Old 03-21-2018, 10:48 PM   #1
Fuergrissa
Drives: 13' FR-S
bad driveline vibration when accelerating at low RPM
I recently replaced my throw-out bearing after the factory one had failed which involved removing the drive shaft and dropping the transmission. I replaced the trans oil at the same time.
After the work I am getting a severe vibration when accelerating at low RPM when the engine gets bogged. This is the only time the vibration is present but it is very severe. I know TOB's are a common job, has anyone encountered this before? Not excited to drop the trans again without knowing exactly what I'm looking for. I'm assuming something with the clutch or the DS carrier bearing but really don't know.
Thanks
Fuergrissa is offline   Reply With Quote
Old 03-22-2018, 12:05 AM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Did you install an aftermarket lighweight flywheel/clutch kit?
EndlessAzure is online now   Reply With Quote
Old 03-22-2018, 12:14 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Chances are something is not torqued down properly.
Could be tranny mounts, drive shaft, who knows. It's one of those things where you just need to put a wrench and feel what's loose.
Old 03-22-2018, 12:43 AM   #4
Thanks
Welcome to the group, there, Fuergrissa ..........
So, you didn't have this vibration before you replaced the TOB .. ??
Did you take off the pressure plate and or replace the clutch disk .. ??
Did you do the work or did someone else do the work .. ??
Come back.
Old 03-23-2018, 08:27 PM   #5
Fuergrissa
Drives: 13' FR-S
No, they were not removed
You are probably right, this was my assumption
No, it wasn't present before. neither pressure plate nor clutch were removed, just pulled the trans off, replaced the TOB and retaining clips, greased the fork pivot (was squeaking), and reinstalled with new trans fluid.
I did the work.
I marked the DS alignment to the differential so it went back on the same way, but the front yoke may have gone into the transmission with a different orientation.
It may be a few weeks before I can put it back in the air and investigate, so I just wondered if anyone had some different ideas. I don't think it's a balance issue because it does not increase in intensity with RPM. and if it were a harmonic resonance it would occur at the same RPM during all operating conditions. The fact that it is only in a certain RPM and only a certain operating condition (under load) makes me think it is probably something mounted too rigidly or not rigidly enough. Checking all the bolts is probably to best way to figure it out, but if anyone has another idea I would love to hear it.
Thanks
The Following User Says Thank You to Fuergrissa For This Useful Post:
humfrz (03-23-2018)
Old 03-23-2018, 08:53 PM   #6
I'll summon ol @Ultramaroon ...... one of out transmission experts, to see if he has any input.
Old 03-23-2018, 09:19 PM   #7
EndlessAzure
Wheels for Brains
I did the work.
Thanks
Ah, gotcha.
I have a similar issue when I lug the engine between 1k and 2.2k as well as when I'm engine braking from 2.6k down to 2k.
However, I changed my clutch and flywheel plus added a transmission bushing.
I'll keep an eye on on this thread too.
Old 03-23-2018, 10:07 PM   #8
Do you hear it, feel it, or both?
How did you support the engine?
Old 03-25-2018, 08:20 AM   #9
EndlessAzure
Wheels for Brains
For my part, a little bit of both.
I don't recall supporting the forward part of the engine during the process
Old 03-25-2018, 10:19 AM   #10
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Dont assume its driveline. Low RPM vibrations are often an indication of an engine problem.
guybo is offline   Reply With Quote
Old 03-25-2018, 01:58 PM   #11
The engine and transmission together balance on the engine mounts. When separated the engine will flop forward pretty hard. If you didn't support it, the exhaust pipe must have kept things in place. Perhaps a heat shield was bent then? Also, the engine bottom cover can make a hell of a racket if the screws back out. Once they've been removed, it seems like they don't like to stay tight. I use blue loctite on them.
Just a couple ideas. Try to record it for us. It might help.
EndlessAzure (03-26-2018), humfrz (03-25-2018)
Old 03-26-2018, 11:00 AM   #12
EndlessAzure
Wheels for Brains
I'll try to get a recording this week.
I didn't remove the front aluminum undertray/shield so the engine may have had some minimal support during tbe process.
The Following User Says Thank You to EndlessAzure For This Useful Post:
Ultramaroon (03-26-2018)
Old 03-26-2018, 01:03 PM   #13
ermax
ermax's Avatar
When I did my TOB I didn't support the front on the way off and spent almost 2 hours trying to get it off the lower studs. It wasn't until I said fuck it and pushed the jack aside and man handled it (not a good idea) that it came off. Once it was finally off I realized how far forward the engine tips which explained my difficulty getting it off. I supported the engine before putting it back on and WOW what a difference. I jacked it up enough and get it on the lower studs and then a single gentle push of the jack and the thing went right on. I could kick myself in the ass for skipping the front engine support.
Anyways, I feel sorry for anyone who does that job without jacking the front of the engine.
Old 03-26-2018, 01:17 PM   #14
After I get the back of the transmission separated, I wrap around the front of the engine and tie to the tower braces with a big fucking strap.
Not accelerating Fresh31 Issues | Warranty | Recalls / TSB 15 03-17-2018 05:05 PM
Please help.. Car not accelerating Joseph Issues | Warranty | Recalls / TSB 9 09-08-2015 11:55 AM
What driveline bushings would you replace first? Shady195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 07-02-2015 12:57 PM
Driveline Defect skoodge Issues | Warranty | Recalls / TSB 0 01-18-2013 12:16 AM
The BRZ / FR-S / GT 86 transmissions and driveline: what we know so far jruhi4 Engine, Exhaust, Transmission 25 02-17-2012 03:33 PM
