Old 03-19-2018, 11:05 PM   #1
Dee
Drives: 2014 Asphalt FRS
Getting rear camber to 0
Sorry for multiple posts I’m trying to tune my suspension where I want it.
So I am on coilovers, 1.75” lowered. I also have SPC LCA’s. I’m wanting to get my rear camber as close to 0 as possible (-1 is fine). I’m currently sitting at -2.1* on each side.
This is what alignment tech said:
Left rear I could get to -1.3*, but right could only get as low as -2.1* camber. So I had to match them up at -2.1*.
If you want any closer to 0, you’ll have to get upper control arms.
So.. after some research upper control arms look to be about 500$, and i’ve heard install is a PITA. Should I just raise my car up a fair amount? Are there any other parts I could look at getting?
Dee is offline   Reply With Quote
Old 03-19-2018, 11:45 PM   #2
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
I believe you can get different lower control arms. SPC using a bushing style adjustment for camber. SPL control arms for example, use a rod end that can give much greater adjustment.
Barefootdan is offline   Reply With Quote
Old 03-19-2018, 11:48 PM   #3
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
You should be able to get close to -1 with that drop and SPC arms. I'm not sure your tech knows what he's doing if he can only get -2.1. At worst, if your arms can't make it into spec you could try a different lca that doesn't utilize an oblong bolt for adjustment such as Stance, Velox, etc.
tyler_win_photo is offline   Reply With Quote
Old 03-20-2018, 02:11 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
When/if fitting SPC arms, don't use their toe-kit, if you want 0 to -1 camber imho. One may need to run higher camber with using it, while still having reasonable toe settings.
Old 03-20-2018, 05:54 AM   #5
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I did not use the toe bushings and got something like .05 toe in and -1 degree rear camber, but I have room to spare on that oblong washer if I want to reduce camber even more. One thing I have found though with alignment techs- they hate camber bolts, oblong washers etc- any of that. They want to do stock suspensions on stock settings all day and that's it. Slip them a $20 and they will try that little bit harder though.
*note- I'm not lowered
guybo is offline   Reply With Quote
Old 03-20-2018, 07:52 AM   #6
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
I was at -2.2 max i could get positive with my spc arms. Installed spc toe arms now I'm at -1.0 in the rear and can get more positive if I wanted. No rubbing issues, but I also have rolled out my fenders.
SPC Rear Lower Control Arms
SPC Rear Toe Arms
Enkei RPF1 17x9
Firestone Firehawk Indy 500 255/40/17
Tein Flex Z Coilovers (Lowered around 2 inches)
malubawla is offline   Reply With Quote
Old 03-20-2018, 09:46 AM   #7
Dee
SPC Rear Toe Arms
Enkei RPF1 17x9
Whaaaat? You’re probably a quarter inch lower than me and can get -1.0? That doesn’t make a whole lotta sense. I’m looking at getting stance lca, but before I do that I will raise my car some, or try another alignment tech.
Also I did slide my tech a 20$ and request my rear to be low as possible
Old 03-20-2018, 10:07 AM   #8
Icecreamtruk
Drives: Track preped NA FRS
But here is the better question, why do you want 0 camber?
Icecreamtruk is offline   Reply With Quote
The Following 5 Users Say Thank You to Icecreamtruk For This Useful Post:
Leonardo (03-20-2018), Lust (03-20-2018), Spuds (03-20-2018), strat61caster (03-20-2018), ZDan (03-20-2018)
Old 03-20-2018, 10:18 AM   #9
Dee
More oversteer setup(drift),lots of camber up front. Little as possible camber in rear
The Following User Says Thank You to Dee For This Useful Post:
Icecreamtruk (03-20-2018)
Old 03-20-2018, 10:36 AM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
More oversteer, drift .. you may try slight toe-out & less grippy (narrower & higher threadwear & higher air pressures) tires too.
Old 03-20-2018, 02:24 PM   #11
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
RacerX upper control arms should lose some weight and allow you to push out the top of the wheel pretty easily.
B T is offline   Reply With Quote
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
Does toe affect camber in the rear? More camber on one side after alignment shattered_memory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-30-2014 09:37 AM
WTB rear Camber kit ethanzhang Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-21-2014 09:26 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
