Old 03-15-2018, 01:22 AM   #43
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Originally Posted by carlovestela View Post
Do i need camber bolts in front to adjust camber?
Whats the ideal camber for front and rear
I think trd springs lowers 1”
You're also going to need lca's in the rear to adjust camber.
As for alignment, it totally depends on your driving style. I would try to have more front camber than rear though in most setups.
A good daily alignment would be -1 to -1.5 F/ -1 R.
tyler_win_photo is offline   Reply With Quote
Old 03-22-2018, 02:28 PM   #44
carlovestela
Drives: 2015 Firestorm FRS
Can wheel alignment do -1.5 front and -1 rear without using camber bolts and lca?
Originally Posted by churchx View Post
Ideal can be differing depending on car and on use type (daily or track or some mix of those) and from tires used and from wished handling change. Even stock rear camber is not zero, i somewhat doubt on it being best choice.
Commonly i see mentioned -1.5dg front, -1dg rear camber for daily driving, -2.5dg to -3.5dg front camber for track, -2dg to -2.5dg rear, even more camber front like -4dg or -5dg for drift setups. Zero toe front, slight +0.1dg toe in rear. (stock is zero camber front, -1.2dg rear, zero toe front, 0.2dg rear toe in. Best way to dial "ideal" camber is with tire pyrometer with comparing tire inside/outside temps.
carlovestela is offline   Reply With Quote
Old 03-22-2018, 03:09 PM   #45
churchx
churchx's Avatar
Drives: 2014 GT86
There is no camber adjustment on our cars stock, only toe adjustment.
Stock front camber is 0, rear -1.2. Lowering car adds some negative camber to both.
So you can think what to expect, if you don't add adjustability to one of ends.
But -1.5 front can be got with just one set of camberbolts .. more expensive with rear, but: 1) -1 is not that far from -1.2 so you can leave it as is, if it's even enough to your taste on both sides, 2) cheapest LCAs like SPC/Whiteline/Eibach imho are cheap enough.
Old 03-22-2018, 03:25 PM   #46
dattran86
Driver
Drives: 2013 Whiteout FRS
I did track day and autocross on GTF1, no complaint. They held up very well to abuse.
Check out my website:
http://www.aim4apex.com/
IG: aimforapex
dattran86 is offline   Reply With Quote
Old 03-23-2018, 10:28 AM   #47
Jordanwolf
Rice King
Jordanwolf's Avatar
Pictures coming soon (tm)
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 03-23-2018, 11:45 AM   #48
mnuttall
Drives: 2013 Audi Allroad, 2017 Subaru BRZ
I'm looking forward to seeing the pics. I'm another Canadian with a set of these on the way (hopefully will arrive today!).
mnuttall is offline   Reply With Quote
Old 03-23-2018, 11:52 AM   #49
Jordanwolf
Rice King
Jordanwolf's Avatar
Are you going to fit the stock tires on yours? I've already done this and they fit well.
Glorious Honda.
Old 03-23-2018, 12:01 PM   #50
mnuttall
That's the plan for now. They've got less than 5,000km on them. Once I wear them out I'll probably put some Michelin PS4S on. The PSS on my Audi are fantastic.
Did you go for the 17x8 or 17x9? I got the 17x8.
Old 03-23-2018, 12:32 PM   #51
Jordanwolf
Rice King
Jordanwolf's Avatar
17x8, the 17x9 would've been a stretch for stock tires. I have no idea what I want to upgrade to after though, something with decent tread life for sure, but not so loud when spiritedly driving.
Glorious Honda.
Old 03-23-2018, 07:55 PM   #52
Jordanwolf
Rice King
Jordanwolf's Avatar
Here is one of them with tire mounted.
Glorious Honda.
The Following User Says Thank You to Jordanwolf For This Useful Post:
new2subaru (03-23-2018)
Old 03-30-2018, 02:36 PM   #53
mnuttall
Put mine on today, along with Eibach Pro Kit springs.
Sent from my LG-E973 using Tapatalk
Old 03-30-2018, 03:51 PM   #54
Jordanwolf
Rice King
Jordanwolf's Avatar
You just couldn't wait haha.
I'm still looking at this weather kinda like, do I wanna put them on yet.. Temps can still drop and I'm going to be making a run north soon, which has different weather conditions -_-
Glorious Honda.
Old 03-30-2018, 03:56 PM   #55
mnuttall
Nope, definitely couldn't wait. It's a second car for us; worst case I have to drive it six minutes to work in non-ideal conditions, so no big deal if the weather isn't ideal.
Old 03-30-2018, 05:44 PM   #56
rmr
rmr's Avatar
Drives: FRS 10-series
is that... St Joes??
Really like the GTF1, if they came in anything but black I would be all over it. Very light weight.
What tires?
edit: just saw location. Watch out for those London potholes
rmr is offline   Reply With Quote
Canadian in NZ Cole NEW ZEALAND 4 02-03-2016 04:59 PM
Need a favor from a Canadian BRZ owner, (Canadian Base model with Manual Trans)) boomslang CANADA 1 09-07-2014 11:24 PM
Any Canadian BRZ's out there? BP1913 BRZ First-Gen (2012+) — General Topics 5 05-30-2012 11:14 AM
Canadian FRS vs. BRZ Marloon CANADA 24 05-02-2012 04:40 PM
TO ALL MY CANADIAN FRIENDS - BRZ Canadian Pricing Released zex BRZ First-Gen (2012+) — General Topics 7 04-24-2012 12:46 AM
