Old 07-10-2012, 12:28 AM   #15
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
Originally Posted by V1B View Post
Wow this one sounds pretty damn good!!!
Is this one axle back or full system?
I realy want something nice deep and agresive sounding
SRT's is header-back:
http://www.ft86club.com/forums/showthread.php?t=9372
denkigrve is offline   Reply With Quote
Old 07-10-2012, 12:36 AM   #16
Thunderchicken
Drives: 2008 STi
just quick question. how can we achieve the subaru boxer engine sound?
straight pipe probably will not do it huh? need headers w/o the cats ?
The only way to get the Subaru Turbo rumble is to have unequal length headers.
FYI not go in this type of application, but it's great for single scroll turbo's.
Thunderchicken is offline   Reply With Quote
The Following User Says Thank You to Thunderchicken For This Useful Post:
Sportsguy83 (07-10-2012)
Old 07-10-2012, 12:44 AM   #17
V1B
V1B's Avatar
Drives: Scion FRS
V1B is offline   Reply With Quote
Old 07-10-2012, 02:53 AM   #18
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Like this:
[ame="http://www.youtube.com/watch?v=WCI5Rf2bXsg"]TOYOTA 86&SUBARU BRZ  AUTO FACTORY オリジナルエã‚*マニ & Muffler sound FUJI - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=d-xlg_HI4cA"]TOYOTA86&SUBARU BRZ  AUTO FACTORY オリジナルエã‚*マニ&Exhaust Muffler  FUJI - YouTube[/ame]
http://www.ft86club.com/forums/showthread.php?t=5947
Vracer111 is offline   Reply With Quote
Old 07-10-2012, 03:38 AM   #19
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Spaceywilly View Post
Equal length makes more HP. The only reason WRX uses UEL is because it is better packaging for the turbo. Here is a good video showing UEL sound vs. EL sound
AFAIK, the OP is asking for the "burble" Boxer sound. That has been best explained by Spacewilly's video (the first run when it says header is stock).
All other videos with BRZ exhaust has shown beautifull note and growl (especially Auto Factory!) but none will sound with the Boxer "Burble" because headers are equal lenght.
Old 07-10-2012, 05:41 AM   #20
TOMIMOTO
TOMIMOTO's Avatar
Drives: MY00 Impreza 2.5RS
The turbo adds a lot to the sound too.
I have unequal length on my 2.5 na Impreza. It sounds great, but it's definitely missing the throaty burble the turbo brings to the party.
TOMIMOTO is offline   Reply With Quote
Old 07-10-2012, 08:21 AM   #21
wcbjr
Drives: 2006 Subaru LGT
Originally Posted by RWD-boxer View Post
Remove you muffler and you will have the rumble.
No, you will not.
wcbjr is offline   Reply With Quote
Old 07-10-2012, 08:23 AM   #22
wcbjr
It works with single-scrolls, or any-scrolls for that matter. But equal length is always better.
Old 07-10-2012, 08:46 AM   #23
Exhaust
UCanThrottleMyBody
Exhaust's Avatar
Drives: 2015 GM 370z Sport
honestly its not even worth it.
Exhaust is offline   Reply With Quote
Old 07-10-2012, 10:35 AM   #24
V1B
V1B's Avatar
Drives: Scion FRS
Great info guys .
Old 07-11-2012, 09:47 AM   #25
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
It's less about primary length than it is how adjacent cylinders are connected. Flat fours fire cylinders on the same bank sequentially.
As you're looking down on the engine, the cylinders are numbered like this:
4 3
2 1
Firing order is 1-3-2-4. What that means is that you get two pulses close together in each exhaust 'side'. If you have a 4>1 header and it's equal-length, then all four-cylinder engines will sound the same. If you have manifolds where each bank dumps together then combines with the other bank, you get the other extreme - the VW Beetle cadence.
The turbo Subs are somewhere in between - they have individual tubing for each cylinder but since they're not equal length, you'll get the burble. But the intensity will vary depending upon engine speed, since at some speeds the pulses will combine and at others they'll be spaced apart.
FWIW this is why "American" V8s sound different than, say, Ferraris. Most V8s have a firing sequence where two cylinders on the same bank fire sequentially. This results in a bigger 'bang' in the exhaust, so you get "bang bang BANG bang bang BANG"...which is why there's a similarity between that sound and a two-cylinder - you hear two of the firing events much more prominently.
Ferrari V8s (and some others) fire in an alternating fashion, so the sound is more uniform and much less distinctive.
This is also why V8s use bigger exhaust tubing and crossover pipes - you have to design the system for the 'big' pulses. Fours (inline anyway), fives, and sixes don't need nearly as much cross-sectional flow area for a given displacement/RPM.
Back to the Toyobaru, near as I can tell the header is not only equal-length or close to it, but it's also a triple Y that joins the non-adjacent cylinders...so it'll really be tough to make it sound like a traditional flat four without replacing the headers.
Admiral Ballsy is offline   Reply With Quote
The Following 5 Users Say Thank You to Admiral Ballsy For This Useful Post:
cobrabyte (07-11-2012), dabocx (07-11-2012), mike2100 (07-11-2012), Symbiont (07-11-2012), Zach (09-03-2012)
Old 07-13-2012, 07:03 AM   #26
RWD-boxer
RWD-boxer's Avatar
Drives: Black
Originally Posted by wcbjr View Post
No, you will not.
3k you can hear the rumble for free
RWD-boxer is offline   Reply With Quote
Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 113 11-21-2020 01:02 PM
How to get that boxer rumble? ryude Engine, Exhaust, Transmission 45 03-20-2014 02:30 PM
Rumble coming from rear end? No Quarter Scion FR-S / Toyota 86 GT86 General Forum 34 06-27-2012 02:14 PM
Subaru BRZ vinyl wrapped MATTE WHITE , Showing @ Subaru Summer Solstice 2012 Premium Auto Styling Southern California 2 06-22-2012 07:34 PM
Subaru/Toyota Coupe spotted in Socal with Subaru Plates owsiu Scion FR-S / Toyota 86 GT86 General Forum 150 05-25-2011 10:27 PM
