Old 06-17-2013, 02:10 AM   #1
YDNA
YDNA's Avatar
Drives: Raven FR-S
KWV3 owners, did anyone remove the helper springs?
Was thinking about removing the helper springs just to sit a little bit lower so the wheel gap isnt as big. Has anyone done this yet?
YDNA is offline   Reply With Quote
Old 04-02-2018, 08:29 PM   #2
iFunner
iFunner's Avatar
Drives: 2016 Toyota 86
I installed mine today and my mechanic decided not to use them because they would not fit unless preloaded the spring. Any other owners with KWs done this?
iFunner is offline   Reply With Quote
Old 04-02-2018, 10:41 PM   #3
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
Running the shocks that low will put them outside of the ideal ride height. Not recommended.
What ride height were you trying to set the car to? "Preloading" the spring might be necessary to get that ride height but there is nothing wrong with that. These shocks are adjusted by moving the spring collar so that sounds normal.
Lincoln Logs is offline   Reply With Quote
Old 04-02-2018, 11:01 PM   #4
iFunner
iFunner's Avatar
I was just trying to set it to the recommended settings but even then it's a low drop about 1.4 inches around 1 finger gap. The helper springs fit in the back but not in the front. could it be my camber plate? Might have to go to another shop to check the measurements...
Old 04-03-2018, 12:11 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
One doesn't measure recommended drop / best working range for suspension by measuring wheel gap :P.
For our already relatively low cars with relatively low suspension travel reasonable drop to not fsck up suspension geometry too much is within 1". KW may have some specific recommended settings. Have you consulted specs? Installation manual?
Old 04-03-2018, 01:00 AM   #6
TOPEC
camber plates will add to the stack height depending on the design. the KWV3 are meant for OEM style top hats/camber plates where the top of the strut mounts past the strut tower where as some other camber plates have the strut mount flush with the strut tower adding height. which camber plates r u running?
TOPEC is offline   Reply With Quote
Old 04-03-2018, 08:15 AM   #7
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
you should sell your V3's and buy a set of racelands.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 04-03-2018, 08:42 AM   #8
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
It shouldn't be too difficult to get a decent drop out of the V3s and still remain within recommended specs. Unless I did something horribly wrong (it was my first time working with coilovers), I actually had to set them to the MAXIMUM height of the recommended range to prevent the car from being too low for my tastes. I'm running Raceseng Camber plates up front which have a "minimal stack height."
Note the shadows make the car seem a bit lower than it actually is in this photo. There is a gap between the tires and the top of the fender. As there should be!
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 04-03-2018, 12:33 PM   #9
iFunner
iFunner's Avatar
I’m still new to coilovers altogether but currently the ride is fine but might be a bit soft in front. Should I be worried about not having the helper springs in the front? It will just unsettle if I lift the car up right?
I’m running camber plates from feal coilovers so it looks like this:
Old 04-03-2018, 01:02 PM   #10
jamal
jamal's Avatar
Drives: Legacy GT
If you remove them to get the car lower, be sure to measure the amount of bump travel left at your desired ride height. It might be very little...
The only thing the helpers do is keep the springs seated at droop. This is because the shock has more travel than the main spring. They're not completely necessary, but a good idea, otherwise the spring has the opportunity to rattle around or get wedged in at an angle after it comes unseated.
jamal is offline   Reply With Quote
Old 04-03-2018, 01:08 PM   #11
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
The only reason to remove the helper springs to go lower is if you're already bottomed out on the spring perches.
ineedyourdiddly
Old 04-03-2018, 01:18 PM   #12
iFunner
iFunner's Avatar
Thanks guys I’ll have a shop double check the install. It wasn’t installed since there was basically no room for the helper spring and we were already at the maximum (highest) height of the recommended settings. We also didn’t want to add preload to the main spring. Would I have to preload the main spring in order to get some room to install the helpers?
Old 04-03-2018, 01:42 PM   #13
wparsons
wparsons's Avatar
The helper spring is pretty thin when fully compressed, you're not going to get that much more drop. They're there to keep the spring properly seated at full droop. Without them you could have the spring become unseated over a big bump and not settle right after.
Short answer, don't do it unless there's enough tension on the main spring at full droop to keep it from becoming unseated.
There will absolutely be pre-load on the helper at full droop, that's the point. I don't have my new upper mounts yet, but looking at mine without upper mounts it looks like at the lowest recommended setting there would still be a bit of pre-load on the helper, at the highest recommended setting there would be some pre-load on the main spring.
Don't second guess the instructions, KW knows what they're doing.
flickr
Old 04-03-2018, 02:38 PM   #14
jamal
jamal's Avatar
Drives: Legacy GT
Uh, I don't get what is going on here. You have the height turned all the way up? why are you not lowering the perches then to make the car lower?
Maybe you need someone more familiar with adjustable coilovers doing this.
Guys/Gals who installed KWV3 install these washers? OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 06-14-2013 01:35 AM
Best way to remove OEM struts/springs taimysho0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 06-07-2013 03:21 PM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 10:41 PM
Question for HOUSTON Fr-s owners and/or to be owners enjoi23 Southeast 2 08-30-2012 09:48 PM
