Old 07-23-2013, 02:08 AM   #1
FRSHunter
Drives: Asphalt FRS
Crack in my headlight under warranty?
I have a small crack actually inside my headlight. The outside has no cracks and is completely smooth. Not exactly sure how it got there, is this possible to get replaced by dealer under warranty? Headlights are bonestock, never had HID's, baked/cracked opened, etc.
FRSHunter is offline   Reply With Quote
Old 07-23-2013, 06:29 AM   #2
fistpoint
Drives: Supercharged Golf Cart
Why not try and report back with the answer? Example: I say "no, they won't fix it"...are you really going to not even try after hearing that?
Just be nice and ask as if you expect them not to rather than insisting they do. You can also go to another dealership and try again.
fistpoint is offline   Reply With Quote
Old 07-23-2013, 12:11 PM   #3
frslee
Just drive it
Drives: 13' FR-S
If it's inside and there is no sign of damage from outside, they might be able to replace it under warranty. However, if there is contact point with outer housing and finds slight impact, then the they'll turn on their back... Talk to them nicely.
frslee is offline   Reply With Quote
Old 07-23-2013, 12:27 PM   #4
Brently
Grey Wind
Brently's Avatar
Drives: FR-S 10 Series #0065
As aforementioned, if there is no sign of impact on the exterior, it will likely be replaced under warranty for you. I've had success getting a fog light replaced this way.
So, my grandma Reynolds was always saying 'when life gives you lemons, make lemonade.' I wish she was still alive, because I'd really like to ask her what she suggests for when life gives you Chlamydia.--Veronica Mars
Brently is offline   Reply With Quote
Adding Fog Lights + Headlight Stalk Replacement Void Warranty? JohnAyySays Issues | Warranty | Recalls / TSB 1 05-08-2013 09:07 PM
Crack in the glass.. Miss_Red Scion FR-S / Toyota 86 GT86 General Forum 54 02-27-2013 01:06 PM
Advice for this crack and scratch? noc Cosmetic Modification (Interior/Exterior/Lighting) 10 02-26-2013 07:43 PM
Window rubber crack after 1 month motofan Issues | Warranty | Recalls / TSB 16 09-28-2012 09:34 PM
Anybody crack open the oil filter yet? Bonburner Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-20-2012 02:42 PM
