Old 03-04-2018, 01:39 PM   #3697
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by Rohint75 View Post
Someone local is selling enkei nt03 18x9.5 +40 with 255/35/18 tires. Will these fit stock suspension with spacers?
Read post 213 and 214.
http://www.ft86club.com/forums/showt...=28017&page=16
Read page one of the Meaty tire thread.
http://www.ft86club.com/forums/showthread.php?t=41083
I LIKE TIRES!
Old 03-05-2018, 07:32 PM   #3698
norcalpb
norcalpb's Avatar
I have enkei rpf1 17x9 +35 on RCE lowering springs, bilstein b6, camber plates, and stock crash bolts.
I am soon going to get the Federal RSRR tires. They only come in 235 or 255 and I know they run a size wider than normal. Would 255 rub on my lowering springs?
And if 235 is the way, then should I get 235/40/17, or 235/45/17?
TIA
Old 03-06-2018, 07:39 AM   #3699
The owl Talon
Ok, so I plan on buying some Motegi MR127's. I want to double check that everything would work on stock FR-S and not have fitment issues, and how flush it would be. Its the Motegi Racing MR127 Satin Black Wheel (18x8"/5x100mm, +38mm offset). Also since this is my first time buying new wheels for my FR-S is there anything else that I should purchase along side of the wheels and tires (probably gonna be 225/40R18W)
The owl Talon is offline   Reply With Quote
Old 03-06-2018, 09:49 AM   #3700
Vital
Drives: 2015 BRZ
Yes, that will be fit fine on stock suspension just keep in mind it might poke a little bit in the front. You may want to get hub-centric rings and make sure you get correct size aftermarket lug nuts (M12x1.25). Also, you will need TPMS sensors so you dont get the TPMS light on your dash depending on where you go to get your wheel and tires mounted they might just swap the OEM sensors to your new wheels.
The Following 2 Users Say Thank You to Vital For This Useful Post:
Leonardo (03-06-2018), Tristor (03-06-2018)
Old 03-06-2018, 01:33 PM   #3701
Leonardo
Country Boy 4 Life
Leonardo's Avatar
TIA
It looks like 255/40/17 hankook RS-3's fit on 17x9 +35's with similar suspension parts.
Post #18
http://www.ft86club.com/forums/showt...=100400&page=2
I LIKE TIRES!
norcalpb (03-06-2018)
Old 03-06-2018, 04:48 PM   #3702
norcalpb
norcalpb's Avatar
Post #18
Hmm seems like he still rubber at full lock when reversing, I don’t rub at all anywhere (245/40/17 PSS) and I kinda wanna keep it that way so thank you for directing me to that link.
So getting 235s, will I need 235/40 or 235/45?
The Following User Says Thank You to norcalpb For This Useful Post:
Old 03-06-2018, 05:00 PM   #3703
Leonardo
Country Boy 4 Life
Leonardo's Avatar
235/40. 100%
I LIKE TIRES!
Old 03-13-2018, 03:30 PM   #3704
JustSomeGuy
A Nobody
JustSomeGuy's Avatar
Drives: FRS
dont know where to properly ask this dumb beginner question but if i lower my car on stock wheels, then get new ones will new wheels affect the camber? i have decided on what wheels but they would be wider and +35 offset range over stock but curious about lca
JustSomeGuy is offline   Reply With Quote
Old 03-13-2018, 03:38 PM   #3705
Kameron Aiken
Drives: 86
With the Rocket Bunny v1!
Front: Rim Specs
18x9.5 +30
25mm Spacer
2inch Drop
=18x9.5 +11mm
Rear:Rim Specs
18x10.5 +22
30mm Spacer
2inch Drop
=18x10.5 -6mm
Correct me if I’m wrong?
Kameron Aiken is offline   Reply With Quote
Old 03-13-2018, 04:03 PM   #3706
Leonardo
Country Boy 4 Life
Leonardo's Avatar
What wheels are you thinking? Lowering will change camber. Not wheels. Also, the more you lower, the more natural camber you will get. The car does not have adjustment stock. I'd suggest a set of camber bolts, the are easy to install and inexpensive.
I LIKE TIRES!
JustSomeGuy (03-14-2018)
Old 03-14-2018, 10:54 AM   #3707
JustSomeGuy
A Nobody
Drives: FRS
either 17x9 or 17x8 around 35 offset range. i guess i just wanted to know if i could get away with being lowered on stock wheels until the new ones came in with lca and decide then if it would be worth it but thanks
Old 03-14-2018, 12:34 PM   #3708
Leonardo
Country Boy 4 Life
Leonardo's Avatar
17x8 +35 is a perfect size. 17x9 +35 will work great too, but pokes some in the front.
I'd run 225/45 on the 17x8. 245/40 on the 17x9. LCA is not necessary, but camber bolts are for the front. Especially for 17x9 +35.
I LIKE TIRES!
Old 03-14-2018, 12:39 PM   #3709
JustSomeGuy
A Nobody
Drives: FRS
im not smart enough to figure this out but im curious about 17x8 +30.. is that close to how 17x9 +35 would sit? 17x8 does seem more appealing to me though and with the cheaper tire price it would be nice aha. i plan on getting camber bolts up front though but good to know i dont need lca.. but even if i go about 1.5" lower? natural should be fine for DD?
Old 03-14-2018, 12:48 PM   #3710
Leonardo
Country Boy 4 Life
Leonardo's Avatar
How are you lowering? How much camber do you want to run? 17x8 +30 will work with around -2 front camber.
IMHO, I can not suggest going lower than 1" on springs. But, that's how I roll.
I LIKE TIRES!
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
