Old 09-29-2014, 07:12 PM   #1
omfg5041
Question for you
Hey all.
I have a quick question. I have about 700$ saved, and I am looking to do my first major mod.
I am looking at get an OpenFlash Tablet for the first mod, but I am having second thoughts wondering if it is the best option for my first major mod.
Other options I thought of were getting a used exhaust, or overpipe/front pipe.
Does anyone here have any other suggestions/opinions that may be helpful?
I am wanting to make a change to this car, and I know if I get an OFT, it will set me up in case I want to make a major upgrade on the car (i.e. headers)
Any thoughts/comments/input would be greatly appreciated.
omfg5041 is offline   Reply With Quote
Old 09-29-2014, 07:14 PM   #2
gramicci101
Off Topic
For $700, get an OFT, MTEC springs, transmission insert, rear diff outrigger inserts, and rear shifter bushing.
The Following User Says Thank You to gramicci101 For This Useful Post:
JohnJuan (09-29-2014)
Old 09-29-2014, 07:55 PM   #3
omfg5041
Thanks for the suggestions. Can you please explain why you would choose these mods?
Old 09-29-2014, 08:52 PM   #4
gramicci101
Off Topic
The OFT stage 1 is a definite improvement over stock.
The MTEC springs replace the springs that center the shifter. So now you'll have a much firmer and defined shifter, especially between 2-3 and 5-4.
The transmission insert fills the hole in the transmission bushing with a polyurethane insert, so the transmission flexes on its bushings less.
The rear diff inserts do the same thing, but for the rear diff. The OEM diff bushings let the diff flop around a lot; you can hear this when you shift, it makes a large clunk.
The rear shifter bushing replaces the soft OEM bushing with polyurethane.
The Following 3 Users Say Thank You to gramicci101 For This Useful Post:
Boofneenee (09-29-2014), JohnJuan (09-29-2014), omfg5041 (09-29-2014)
Old 09-29-2014, 09:11 PM   #5
omfg5041
Would the tune be worth it if I only have access to 91 Octane where I'm at? Is it going to improve the car even though I don't have access to E85 or 93 Octane?
The Following User Says Thank You to omfg5041 For This Useful Post:
Old 09-29-2014, 09:14 PM   #6
gramicci101
Off Topic
It will absolutely improve the car. I'm currently OFT Stg 1 on 91 octane, and it's a wonderful improvement over stock.
Plus, when it comes time to build your exhaust, you already have the OFT so you can flash Stg 2 right away.
Old 09-29-2014, 09:14 PM   #7
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Agreed. OFT Stage 1 followed by upgrade to the shifter (assuming your manual) maybe get a high flow filter too.
Your next mod should be a catless header and stage 2. Really helps fill the tq dp and increase high rpm HP.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 09-29-2014, 09:18 PM   #8
gramicci101
Off Topic
I love having the mods I listed. Aside from the OFT, they were all $50 or less, and they make such a huge improvement over factory. The drivetrain is firm and taut instead of loose and sloppy, and the shifter is precise and defined.
I just received RCE yellows from FT-86 SpeedFactory, so that, camber bolts, and steering rack bushings are all scheduled for my next install day.
Old 09-29-2014, 09:37 PM   #9
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
TURBOOO!!!
lol jk. Bushings bushings bushings. Its the little things that transform how the car feels when driven. Shifter bushings, transmission bushings, Diff bushings...
Id also say sway bars and springs, and eventually some sticker tires. OFT if you get their header and an exhaust to pair it with.
Old 09-29-2014, 09:56 PM   #10
omfg5041
Thank you for the input! I really appreciate it. I have ordered the parts, and cannot wait for them to arrive! Hopefully in time for shop day so I can put them in.
I do have a manual, and bushings are on the way. I cannot do a catless header because of silly annual inspections. There must be the same number of cats on the car in order to pass a Motor Vehicle Inspection. We do not (thankfully) have emissions testing.
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 11:41 AM
oft + ofh question frsqc Engine, Exhaust, Transmission 2 02-23-2014 10:21 AM
Question? FRSBRZGT86FAN Scion FR-S / Toyota 86 GT86 General Forum 10 07-09-2013 08:53 PM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 02:11 PM
BRZ Question geb2391 BRZ First-Gen (2012+) — General Topics 24 11-19-2012 10:49 AM
