FOR REAR DRIVE PINION
FRONT)
-41201C 9031138070 SEAL, OIL (FOR REAR DIFFERENTIAL CARRIER)
-41201D 9020135497 WASHER, PLATE (FOR REAR DIFFERENTIAL DRIVE PINION)
-41231 4123124010 SPACER, REAR DIFFERENTIAL DRIVE PINION BEARING
The above parts especially the bold ones are the same for EUDM factory 4.1, USDM factory 4.3 or preferably 4.56 final drive?
Cause I think the problem is with diff oil seal, spacer and washer!
Old 04-05-2018, 09:21 PM   #8
Teseo
Drives: frs
There must be a way to get it more cheaper
Old 04-05-2018, 10:07 PM   #9
86TOYO2k17
Drives: 2017 toyota 86
RHDJapan has a 4.3 kit comes with everything needed for about 650$ shipped anywhere.
They also have a few others if you want to go more aggressive. for the cost though .2 isn't going to make that much of a difference. i would look at something more aggressive, but depends what your goal is.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Teseo (04-05-2018)
Old 04-05-2018, 10:28 PM   #10
Teseo
Drives: frs
4.5 would be on the spot. If it comes with all hardware, i just need to find a shop who can do the labour
Old 04-05-2018, 10:40 PM   #11
86TOYO2k17
4.5 comes with everything but shims, but the shop should have that. Most transmission shops or differential shops should be able to do it. Probably 500-800 for labor.
Old 04-06-2018, 10:13 AM   #12
fika84
fika84's Avatar
REAR)
FRONT)
Yes, they are the same. The diameter of the pinion shaft doesn't change between gear ratios... the number of teeth of both pinion and ring gear change.. it's that ratio that gives you your final drive ratio.. Like I said.. I used these with my 4.88 final drive install and I did all the work myself.
Old 04-07-2018, 06:50 PM   #13
JIM THEO
Drives: BRZ 2018
@fika84 thanks, this thread confused me: http://www.ft86club.com/forums/showp...1&postcount=24
But it mention what part number is each different gear ratio kit, 41201-19557 (4.56:1) my preferred one costs about 500$ plus shipping from a friendly shop, not bad at all and labor is very cheap locally!
The Following User Says Thank You to JIM THEO For This Useful Post:
fika84 (04-09-2018)
Old 04-07-2018, 10:14 PM   #14
Hiko
Drives: 2016 FR-S
For another perspective for the OP's sake, I've taken my 4.1 to a 4.3 and am very much pleased with it. It's not a world of difference, but can certainly be felt and is an improvement in drive ability for sure.
Would agree that it also depends on the goals. Mine was just to have a bit punchier car without compromising it as a daily driver.
Hiko is offline   Reply With Quote
Final BRZ Goal leevanf BRZ First-Gen (2012+) — General Topics 11 09-14-2017 03:28 PM
Final Drive: 4.56 vs. 4.88 mcbrawr Engine, Exhaust, Transmission 43 12-26-2015 07:23 PM
driver side Windows cant contrl by driver side button athlon816 Issues | Warranty | Recalls / TSB 12 12-13-2014 10:06 AM
World Cup Final D4S Mid-Atlantic 0 07-08-2014 04:39 PM
Final 13' BRZ brochure poormans_LFA BRZ First-Gen (2012+) — General Topics 29 03-31-2012 02:43 AM
