Drives: '13 FR-S
Alignment: Dealership or Elsewhere?
As per title, do you trust regular alignment shops to do alignment correctly, or is it necessary to go to dealerships? I'd rather not go there, but want it done correctly. Thanks,
Don Ivey '13 FR-S |
Alignment shops do hundreds of them a week. They are either capable enough to do any car or they go out of business fast. Just pick one that has been around a while and all is good.
Only users lose drugs.
Drives: All the time
How good an alignment is depends directly on the person actually doing it. I've gotten both good and bad alignments at private shops and dealerships; 99% of them will just do a 'by-the-'book' alignment, which means if everything is within the wide range of factory specs, they call it good, since that's good enough for the typical grocery-getter. My suggestion is look for a shop that's been there for a long time, and for an old dude to be doing the alignment work. It usually takes a little convincing to get them to use more aggressive, non-stock numbers, but they'll get it right on the money on the first try usually.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Years ago I took my Passat to a tire place and asked if they were set to handle this car. Swore up and down they did many of them.
Turned out they had no experience with Passat and the parameters weren't even loaded into the system. They said they would try to dial it in for me. No way. I told them they were done with the car. To top it off, they jimmied a lug nut. The dealer had a hell of a time fixing it. I took the bill to the tire place and made them pay it. They were surprised at the high bill. I told them it will be a lot more if we lawyer up and go downtown and they get to eat court costs on top of it. Last time I went to a tire franchise. Costco is my choice. Limited selection but they have what I want and their customer service is legendary. |
Ohne Titel
Drives: 2017 BRZ PP ISM
Look up reviews of alignment shops in your area. Make sure to get an alignment report that shows the before and after specs.
Well, I reckon that depends on who is on duty on the alignment rack.
For average driving, any shop or dealership that has a rack and someone who knows how to use it, will do.. Personally, I take my cars to a local shop where I know the fellows. humfrz |
Drives: 2013 FR-S MT Hot Lava
If you have a Firestone shop near you,you should take advantage of their lifetime alignment service.
#8 | |
Go to whichever dealership/private shop you want, and ask them: "Can you adjust my camber to -1.5?" (or whatever degree you prefer) If they answer "Yes", get the hell out of there as fast as you can! |
#9 | |
![]() Needless to say, I left and never thought of going to another Firestone again. Sorry for digressing. |
#10 | |
As stated before it depends on the shop, there's dealerships with alignment techs that are amateur racers that will nail it and there's 'performance shops' that do a sloppy job. If all you need is a decent street alignment (seems like that's all OP wants) pretty much any reputable shop should be able to do just fine, it's a very simply designed car, you just gotta accept that factory stock there is no camber adjustment on this car. |
#11 |
Drives: 2013 FR-S Series 10
not to open a can of worms, but camber bolts should be plenty for a street car? and do most alignment shops install them?
#12 |
Drives: FR-S 10 Series
Wherever you go, ask for a printout of the before/after to see the difference. I would get these every time I had an alignment on my last car (salvaged after an accident, hence the multiple alignments), and they would give me a printout every time so I could tell what was off for reference when I was getting my repairs done. It was pretty neat to see the accuracy of their charts (assuming they were accurate).
Just fyi, I went to a basic auto shop, nothing fancy and no dealership. Even though it was my last car, I built enough rapport with the shop that I would take my FR-S there for an alignment if it ever needed one. |
#13 | |
#14 |
Drives: 2017 Toyota 86
If you only need toe adjustment, you can pretty easily do it yourself with a few jackstands and some string, google 'string alignment'. That's what most racing teams do. Anything beyond toe requires either a lot of math or some more involved instruments, though.
If you want someone else to do it, as everyone else has said, it doesn't really depend on the shop, it depends on who's working there that day. Unless you already have experience with a place it's hard to tell if it's good or not. I would not recommend a dealership over a private shop. Dealers have very little incentive to do good work, private shops depend on it for their livelihood. |
| Alignment settings/Alignment Shop | v1beeee | CANADA | 27 | 04-24-2017 04:54 PM |
| Going to dealership for new brz | Sherb | BRZ First-Gen (2012+) — General Topics | 27 | 07-13-2016 05:18 PM |
| Fed up with dealership | MisterSheep | Issues | Warranty | Recalls / TSB | 76 | 05-10-2016 07:01 PM |
| Camber/alignment for Eibach Prokit and when should I get alignment? | Meanderchap | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 02-01-2016 03:44 AM |
| DIY alignment - quick way to set alignment while new suspension settles? | 1Cor10:23 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 12-11-2014 09:53 PM |
