Old 03-07-2018, 12:47 PM   #1
Tristor
Tristor's Avatar
Recommended Track Wheels?
Howdy,
I've got a set of beautiful forged monoblock wheels for cruising around town and going to car meets showing up, but I'm looking to acquire another set of wheels which are at much lower cost/easier to replace since I'm sure the track will end up defacing their appearance. What's the current recommendation for track wheels? Here's a few I'm considering for what will be 17x9s.
Enkei RPF1s
Gram Lights 57CR or 57DR
949 Racing 6UL
Wedssport TC105N
Any others I should be thinking of? At $800+ a pop, forged wheels are a bit pricey to beat to crap on the track, but I still want something that's going to be strong and lightweight.
Tristor is offline   Reply With Quote
Old 03-07-2018, 01:09 PM   #2
MRCA1ST
MRCA1ST's Avatar
Drives: 2013 WRB BRZ 6MT
RPF1 would be my choice for the track, I am not a huge fan of their looks but considering their weight and cost I think they are tough to beat for the sole purpose of track duty.
MRCA1ST is offline   Reply With Quote
The Following 2 Users Say Thank You to MRCA1ST For This Useful Post:
Tristor (03-08-2018), wparsons (03-08-2018)
Old 03-07-2018, 01:19 PM   #3
Lynxis
Lynxis's Avatar
Lots of options at that size/weight/price point. Apex ARC8 and Konig Hypergram are the first ones that come to my mind. If you don't mind importing from Canada, 720Form GTF1's are good.
Lynxis is offline   Reply With Quote
Old 03-07-2018, 01:30 PM   #4
Code Monkey
Drives: Subaru BRZ
Since you plan to upgrade to the AP Racing BBK, make sure the wheels will clear the calipers. This eliminates the 17x9 RPF1's for sure, 6UL fit for sure, and I think the WedsSports fit too.
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
Old 03-07-2018, 01:31 PM   #5
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
RPF1's, hate their looks but you can't beat them for weight and cost.
Lunatic is offline   Reply With Quote
Old 03-07-2018, 02:27 PM   #6
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Gram lights are the heaviest wheels on the list. The Wedsports are probably the lightest. A lot of forged wheels are roughly the same weight as the RPF1 or Wedsports. Very few are actually lighter.
tyler_win_photo is offline   Reply With Quote
The Following 2 Users Say Thank You to tyler_win_photo For This Useful Post:
Leonardo (03-07-2018), Tristor (03-08-2018)
Old 03-08-2018, 12:52 AM   #7
FirstWinter
Drives: Car
+1 for 949 6UL or TC105N
The 17x9 RPF1s simply don't clear that many BBKs. 6UL and TC105N are both a bit stronger as well.
FirstWinter is offline   Reply With Quote
The Following User Says Thank You to FirstWinter For This Useful Post:
Old 03-08-2018, 11:14 AM   #8
Racecomp Engineering
The TC105N are very light for the cost.
We just started carrying BRAID wheels. Not as light as some of the others, but not bad and extremely strong. Think tarmac rally wheel. Any size/offset with excellent brake clearance.
http://www.ft86club.com/forums/showthread.php?t=125709
- Andrew
Old 03-08-2018, 11:50 AM   #9
jmark
Drives: '97 NSX-T, '18 Type R
http://www.ft86club.com/forums/showthread.php?t=124967 They clear the PP Brembos as well. They are proven on track too.
jmark is offline   Reply With Quote
The Following User Says Thank You to jmark For This Useful Post:
Old 03-08-2018, 12:31 PM   #10
Tristor
Tristor's Avatar
Looks like I just missed the group buy, but those look excellent. They clear the AP Sprint Kit + have exact correct center bore and hubcap fitment, and are offset to be a flush fit to the fenders. Really nice.
Old 03-08-2018, 01:20 PM   #11
wparsons
wparsons's Avatar
The 17x9 +35's clear the AP sprint kit (barely), but not the +45's. You'd want the +35's anyway since the +45's might rub on the inside and give you no clearance to add camber at the knuckle.
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
Code Monkey (03-08-2018), G-Man (03-08-2018), Tristor (03-08-2018)
Old 03-08-2018, 01:33 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
With 17X9 +38 57DR's I had no room to add camber at the knuckle with 245 RS3's. With camber bolts maxed out tire would rub the spring perch under hard cornering. Just an FYI to all.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Tristor (03-08-2018), wparsons (03-09-2018)
Old 03-10-2018, 07:32 AM   #13
jmark
http://www.ft86club.com/forums/showthread.php?t=125888
Recommended trans and diff oil for track Elliotw Tracking / Autocross / HPDE / Drifting 3 02-12-2018 10:27 PM
Recommended floor jack for a lowered BRZ that can easily be transported to the track? Pat Tracking / Autocross / HPDE / Drifting 13 01-09-2017 08:25 PM
Tire Pressure and Temperature Gauges recommended for track use Toyarzee Tracking / Autocross / HPDE / Drifting 16 01-26-2016 08:23 PM
Any Track day recommended for a track noobie near NY area? Imsteak Tracking / Autocross / HPDE / Drifting 4 04-04-2014 07:13 PM
Recommended Tire Pressure for Aftermarket Wheels and Tires Chri5 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-15-2013 01:28 PM
