Old 03-24-2018, 08:16 AM   #15
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
For what it's worth, I had the dealership do my car. I told them needed an alignment and used the car for autocross, so I'd like aggressive negative camber. The tech said that the cars don't have much wiggle room, but he'd see what he could do without adjustable hardware. End results was about 1.5 degrees in back, 1.2 in front. Couldn't be happier. Your communication, honesty, and the questions you ask are the most important tools here.
funwheeldrive (04-02-2018)
Old 03-24-2018, 08:54 AM   #16
Don Ivey
Drives: '13 FR-S
Thanks guys, appreciate all the input. I'll be going to the local shop that I've built a somewhat solid relationship with. Regards,
Don Ivey
Don Ivey is offline   Reply With Quote
The Following User Says Thank You to Don Ivey For This Useful Post:
humfrz (03-24-2018)
Old 04-02-2018, 08:14 PM   #17
bmxr
bmxr's Avatar
Drives: 2017 BRZ PP WR Blue
FWIW, I have had too many questionable experiences taking vehicles to regular shops, dealership or otherwise, to ever do it blind. The best thing to do is find someone who aligns performance cars for a living. They will have a much better idea of what you want, why, and not be motivated to "just get you within spec", tell you that's all that is possible, and send you on your way. The guy I use aligned my car, gave me recommendations given my camber bolt setup, gave me suggestions on the next few suspension mods to do, and which to avoid, experiences with certain tires for open track and autocross, and then checked up on me at the track to make sure everything was going to plan (he was there crewing a customer car). Ask around at whatever shops field race cars in your local area. In my case there is NASA, FARA, and SCCA, plus all the HPDE guys... There's no nationwide lifetime warranty, but it was probably the best money I spent on my car so far.
bmxr is offline   Reply With Quote
Alignment settings/Alignment Shop v1beeee CANADA 27 04-24-2017 04:54 PM
Going to dealership for new brz Sherb BRZ First-Gen (2012+) — General Topics 27 07-13-2016 05:18 PM
Fed up with dealership MisterSheep Issues | Warranty | Recalls / TSB 76 05-10-2016 07:01 PM
Camber/alignment for Eibach Prokit and when should I get alignment? Meanderchap Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2016 03:44 AM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 09:53 PM
