Old 03-12-2018, 07:18 PM   #1
Greenbean
Drives: 2017 series yellow BRZ
Coilovers and LCA's
Im sure this is answered someone but if someone can give me an answer I will appreciate it. I ordered some fortune auto 500 coilovers and I was wondering do i HAVE to get toe arms and LCA's or will the camber and toe be relatively the same after installation. I will be getting an alignment after i receive them and install. I think im going to do around a 1 inch drop or maybe a 1.5. Please help thanks.
Greenbean is offline   Reply With Quote
Old 03-12-2018, 07:53 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Lowering car will increase negative camber. To not fsck up geometry and not rise need to buy many more parts to workaround/fix, suggesting to keep lowering within 1".
The Following User Says Thank You to churchx For This Useful Post:
Greenbean (03-12-2018)
Old 03-12-2018, 07:54 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
At that much drop you will end up with a little over -2 degrees in the rear. If that is acceptable to you then you should be okay. I bought toe arms and LCAs and set my toe arms to the same length as my factory ones and it was close in the rear so it may have been okay without them. I am a little over 1.5 inches of drop.
Old 03-12-2018, 08:04 PM   #4
Greenbean
Ill install my coilovers and get the alignment bc it will not be off so bad to the point of hurting DD but if it is does NEED adjusting I will buy toe arms and LCA.
Old 03-12-2018, 09:47 PM   #5
Lust
Drives: 2017 Subaru BRZ
If you have the money for the LCA and toe arms I say get them. You'll be able to get the camber and toe dialed in exactly how you want vs. whatever natural camber you get from lowering. If you want to just DD with a 1" drop, LCAs and toe arms are not needed.
Lust is offline   Reply With Quote
Old 03-13-2018, 11:07 AM   #6
JustSomeGuy
A Nobody
JustSomeGuy's Avatar
Drives: FRS
got any pics? im leaning towards the same setup as you
but my opinion (and what i may do) is lowering it then seeing how awful/good it really is before deciding if i should get the extra components..unless you just have the money to get it all at once then do that lol
JustSomeGuy is offline   Reply With Quote
Old 03-13-2018, 12:47 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
https://photos.app.goo.gl/9laqPsBma9D3WMM53
The Following User Says Thank You to NoHaveMSG For This Useful Post:
JustSomeGuy (03-13-2018)
Old 03-13-2018, 01:01 PM   #8
markitect
Drives: Scion FRS
I'm running fortune auto 500 coilovers, with spc rear LCA, dropped 3/4 in. Everything aligned how I wanted no problem, without using the special TOE bushings. There is also spare room both directions on the camber adjustment in the front. But the drop height is the relevant factor here, so look for others with the height drop you want.
markitect is offline   Reply With Quote
Old 03-13-2018, 03:49 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Height and camber make a difference. The toe arm mounts to the top of the rear hub/spindle assembly, so rocking the spindle in or out(camber) will change toe. If you go with a ton of drop with camber correction you can run out of adjustment on the factory toe arms. On the front the tie rods mount low on the spindle so the effect is not as great, but is still there.
The only reason I bothered to run LCAs and toe arms is I track my car and wanted to make sure I could dial it in exactly as I wanted.
Old 03-13-2018, 04:51 PM   #10
strat61caster
strat61caster's Avatar
As long as you're not going hellaflush the factory toe adjustment is perfectly fine.
ineedyourdiddly
Old 03-14-2018, 04:13 PM   #11
Greenbean
LCA's and Toe arms
What LCA's are the best bang for my buck. Money isnt a huge problem but dont wanna buy something overly expensive. I know SPC has a LCA and toe arm kit for 220 but heard mixed opinions on quality as this car is a weekend warrior and might see a track once maybe twice a year where is my best bet?
Old 03-14-2018, 04:32 PM   #12
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
SPC is fine.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 03-14-2018, 04:37 PM   #13
norcalpb
norcalpb's Avatar
The expensive LCAs use a pillow ball bushing where they connect to the frame, but are typically much harder to adjust (more expensive alignment at least at my shop).
Can’t go wrong with the SPC, but I like the white lines which are actually the same thing but silver and use a poly bushing instead of SPCs fake pillow ball bushing.
Whitelines for $198 shipped
https://m.ebay.com/itm/Whiteline-Adj...IAAOSwB09YJQ5G
Forget the toe kit, the 86 lateral links have tons of adjustment.
Old 03-14-2018, 04:50 PM   #14
fika84
fika84's Avatar
I've used SPC's on track occasions as well with no issues.
fika84 is offline   Reply With Quote
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
FREE Shipping: ISC N1 Coilovers: ST Coilovers in stock at B2autodesigns b2autodesigns Brakes, Suspension, Chassis 177 02-09-2015 11:34 AM
WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers ProjectBrz Brakes, Suspension, Chassis 1 04-15-2014 12:21 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 08:56 PM
FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers ill roller Brakes, Suspension, Chassis 5 12-14-2013 03:02 PM
