CANADA Canada
Old 03-03-2018, 03:59 PM   #15
OrangeGuitar
OrangeGuitar's Avatar
Drives: '17 BRZ Dark Grey Sport-tech 6MT
Bone stock is fine for DD in terms of heat dissipation. Not sure what laughable means - the Forester plate does help with stabilization and does lower temps significantly on track and when running over 4K extended vs bone stock. That has been my experience and that of others but maybe you had different experience with it installed. The stock radiator is quite effective for NA. A full oil cooler will of course do more especially with FI. It will have more oil to heat on cold mornings in DD too.
OrangeGuitar is offline   Reply With Quote
Old 03-13-2018, 01:52 PM   #16
Thorpedo
The SquadWhisperer
I run one, street and lots of track. I have mine on a separate coolant loop with its own dedicated "radiator" and water pump. Works fantastic.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
The Following User Says Thank You to Thorpedo For This Useful Post:
7 skulls (03-13-2018)
Old 03-13-2018, 02:25 PM   #17
bad82
Drives: 17 BRZ PP,14 Juke Nismo RS AWD
Could you share some pics of your setup, that sounds like a solution that cuts no corners.
bad82 is offline   Reply With Quote
Old 03-13-2018, 02:40 PM   #18
7 skulls
Drives: 2014 scion frs
I thought about doing something like this a while back. So many questions Pics of your setup would be appreciated. Temp. data too.
7 skulls is offline   Reply With Quote
Old 03-13-2018, 03:57 PM   #19
Thorpedo
The SquadWhisperer
I've had it for years. I had everything from excel spreadsheets to line graphs on the improvement I logged but that laptop got stolen. I'll give you a rough outline from memory. I'll get pics when I have the chance.
It has a heater core out of a mid 80s crown vic mounted in the front passenger fog light grill (I cut it out and installed black wire mesh) I also cut a hole in the fender liner to give the airflow somewhere to go.
It uses a Bosch electric coolant pump out a 2004 ford mustang cobra (supercharged).
I used a power steering reservoir to hold the coolant / give a fill point. I just used heater hose to connect everything.
On a 30 degree (c) day i went from 270(f)+ oil temps at our local track to mid 230s running it very hard behind another car with the cooler on. My oil pressure still wasnt where i wanted it though so i ended up switching to 5w30. Sorry for switching units. Our track is pretty low speed so airflow is minimal. Highest speed I see is 160k/h on the back straight. On a higher speed course or with a front splitter I can see the added airflow making a larger improvement but I see 230 degree oil temps as more than acceptable for a good quality oil. I decided the problem was solved and shifted my focus elsewhere.
The Following 2 Users Say Thank You to Thorpedo For This Useful Post:
7 skulls (03-13-2018), scottman (03-13-2018)
Old 03-13-2018, 03:58 PM   #20
Thorpedo
The SquadWhisperer
Oh, and I'm NA.
Old 12-19-2019, 08:34 AM   #21
Petah78
Drives: 2022 BRZ sport-tech
Sorry to bump an old thread but do you have any pics of this setup? It sounds like an awesome idea.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
The Following User Says Thank You to Petah78 For This Useful Post:
7 skulls (12-19-2019)
Old 12-19-2019, 06:38 PM   #22
7 skulls
I'll second this. Pics and part numbers for that pump please.
Old 12-19-2019, 07:17 PM   #23
86MLR
86MLR's Avatar
Google > Bosch electric coolant pump out a 2004 ford mustang
There's like 1000
The Following User Says Thank You to 86MLR For This Useful Post:
Old 12-20-2019, 09:44 AM   #24
Petah78
There's like 1000
Thanks. It isn't just the coolant pump that I am interested in but rather the entire setup. This is an awesome idea because:
- You don't run the risk of oil leak or worst, blowing an oil line leading to catastrophic failure. Worse can happen is you have coolant leaks and run out of coolant, effectively no oil cooler. But factory oiling is retained with no chance of failure.
- You can wire an switch to the pump effectively turning the cooler on/off pending condition. Therefore, you can bypass over cooling for daily applications.
I suspect the power steering reservoir must be the highest point in the system in order to run an air free system? Essentially, you are building a liquid cooler that is found in gaming PCs these days.
Old 12-20-2019, 02:20 PM   #25
Jordanwolf
Rice King
Jordanwolf's Avatar
Yes, so much yes. I would much prefer this as well, but how feasible would a system like this be, especially in a track application. You'd think we'd have seen something like this already.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 12-20-2019, 02:45 PM   #26
Petah78
I agree hence I wanted more info about the setup. The poster of the idea claims that his oil temp went from 270f -> 230f after this install. I think it's believable because the coolant that is going through the factory coolant/oil exchanger will be ambient (95f on a hot day). I think one of the limiting factor to the using engine coolant is that it starts off already @ 194f hence there is only so much heat it can extract. But if you are talking about ambient, I can see the effects being far greater.
Forrester XT Style "OEM" Oil Cooler SpectreRT Engine, Exhaust, Bolt-Ons 5 09-26-2017 11:35 AM
WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler TheMedakaBox Northern California 4 08-09-2017 10:16 PM
2013 Subaru Forrester speeddemon Other Vehicles & General Automotive Discussions 0 01-31-2017 11:16 AM
Forrester XT cams FAER Forced Induction 7 05-14-2014 03:55 PM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
