Old 02-28-2018, 04:42 AM   #71
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
The battery and connections are just the place to start. I agree with Ultramaroon that at this point it doesn't sound like the battery, though at first to me it did. After 5 pages it sounds like the starter or solenoid is taking a dump. He cleaned the terminals and posts, he needs to get the battery tested- those are free anyway. After that he has to start shelling out some Loonies.
guybo is offline   Reply With Quote
Old 02-28-2018, 06:28 AM   #72
It's not the battery.
I don't think it is either but let's eliminate it form the list for sure.
Old 02-28-2018, 07:52 AM   #73
JERM^
JERM^'s Avatar
Drives: WRB BRZ Aozora 15'
I can pretty much eliminate the battery from the list because when this first acted up, I really needed the car to run and was in a really rushed situation, I bought a new battery after having the car boosted by a coworker on my drive home 7 months ago and it is on the car now. For the hell of it I will still get it tested out but I think I need to start going down the line now.
So next would be the starter solenoid I guess?
JERM^ is offline   Reply With Quote
Old 02-28-2018, 10:42 AM   #74
Grady
Grady's Avatar
Get a VOM and carry it with you. Find your conections for the starter, Battery, solenoid, starter, ect. When you have the issue check to see where you lose voltage.
The Following 2 Users Say Thank You to Grady For This Useful Post:
Tcoat (02-28-2018), Ultramaroon (02-28-2018)
Old 02-28-2018, 11:52 AM   #75
The connection to the starter is the next step.
Old 02-28-2018, 01:26 PM   #76
Use a multimeter and, while a friend pushes the start button, look for 12 volts at the solenoid connector. If you have a trigger voltage, then it's the starter. If not, then look further upstream.
Be super careful to avoid shorting anything to ground.
Tcoat (02-28-2018)
Old 02-28-2018, 01:47 PM   #77
Grady
Grady's Avatar
What a great idea!!! Wish I would have thought of that
Old 02-28-2018, 04:33 PM   #78
Well you didn't say to have a friend push the starter button!
Old 02-28-2018, 06:29 PM   #79
I felt appreciated
...for about five seconds.
Tcoat (02-28-2018)
Old 02-28-2018, 07:56 PM   #80
I felt appreciated
Well it lasting longer now then!
Ultramaroon (03-01-2018)
Old 02-28-2018, 08:21 PM   #81
Hey, no fair ....... nobody said anything about having a friend help ......
Old 02-28-2018, 10:09 PM   #82
Grady
Grady's Avatar
That is ok, just buy longer leads and place the VOM on the hood where you can see it from inside when you push the start button.
humfrz (02-28-2018), Ultramaroon (03-01-2018)
Old 03-01-2018, 02:52 PM   #83
JERM^
JERM^'s Avatar
So I don't have longer leads, I don't know where the starter connections are, and I have no friend.
GG I'm screwed.
Old 03-01-2018, 03:02 PM   #84
GG I'm screwed.
The starter connections are on the starter. Lower passenger side of the car at the bell housing. Don't need a meter to check the connections but certainly will to check the voltage reaching it.
Drive down to London and will be your friend and help check it out. I do have long leads for my meter.
Yes Ultra I actually still have a meter.
No Hum it is solid state not a tube set.
humfrz (03-03-2018), Ultramaroon (03-01-2018)
ECUTek Cable, Engine Mounts, Raceseng Crank Pulley, Intake Tube, Light Battery Kit jonesy Engine, Exhaust, Bolt-Ons 1 08-25-2017 10:46 AM
Crank No start (Not battery issue) NEED HELP cnxmist Issues | Warranty | Recalls / TSB 19 07-28-2017 05:44 AM
Engine Won't Crank - Battery or Worse - Sanity Check StrangeLove4791 Issues | Warranty | Recalls / TSB 16 02-22-2017 11:18 PM
KW V3: 16 clicks for compression? h3opama Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-02-2015 08:01 PM
FS Phantom Supercharger PC680 starter battery, new display-2050 alex345 Engine, Exhaust, Bolt-Ons 20 04-12-2015 01:00 PM
