CANADA Canada
Old 02-22-2018, 05:45 PM   #1
oppiee
Drives: 2014 Scion FRS (Red)
Forrester Oil cooler
Hey guys,
do you have any recommendations on where to get forrester oil cooler that would fit on the frs?
Somewhere that isnt too pricy, in canada?
Thanks!
oppiee is offline   Reply With Quote
Old 02-22-2018, 07:05 PM   #2
scottman
scottman's Avatar
Drives: 13 mt fr-s
From a subaru dealership, really.
As well as it isn't a very effective method of cooling oil.
Save a couple more hundred and get a thermostatically controlled sandwich plate and cooler.
And if it's the oil warming feature you wanted, take off your exhaust manifold heat shielding.
scottman is offline   Reply With Quote
The Following User Says Thank You to scottman For This Useful Post:
OrangeGuitar (02-23-2018)
Old 02-23-2018, 04:35 AM   #3
OrangeGuitar
OrangeGuitar's Avatar
Drives: '17 BRZ Dark Grey Sport-tech 6MT
21317AA070 CONN-OIL COO $48.73
21311AA170 OIL COOLER C $ 186.48
Prices are CDN from a couple of years ago
You also need some loose ends as per
http://www.ft86club.com/forums/showthread.php?t=73684
OrangeGuitar is offline   Reply With Quote
Old 02-28-2018, 09:14 AM   #4
oppiee
I thought it also helps keep the temps down during tracking? Or is getting an aftermarket better?
Old 02-28-2018, 09:17 AM   #5
OrangeGuitar
It does effectively keep high oil temp lower and low oil temp higher. If you have a turbo or SC, get a separate oil cooler.
Old 02-28-2018, 11:31 AM   #6
wparsons
wparsons's Avatar
A good air/oil cooler will do a much better job for track use. I know a couple people that had the OEM forester setup and moved to an air/oil setup.
Get a thermostatic plate if you drive the car year round and you'll be fine.
flickr
Old 03-01-2018, 03:42 PM   #7
oppiee
My car is not boosted. I guess i was looking at the oem setup because it looks fuss free lol!
Old 03-01-2018, 04:14 PM   #8
OrangeGuitar
It is effective and simple to install. A dedicated oil cooler is even more effective but much more fuss.
Old 03-01-2018, 04:37 PM   #9
wparsons
wparsons's Avatar
I'm not sure the forester one is less fuss... you don't have to remove the bumper, but do have to install new lines. It took me about two hours, working very slowly, to install my mishimoto cooler.
Included in that time was me poking around to see how easily I could run brake ducts while the bumper was already off.
flickr
Old 03-01-2018, 04:53 PM   #10
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
Explain more fuss? Genuine question.
The way I look at it from a holistic point of view and not a detailed step by step, you still need to:
1- Tap into line/reservoir for inlet/outlet
2- Mount new cooler somewhere
3- Bleed and purge air
I don't see how a Forrester one would be easier unless it literally bolts on and eliminates the mounting part.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 03-01-2018, 05:04 PM   #11
OrangeGuitar
The forester cooler sits under the oil filter as a sandwich plate (mmm sandwich...). There is nothing to mount in another location. Coolant hoses do have to be run. Oil management remains the same as stock. The install is quick. External oil coolers still have a place.
The Following User Says Thank You to OrangeGuitar For This Useful Post:
Frost (03-02-2018)
Old 03-01-2018, 09:24 PM   #12
oppiee
so verdict: oem is fine for mild tracking?
money better spent on aftermarket ones for heavy tracking?
The Following User Says Thank You to oppiee For This Useful Post:
OrangeGuitar (03-01-2018)
Old 03-03-2018, 01:56 PM   #13
wparsons
wparsons's Avatar
Anyone I know that had an OEM one for track use replaced it with an external one pretty quickly...
How often do you plan on tracking the car? How long of sessions do you want to run?
External ones still use a sandwich plate, so the oil portion is easy. You don't have to remove the bumper with the OEM one, but you do have to run coolant lines and purge the air from them. I'd bet install time is about the same for both.
flickr
Old 03-03-2018, 02:34 PM   #14
Ultramaroon
not playing cards
Ultramaroon's Avatar
The OEM-style is laughable. Nice for stabilizing temps when DDing but that's about it.
Even if cruising at partial throttle with a bone stock engine, a shit ton of heat gets dumped into the bottom end when operated continuously above 4K for any length of time.
Forrester XT Style "OEM" Oil Cooler SpectreRT Engine, Exhaust, Bolt-Ons 5 09-26-2017 11:35 AM
WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler TheMedakaBox Northern California 4 08-09-2017 10:16 PM
2013 Subaru Forrester speeddemon Other Vehicles & General Automotive Discussions 0 01-31-2017 11:16 AM
Forrester XT cams FAER Forced Induction 7 05-14-2014 03:55 PM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
