Old 03-26-2018, 10:54 PM   #1
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
5 0r 6-point belts
I like the seats in my FRS and figure they'll be Ok on track. But how do I deal with the airbags since I need full harness belts. Is there a way to pull the fuses and deactivate the airbags? Better still, how do I safely remove the damned things? If I have to pull my seats for whatever reason, how do I do it safely?
Qwimby1 is offline   Reply With Quote
Old 03-27-2018, 01:20 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Why do you need a harness? Wait never mind that. One thing at a time.
Let's go off what most of the track safety list requires around here. If you have a harness you'll need a roll bar. Then again depends on the organization and how flexible they are about it.
If you just want to roll around the town with a harness don't. Local laws don't allow it. Unless you get those retractable 4 points they make for jeeps.
If and when you eat shit at the track it's best to have the air bags. I won't mess with them unless I'm going full race car, not full ricer.
If you want to remove your seat or any other part that has an air bag, simple: disconnect the battery. Handle with caution.
The Following 4 Users Say Thank You to Mr.ac For This Useful Post:
JohnJuan (03-29-2018), Leonardo (03-27-2018), Shark_Bait88 (03-27-2018), x808drifter (03-27-2018)
Old 03-27-2018, 01:48 AM   #3
FirstWinter
Drives: Car
If you have to ask then don't do it. Why do you need a harness?
FirstWinter is offline   Reply With Quote
Old 03-27-2018, 02:48 AM   #4
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Dude has 18 posts and he's from Florida. Of course he needs a harness, but not a cage, and stock seats.
The Following 3 Users Say Thank You to EAGLE5 For This Useful Post:
FirstWinter (03-27-2018), Shark_Bait88 (03-27-2018), x808drifter (03-27-2018)
Old 03-27-2018, 04:35 PM   #5
He needs one and he needs it NOW!
http://www.ft86club.com/forums/showt...54#post3064454
JohnJuan (03-29-2018), Shark_Bait88 (03-27-2018)
Old 03-27-2018, 05:59 PM   #6
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
There's a Wine Country Motorsports next to Sebring -- about 86 miles away from Sarasota. Good place to try on gear, sit in some seats, etc.
http://winecountrymotorsports.com/
TofuJoe is offline   Reply With Quote
Old 03-27-2018, 06:10 PM   #7
FirstWinter
Drives: Car
Ok assuming he's not an idiot trying to rice his car on the street lol. To remove the airbags all you have to do is unplug/unclip them. Ideally you want to be safe and disconnect the battery then press the brakes for 15-30 seconds until the brake lights don't even come on. I've done them without disconnecting the battery but I don't recommend it.
You'll have to search on the forums if this will cause any issues with the ECU but I don't think so. There's also the airbag module under the head unit (on top of transmission tunnel) but again I'm not sure if you'll run into issues when disconnecting.
However I do not advise running stock seats with a harness/cage/bar/etc. If you're going to do it you should get proper seats. It's designed to work together as a system. Not having part of it will compromise your safety and will most likely be more dangerous than running the OEM 3 pt seatbelt, seat, and airbags.
Old 03-28-2018, 12:32 PM   #8
Qwimby1
The Champcar event is in another car so the harness question isn't about that.
My question about harness is to prepare my newly-bought FRS for track days. I've been an instructor for a long time, but haven't been active for the past few years. I run dedicated track wheels and tires, and would feel lost in three-point belts on the track. I'd have to look but I think my current club wouldn't allow track rubber without a harness anyway. No roll bar is required in a hard top coupe, so I'll put in a harness bar. It looks to me like the stock seats will work fine with a harness and sternum strap. I've done that in other cars, but I wouldn't want to have air bags pop when I'm strapped into a harness. I'll go back to three-point belts and street tires when I leave the track. I wouldn't attempt to use a harness on street.
I hope that clears up any confusion.
Thanks
Wtb front seat belts Parman Want-To-Buy Requests 0 06-21-2017 04:09 AM
WTB front seat belts Bent42 Canada Classifieds 0 05-30-2017 09:37 PM
Colored Seat Belts? AzureShadow Cosmetic Modification (Interior/Exterior/Lighting) 23 04-08-2016 07:14 PM
Front seat belts aznatama Want-To-Buy Requests 0 09-08-2014 03:54 PM
Wtb: front seat belts Guildjs Want-To-Buy Requests 0 01-13-2014 09:46 PM
