Drives: none
Lug nut question
I just bought ARP wheel studs (same length as OEM) and now I need to buy lug nuts, but I'm a bit confused about how to proceed, even after reading other threads about similar topics.
I track and autocross the car about once a month each. I have the stock wheels. I'd prefer lug nuts that don't require a key and that have closed ends. I like the price of Gorilla brand, but they only seem to sell lug nuts that require a key. Can you guys recommend some other, reasonably priced options? Questions: 1. As long as I find the correct size, M12X1.25, and they are conical and the right length, any brand's lug nuts should fit, right? 2. Is there a minimum length requirement, to ensure enough of the stud is secure? 3. In a pinch, can I use the OEM ones? Thanks! |
#2 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Get some closed end Mutekis and call it good.
If the studs are stock legnth any aftermarket should work given the correct specs you stated. The limit on the OEM lugs are if you wheels require a small diameter tuner lug and the OEM are too wide. If they fit diameter wise they should work too. You need at least 6 full turns to be safe from what I read a while back when I put spacers on another car. |
#3 | |
[insert cool phrase here]
Drives: BRZ Premium
2.yes. Try to stick to oem length. There a whole mathematical equation on minimal thread holding power. A quick glance from my machinist handbook 3/4" is enough for most applications. Don't forget to properly torque them. 3.yes. Not sure why would you not? Unless they don't fit your wheels, or just want new bling lug nuts. I been using some cheap-o $25 chrome lug nuts on my MR2 Turbo from O'reillys. They seen years of autox and track days and they are still good. But eh, that's just me.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | strat61caster (03-13-2018) |
#4 |
Drives: Track preped NA FRS
A recommendation that I never see made (on the contrary, some people recommend against it) is to get aluminium lug nuts and have a spare set if you are swapping wheels often. People will tell you all about the horrors of how aluminium nuts are not as strong as steel or chromology ones and bla bla bla. Those are the same people that when they crossthread a lugnut they break the stud, and need to limp home on 4 or less studs on a hub or on the bed of a tow truck. When you crossthread an alumunium lug nut, for one, you feel it right away (as it feels it doesnt tighten) and you also just take it out, throw it on the trash and put a new one in, your studs will not suffer from it. I put on and take my wheels 2 to 4 times per track day, and do around 15 track days per year. I have been tracked for 4 years and have yet to break a stud. You do you, thats my $0.02
| The Following 2 Users Say Thank You to Icecreamtruk For This Useful Post: | Code Monkey (03-14-2018), CSG Mike (03-13-2018) |
#5 |
Ive had the same set of Muteki SR48(open end lug nuts since 2013). Best value in lugs, IMO. Car is tracked and autox'd regularly, and I have 4 sets of wheels for it.
#6 |
Drives: '13 FRS - STX
Yeah, don't know why you wouldn't just use OE or something cheap off the shelf.
Keep the threads clean, never force them. I found a set of closed lugs with 3/4" hex for $15 on Amazon just now, I'm happy with my open end Gorillas (also 3/4" I didn't want to mess with a key either), if it weren't for the extended studs (shorter ones weren't available at the time and I've got spacers) I'd gladly save $50. Edit: Also summit racing has incredible filters for car parts... https://www.summitracing.com/search/...rder=Ascending |
#7 |
Drives: 2013 satin white brz limited
If your car is used in winter weather/salty climate (see your in california so doubt its much of a issue unless your right on the ocean front) I would avoid using open ended lugs. If not then w.e style fits your fancy. I run muteki SR48 open end lugs on my brz with the stock studs.
https://www.amazon.com/dp/B004QHMS5S...ding=UTF8&th=1 If your worried about your wheels being stolen then muteki also sells a wheel lock of the same style. https://www.amazon.com/Muteki-32901B..._&dpSrc=detail |
#8 | |
That being said, going super expensive gets you diminishing returns on quality. Got a color you happen to prefer? |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | cjd (03-13-2018), justint5387 (03-13-2018) |
#9 | |
Drives: none
So to summarize, I'd consider colored ones if they really wowed me, but otherwise, I am leaning towards cheapest and most functional for my driving style (mostly garaged except for driving to/from track and autocross 1-2 a month). Also, since only 1 lug nut is stripped, I was thinking to go to the dealer and just get a few replacements - I need to get this fixed by this weekend for an upcoming track day and this seems like quickest option. What is the material of the OEM nuts? Last edited by fiveoneoh; 03-14-2018 at 01:45 AM. Reason: more info |
#10 | |
Drives: none
What is the OEM length? Is it measured internally, from end to top of the cap? Or is it measured from the outside? Or is there a thread length value that I should be looking for that I can use to compare across different lug nuts (e.g., at least 1" of threads, or something like that) PS, love the machinist's handbook - it's like 4 years of engineering school crammed into 500 pages. <3 |
#11 |
Drives: BRZ 2017 Pure Red, MT
@CSG Mike
What's your opinion on steel vs aluminium for lug nuts? For daily(summer) + 12 autoX per year and maybe some HDPE? I swap wheels for each autoX. What's the disadvantage of going aluminium? Are they going to cross thread easily? OP: OEM nuts are steel. |
#12 |
Drives: Subaru BRZ
#13 |
I hit cones.
Drives: 2015 FRS
| The Following User Says Thank You to ein86 For This Useful Post: | Code Monkey (03-14-2018) |
#14 |
Drives: none
Cool, if the OEM nuts are steel, then I don't see why I should waste money on new ones. I'll swap out the studs and just replace the nuts that got damaged and call it a day! (Unless anyone has a compelling reason not to).
| Turn Signal Relay Question (Dumb Question) | Chimera | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 06-23-2017 01:58 AM |
| OFT QUESTION! | SlammedSilly | Software Tuning | 9 | 08-07-2015 03:40 PM |
| Question for you | omfg5041 | Engine, Exhaust, Transmission | 9 | 09-29-2014 09:56 PM |
| Question for the the 2014 Brz Nav Owners (BT Question) | jbsali | Electronics | Audio | NAV | Infotainment | 3 | 07-16-2014 11:41 AM |
| BEspoke question and rattle question | bdanisi | Electronics | Audio | NAV | Infotainment | 2 | 01-30-2013 02:11 PM |
