Old 04-06-2018, 11:49 AM   #1
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Camshaft's
Are 2012 cams the same grind as 2015 and can 2012 cams be installed in a 2015 engine?
Lunatic is offline   Reply With Quote
Old 04-06-2018, 12:24 PM   #2
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
They are different. The parts were changed to accommodate the changed lengths of the valves. Check below:
Camshaft, Intake, RH
old SU003-00180
new SU003-04741
Camshaft, Exhaust, RH
old SU003-00181
new SU003-04742
The change was done in May 2013. In general 2014-2016 models have the same valves, only 2013 has the earlier valves.
Old 04-06-2018, 12:26 PM   #3
Lunatic
Lunatic's Avatar
old SU003-00180
new SU003-04741
old SU003-00181
new SU003-04742
OK, thats what I thought. The dealer gave me different part numbers but didn't know why.
Old 04-06-2018, 12:29 PM   #4
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Check here for all the changed parts:
http://www.ft86club.com/forums/showthread.php?t=63944
Old 04-06-2018, 12:38 PM   #5
Lunatic
Lunatic's Avatar
thank you.
Old 04-06-2018, 03:23 PM   #6
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
So how do I know which ones I have?
JimmyMac is offline   Reply With Quote
Old 04-06-2018, 03:32 PM   #7
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
These are the Subaru part numbers for the '15 model car:
It looks that yours are the first version.
Old 04-06-2018, 03:38 PM   #8
JimmyMac
JimmyMac's Avatar
Well I'm rebuilding an 06/12 model year. So I should be good to go on the cams then... I hope hehe. Thanks.
Old 04-06-2018, 08:18 PM   #9
Lunatic
Lunatic's Avatar
Found a set of 2014's. Thank you all.
Piper Camshaft.. Walla Walla Engine, Exhaust, Transmission 5 05-12-2017 08:46 AM
Camshaft Bearing FRSloth Engine, Exhaust, Transmission 1 10-15-2016 02:19 AM
camshaft CLEARANCE aagun Engine, Exhaust, Transmission 22 10-03-2015 09:24 PM
camshaft CLEARANCE aagun Software Tuning 1 09-05-2015 07:49 AM
New TSB for camshaft sensor whitefrs Issues | Warranty | Recalls / TSB 13 03-11-2014 02:54 PM
