Old 12-06-2017, 04:11 PM   #197
RallySTI
Drives: 2013 Subaru BRZ
Originally Posted by Surok View Post
im running this guy here.
http://www.xtremeclutch.co.uk/produc...3/KSU20526-2B/
Clamping Force 1000kg
Torque Rating 1200Nm
Bearing Contact Diameter 44-52mm
Bearing Load (@ 48mm) 218kg
Release Travel Required 6mm
Assembly Mass (without flywheel) 7.4kg
Disc Set Static Mass 2.15kg
Friction Thickness New 7mm (0.275")
Friction Thickness Worn 6.48mm (0.255")
sounds like im going to have to get one from you guys.
my clutch is an absolute c*nt to drive.
What do you think of that clutch ?
RallySTI is offline   Reply With Quote
Old 12-06-2017, 09:20 PM   #198
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
dont get it if your car isnt a toy. its a pain in the ass if you are ever in traffic.
its not an on/off light switch, you can slip it if you really need to , but you will smell the clutch if you try to drive it like a normal clutch. it likes when you are brutal to it.
but it sure handles the power alright!
im hoping the new clutch fork totally fixes the annoying problems and makes it more controllable.
i am at 331KW on a hub dyno. not sure how that relates to an american power level.
Surok is offline   Reply With Quote
The Following User Says Thank You to Surok For This Useful Post:
RallySTI (12-07-2017)
Old 12-06-2017, 10:13 PM   #199
Ashikabi
Ashikabi's Avatar
Just get fatter tires to reduce slippage when you dump the clutch
Old 02-28-2018, 09:45 PM   #200
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
We have not updated this thread in awhile but we have a new offering with the fork we are excited about. I know it is nothing revolutionary but we have now created an internal kit to offer with the clutch fork.
As some of you may know, Toyobaru issued a TSB for the TOB (throwout bearing). The grease within the TOB was found to be inadequate at dealing with the heat during operation, which causes premature failure. The Toyota/Scion TSB is S-SB-0012-17 if you would like to look it up.
Anyway, we now stock no less than 10 TOB and clips (shown below) that can be added on during checkout. https://www.verus-engineering.com/pr...30-clutch-fork
Happy motoring!
Thanks,
Eric
VerusEric is offline   Reply With Quote
The Following 4 Users Say Thank You to VerusEric For This Useful Post:
MCTeeJ (02-26-2020), sroby (07-20-2020), SuperTom (03-04-2020), x808drifter (02-28-2018)
Old 02-28-2018, 09:52 PM   #201
Ashikabi
Ashikabi's Avatar
Happy motoring!
Thanks,
Eric
Is this an oem clip you stock or one you guys devised with additional performance over OEM?
Old 02-28-2018, 09:54 PM   #202
VerusEric
VerusEric's Avatar
100% OEM components. OEM 2017+ TOB, OEM spring clips. We're just trying to make it easier to grab a full fix in one shot with one shipping.
Old 02-28-2018, 09:55 PM   #203
Ashikabi
Ashikabi's Avatar
Gotcha
Old 02-26-2020, 05:31 PM   #204
VerusEric
VerusEric's Avatar
This thread hasn't been bumped in a while and we feel this is a really important part to install during any clutch install. We have these in stock with standard 2-day shipping in the USA.
Old 02-26-2020, 09:17 PM   #205
Chuckls
Moutain Runner
Slated to be installed with your turbo kit!
Chuckls is offline   Reply With Quote
The Following User Says Thank You to Chuckls For This Useful Post:
VerusEric (02-26-2020)
Old 07-05-2021, 10:29 AM   #206
VerusEric
VerusEric's Avatar
Bump for anyone who hasn't seen this. This is one of our most popular items at this point and has helped a lot of owners maintain a more reliable car!
The Following 2 Users Say Thank You to VerusEric For This Useful Post:
Capt Spaulding (07-05-2021), Turdinator (07-05-2021)
Old 07-06-2021, 02:40 PM   #207
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Originally Posted by Drakiv View Post
Just a couple more people
I',m interested but have to replace TOB pretty soon so can't wait too long.
Qwimby1 is offline   Reply With Quote
Old 07-06-2021, 06:53 PM   #208
Olson1288
Olson1288's Avatar
Drives: 2014 DGM BRZ Turbo
Been using both the fork and the pivot in my turbo BRZ for almost 2 years now with no issues.
Olson1288 is offline   Reply With Quote
The Following User Says Thank You to Olson1288 For This Useful Post:
VerusEric (07-08-2021)
Old 07-07-2021, 04:01 AM   #209
mb_
Ex-MR2 owner
Drives: Scion FRS
My throwout bearing just went yesterday and ordered the fork and pivot ball today!
mb_ is offline   Reply With Quote
The Following User Says Thank You to mb_ For This Useful Post:
Old 07-07-2021, 02:26 PM   #210
Qwimby1
We'll start looking into doing the pivot as well, should be a relatively inexpensive piece in quantity. The forks will be coming out first though of course.
Units are nearing the finish line!
Thanks,
Eric
I just noted the date on this thread. I ordered the fork and pivot
from 86speed yesterday. Looks like they just sold out. Do you have any others ready to go?
Verus Engineering Brake Cooling Kit VerusEric Suspension | Chassis | Brakes -- Sponsored by 949 Racing 100 07-15-2023 11:18 PM
Modular Hood Louver Kit - Verus Engineering VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 276 07-08-2023 05:03 PM
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 10:15 AM
Verus Engineering Billet Transmission Beta Tester Run VerusEric Engine, Exhaust, Transmission 62 04-26-2020 02:44 PM
▀▄▀▄ Vivid Racing | Cusco 86/BRZ Clutch Release Fork and Pivot Set vividracing Transmission and Driveline 0 07-12-2016 02:32 PM
