#29 |
Drives: BRZ, STI, GT350R, Supra, 987.2
Final revision on the right below. Machinist told me he was going to cut it from both sides anyway, so I changed the design a bit to be a little nicer looking and easier to install.
![]() ![]() We're looking at about a month for production units to be machined, coated, and ready for sale. Thanks, Eric Last edited by VerusEric; 08-29-2017 at 04:52 PM. |
#30 |
Drives: 2016 Scion FR-S
Put me on the list please!
#31 | |
Project Shadow
Drives: 2015 BRZ Limited 6MT
![]() ![]() I'm just hoping I can pick up a unit before June 13 so I can have them install it with my gear set and clutch.
#32 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Wow just saw this. I'd be interested in this since I may be upgrading my clutch by the end of the year.
#34 |
Snagged a few photos from my machinist on the first article that is headed to me.
![]() ![]() ![]() We will test fit it once we receive it, ensure it matches the print, and then production order will begin. Thanks, Eric Last edited by VerusEric; 08-29-2017 at 04:53 PM. |
| The Following 5 Users Say Thank You to VerusEric For This Useful Post: | Brzerker (05-19-2016), Drakiv (05-18-2016), Hawk77FT (05-18-2016), Hyper4mance2k (06-03-2016), TRAKRAVN (05-18-2016) |
#35 | |
Project Shadow
so awesome!
#36 |
Final price on these?
#37 |
Working on that
We had another person send us a picture of a broken pivot point, right at the threads where it goes into the transmission case. Anyone else had this issue? Logically it does not make sense with how it broke as this point should see mostly compression and no bending load but before writing it off as a fluke, wanted to ask... Thanks, Eric |
#38 | |
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I don't know if this is a common problem on 86es or not. However, this used to be a fairly common issue on older Nissans, and an upgraded Nismo clutch fork pivot used to be offered. |
| The Following User Says Thank You to FrX For This Useful Post: | VerusEric (05-23-2016) |
#39 | |
Project Shadow
Here is the HKS reinforced one as an example as well: http://www.enjukuracing.com/products...-vg30-z32.html
#40 |
Long Distance Driver
Interested as well.
#41 |
Ned flanders
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Can verify that i had quite a few SR20's where the stupid pivot ball was an issue. IF we are upgrading to a new fork..might as well do both..
797Performance.com
#42 |
We'll start looking into doing the pivot as well, should be a relatively inexpensive piece in quantity. The forks will be coming out first though of course.
Units are nearing the finish line! Thanks, Eric |
| The Following 2 Users Say Thank You to VerusEric For This Useful Post: | Drakiv (06-03-2016), Hyper4mance2k (06-03-2016) |
| Verus Engineering Brake Cooling Kit | VerusEric | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 100 | 07-15-2023 10:18 PM |
| Modular Hood Louver Kit - Verus Engineering | VerusEric | Cosmetic Modification (Interior/Exterior/Lighting) | 276 | 07-08-2023 04:03 PM |
| Verus Engineering Rear Wing Development | VerusEric | Tracking / Autocross / HPDE / Drifting | 203 | 07-05-2021 09:15 AM |
| Verus Engineering Billet Transmission Beta Tester Run | VerusEric | Engine, Exhaust, Transmission | 62 | 04-26-2020 01:44 PM |
| ▀▄▀▄ Vivid Racing | Cusco 86/BRZ Clutch Release Fork and Pivot Set | vividracing | Transmission and Driveline | 0 | 07-12-2016 01:32 PM |
