Old 10-20-2016, 12:03 AM   #15
zmz0305
Drives: subaru brz
Originally Posted by Bagarre View Post
I find myself in the market for a screen.
Having trouble finding one online so I'm researching the specs to find an alternative.
Only the touch screen is damaged so I might try a new one of those from adafruit.
I find this one with very similar socket cables.
http://www.ebay.com/itm/Brand-New-3-...AAAOSw5VFWNp22
I also find the specific model in Chinese market. But shipping is gonna cost a fortune.
zmz0305 is offline   Reply With Quote
Old 10-20-2016, 09:50 AM   #16
Bagarre
Drives: 987.1 Boxster
After not being able to find the complete screen, I decided to go another route.
On mine, the display still works. Only the touch screen failed. They are two separate components attached with some adhesive.
Most all resistive touch screens are the same except for size so I worked it off with a razor and cleaned the surface with alcohol.
A quick search on ebay found a 3.5" touch screen measuring 77x64mm which is very close enough. Once it's on, the calibration process will fit it.
http://www.ebay.com/itm/152070987652
EDIT:
This looks like a direct replacement to the touch screen. I ordered both but Digi-Key will get here sooner.
https://www.digikey.com/product-deta....5Z-ND/2626417
In reality, you can use a larger screen as well since calibration will take care of matching pixels to values.
You need to make sure the plug is a 1mm pitch. A lot of them are 0.5mm pitch but there are adaptors and extensions out there as well.
The screen wont be here for a week or so. Will update more then.
https://goo.gl/photos/mJqGznKX7QpLkPh38
Bagarre is offline   Reply With Quote
Old 10-24-2016, 08:54 PM   #17
Bagarre
Fixed!
The screen at
Worked perfectly for $15.00 with shipping.
The adhesive is already around the edge so you just pull off the clear plastic and stick it down. The plug is in the right place but a little longer but doesnt affect anything.
A drop of glue on the old posts and it's done. I added a strip of foam around the outside.
Old 10-24-2016, 10:24 PM   #18
Subie_Nubie
Subie_Nubie's Avatar
Drives: 2013 Subaru BRZ Limted
The screen at
Awesome dude! Thanks for contributing more knowledge!
2013 SWP BRZ Limited // 6 MT // Grimmspeed Intake // Tomei Supreme UEL Header // OFT Stage 2, 93 Oct, UEL Tune // Enkei RPF1's // Borla Catback and Diffuser // Bilstein Shocks // Eibach Anti-Roll Kit // TRD Strut Bar
Subie_Nubie is offline   Reply With Quote
Old 12-02-2016, 12:45 AM   #19
ze12o
Drives: BRZ 2015 DGM
Just did this. I haven't been e85 in months! Took me two hours to flash back to 91 with a broken touch screen a while back.
You rock OP
ze12o is offline   Reply With Quote
Old 03-08-2017, 03:16 PM   #20
Subie_Nubie
Originally Posted by L8Apex View Post
Now my OFT is like new, except the bottom edge looks like it was chewed on by a gorilla, LOL.
Thanks again to everyone for sharing the knowledge!
Glad you were able to fix it dude. This is why I created this thread!
Old 05-12-2017, 02:30 PM   #21
Jon86Valdosta
Drives: 2016 WRB Subaru BRZ
Did you every try to pursue this route? I'm curious if this screen worked or if I still need to find another.
Jon86Valdosta is offline   Reply With Quote
Old 10-04-2017, 01:10 PM   #22
CSPTK
Drives: 2014 FR-S
Could someone who has done this shed some light on how the two outer case parts snap together? Maybe some close-up pics? Can the case be opened without breaking the tabs if you know where/how to pry?
Thanks!
CSPTK is offline   Reply With Quote
Old 10-04-2017, 02:26 PM   #23
steve99
Drives: FT86
Thanks!
no its a sealed unit ,not meant to be opened, you have to cut through those tabbs
Old 10-17-2017, 12:26 PM   #24
Chidow_21
Drives: 14 BRZ Limited
ISO a display screen. Can someone guide me where to find one? Thanks
Chidow_21 is offline   Reply With Quote
Old 10-19-2017, 09:45 AM   #25
bababooey
Drives: BRZ SWP Limited -6MT
links above?
bababooey is offline   Reply With Quote
Old 03-02-2018, 12:37 AM   #26
amaciose
amaciose's Avatar
Drives: 2013 BRZ Limited
Does anyone know if this would be a direct replacement? The model number is off by one character.
https://www.mouser.com/productdetail...iYaSfBKA%3D%3D
amaciose is offline   Reply With Quote
Old 03-02-2018, 07:54 AM   #27
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I've been asked a few times through PM's for the links to the replacement parts. It's easy to fix these, but you will beat up the case of your OFT quite a bit. Therre's no graceful way to crack open that clam case!
A very nice guy on FB gave me these links in October. I won't call him out, in case he wants to stay lurking, but if you are reading this, you're the best dude!
So heres The LCD
https://www.mouser.com/Search/m_Prod...68-UMSH8252MDT
You'll need The touch display as Well
https://www.digikey.com/product-deta...-5Z-ND/2626417
guybo is offline   Reply With Quote
Old 03-02-2018, 11:27 AM   #28
amaciose
amaciose's Avatar
Looks like those links are broken. I think these are the correct ones:
UMSH-8252MD-T
TS-TFT3.5Z
Header crack question alchemis Engine, Exhaust, Transmission 3 04-07-2016 03:36 AM
Crack in my headlight under warranty? FRSHunter Issues | Warranty | Recalls / TSB 3 07-23-2013 12:27 PM
T7019A HELP boot screen or splash screen change Trap63 Electronics | Audio | NAV | Infotainment 2 06-09-2013 05:04 PM
Crack in the glass.. Miss_Red Scion FR-S / Toyota 86 GT86 General Forum 54 02-27-2013 01:06 PM
