Old 06-07-2013, 02:04 PM   #1
taimysho0
Drives: frs
Best way to remove OEM struts/springs
hi, im planning to install coil overs and was starting on the rears. i have the car jacked up on one side of the rear im working on. im having some trouble pulling the strut assembly out, is there a trick to this? such as taking off other bolts? i looked at the coilover DIY and it says you may need to push down on the hub, which ive tried but theres barely any play at all.
also as a side note, just to confirm, i wouldnt have to adjust the preload from for the coilovers from factory right? i just want it default preload. And the endlinks, are these necessary?
taimysho0 is offline   Reply With Quote
Old 06-07-2013, 02:21 PM   #2
xwd
Take out the bolt holding the lower control arm to the hub, once you separate them it will allow the control arm to move further down so you can more easily remove the shock.
What kind of coilovers are they? What endlinks? if they came with front endlinks I would use them as with some of the coilovers the strut bodies are much shorter and the stock endlinks will end up being too long.
Old 06-07-2013, 02:30 PM   #3
cnk
Drives: '13 DGM BRZ Limited
It's also usually easier to jack the entire rear end up or the entire front end up when you do the install. That way, you don't have pressure on the sway bar from the other side. So, jack up one end, put it on jack stands, remove stock, install new.
cnk is offline   Reply With Quote
Old 06-07-2013, 02:37 PM   #4
taimysho0
Drives: frs
i bought a set of stance with swift springs
Old 06-07-2013, 03:21 PM   #5
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
This.
It's hard enough to get the rears out with both rear wheels off the ground and the rear sway still attached, let alone doing one side at a time!
GTM_Challenge is offline   Reply With Quote
Replacing Struts and Installing Coil Springs DarrenDriven DIY (Do-It-Yourself) Guides 195 04-26-2017 04:15 PM
Selling stock FRS Springs/Struts + Stock Pads + Rotors 6k on all! NickFRS Brakes, Suspension, Chassis 6 03-14-2013 01:38 AM
TRD has Springs & struts for my stupid Yaris but not my FRS? regal Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-17-2013 04:25 PM
Stock pads + rotors + springs/struts for sale in Gladstone Oregon 6k miles NickFRS Northwest 2 12-23-2012 01:03 AM
Stock Springs/Struts FRS jadewbj Brakes, Suspension, Chassis 1 12-18-2012 10:00 AM
