Old 04-04-2018, 11:57 AM   #1
fika84
fika84's Avatar
Differential Temperature
Thought I'd post this up as informational. I was curious as to the temperature that my diff was reaching, mainly because I've put in the MFactory mechanical LSD and want to make sure I'm not going to toast it on the track.. The fluid that I use is Torco RTF and the viscosity of that fluid goes down quite a bit after 220F.
Anyway, I installed a new cover and added a temp gauge and so far under both normal and canyon driving I've hardly been over 140F..
I'll update this thread once I get back out on the track as I KNOW I'm harder on the car there than the canyons.. to paranoid in canyons..
fika84 is offline   Reply With Quote
Old 04-04-2018, 11:57 AM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Good info, thanks for sharing.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 04-04-2018, 12:31 PM   #3
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
which cover did you install?
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 04-04-2018, 01:22 PM   #4
mkivsoopra
FWIW, I overheated my OS Giken at the track... this is with the Cusco diff cover. My setup is a bit extreme though: 5.29:1 final drive, 11k engine RPM. This was before adding an external cooler and temp probe.
Last edited by mkivsoopra; 04-04-2018 at 08:50 PM. Reason: Cusco diff cover, not GReddy
mkivsoopra is offline   Reply With Quote
Old 04-04-2018, 01:45 PM   #5
Roadcone
StreetKart
Originally Posted by mkivsoopra View Post
FWIW, I overheated my OS Giken at the track... this is with the GReddy diff cover. My setup is a bit extreme though: 5.29:1 final drive, 11k engine RPM. This was before adding an external cooler and temp probe.
what engine was turning 11k?!
Old 04-04-2018, 01:53 PM   #6
mkivsoopra
3.0L Synergy V8
Old 04-04-2018, 06:28 PM   #7
fika84
fika84's Avatar
I tried this one out. I had to notch some of the fins off to clear the Perrin exhaust.
https://www.ebay.com/itm/SICKSPEED-P...FWgXlJ&vxp=mtr
Old 04-04-2018, 06:30 PM   #8
fika84
fika84's Avatar
I love your build!
I'm rocking a 4.88 FD... and no v8... and no 11k... but what cooler and pump did you install?
Old 04-04-2018, 07:10 PM   #9
mkivsoopra
Originally Posted by fika84 View Post
I love your build!
Tilton oil pump and Setrab 1-13. We'll see how it fares!
Old 04-04-2018, 07:40 PM   #10
sw20kosh
Drives: 2013 Black FR-S
@mkivsoopra can now pass miata's with ease!
Old 04-04-2018, 08:30 PM   #11
mkivsoopra
woohoo!
Old 04-04-2018, 10:01 PM   #12
fika84
fika84's Avatar
Another question, what temp were you seeing when it overheated, do you know?
Old 04-05-2018, 04:27 AM   #13
mkivsoopra
Unfortunately, no, I don't know. My LSD was stuck locked while on track. When it cooled down, it seemed ok again, but it permanently became an open diff after that.
Old 04-05-2018, 09:48 AM   #14
lutfy
lutfy's Avatar
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
This is not good has anyone with stock gearing/stage 2 motor experienced this or its because of 'power' and speedier ratio?
Cheers,
Lutfy
2015 FRS NASA ST/TT5
2022 LR Defender
2023 BMW M2
lutfy is offline   Reply With Quote
Review soon:OS Giken Super Lock Limited Slip Differential + Greddy differential cover mav1178 Engine, Exhaust, Transmission 5 02-11-2021 01:20 PM
temperature range of differential? jcw99 Engine, Exhaust, Transmission 4 08-04-2017 10:54 AM
What temperature do you put A/C on? FRiSson New England 23 06-13-2016 08:55 AM
E85 and oil temperature jvincent Engine, Exhaust, Transmission 11 11-12-2014 08:53 PM
Color Temperature FRSure Cosmetic Modification (Interior/Exterior/Lighting) 14 01-03-2014 11:19 PM
