Old 03-14-2018, 06:25 PM   #15
Racecomp Engineering
doublepost
Old 03-14-2018, 06:25 PM   #16
Toe arms are useful to make toe adjustment easier, stay true, and can give you a firmer bushing in a crucial location. The extra range isn't needed for most people, but IMO replacing the arms is worthwhile if you track the car and/or use sticky tires. I recommend an arm that comes with a lockout for the OEM eccentric.
For a fun street car, the Whiteline LCAs work well at a good price.
- Andrew
Old 03-14-2018, 06:41 PM   #17
Kordless
Drives: '13 BRZ Limited
Originally Posted by norcalpb View Post
The expensive LCAs use a pillow ball bushing where they connect to the frame, but are typically much harder to adjust (more expensive alignment at least at my shop).
My SPL uses a magnificent spherical bushing
2019 Mazda MX-5 RF
2013 Subaru BRZ - SOLD
Instagram - @uwuboiz
Kordless is offline   Reply With Quote
Old 03-15-2018, 02:30 AM   #18
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
LCA's yes. Toe arms I would hold off unless you can't bring it back to spec. Strangely enough when I had my car lowered 2" I didn't need toe arms, but when I raised the car a bit so the drop was about 1" I ended up needing toe arms. Right rear toe was stuck out -0.36 degrees for some odd reason.
tyler_win_photo is offline   Reply With Quote
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 01:09 PM
FREE Shipping: ISC N1 Coilovers: ST Coilovers in stock at B2autodesigns b2autodesigns Brakes, Suspension, Chassis 177 02-09-2015 12:34 PM
WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers ProjectBrz Brakes, Suspension, Chassis 1 04-15-2014 01:21 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 09:56 PM
FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers ill roller Brakes, Suspension, Chassis 5 12-14-2013 04:02 PM
