Old 02-24-2018, 01:03 PM   #3683
HeadTurner80
Drives: 2013 JRSC FRS
Would 16x8 +12 or -12 fit on stock height? I have searched and looked through the wheel fitment guide... trying to run a wide ish drag radial setup. contacted tire rack and wheelfire, neither really gave a straight answer. Any input would be awesome. Thanks
HeadTurner80 is offline   Reply With Quote
Old 02-26-2018, 02:37 PM   #3684
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I'd say no and NO.
Post 94 shows a 16x8 +25. So, a 16x8 +12 will poke out another 13mm!! The 16x8 -12 wheel will poke out an additional 37mm past the 16x8+25
http://www.ft86club.com/forums/showt...t=30465&page=7
I LIKE TIRES!
Old 02-27-2018, 04:45 PM   #3685
HeadTurner80
I'd say no and NO.
Thanks a lot. Ive never had to worry about offset. Totally new to me. I appreciate it though.
Old 02-27-2018, 08:24 PM   #3686
Daedex
That One Guy
Daedex's Avatar
Drives: White 2017 BRZ
2017 BRZ w/ Performance Package
Can't find a definitive answer, so i'd like to ask here:
2017 BRZ w/ PP / Brembo brakes.
Looking to put the Enkei RS05RR 18x8.5 42mm offset. They also have a 18x8.5 50mm offset.
Would either of those work?
Edit: confirmed, they do not fit with brembos. I do not know what kind of spacer one would need for them.
"I am not bound to win, but I am bound to be true."
Daedex is offline   Reply With Quote
Old 02-28-2018, 12:42 PM   #3687
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Good question.
This thread has information...
http://www.ft86club.com/forums/showthread.php?t=122138
Good luck!
I LIKE TIRES!
Daedex (02-28-2018)
Old 03-02-2018, 04:31 PM   #3688
Daedex
That One Guy
Daedex's Avatar
Good question.
Good luck!
actually, question: The PP wheels are a +48 offset.
Since the enkeis are 42mm, does that mean a 6mm spacer would allow them to fit?
#DidIGetThatRight?
Old 03-02-2018, 04:41 PM   #3689
Tristor
Tristor's Avatar
#DidIGetThatRight?
Wheel spacers reduce positive offset by pushing the wheel farther away from the suspension. So a +42mm offset with a 6mm spacer would be equivalent to a +36mm offset. The wheels that come with the car are:
7Jx17ET48, 7.5Jx17ET45, or 7.5Jx18ET45. The PP wheels in 2018 are the 7.5Jx17ET45 wheels (or rather a +45mm offset).
Tristor is offline   Reply With Quote
The Following 2 Users Say Thank You to Tristor For This Useful Post:
Daedex (03-02-2018), Leonardo (03-02-2018)
Old 03-02-2018, 04:43 PM   #3690
swarb
#DidIGetThatRight?
better chance to fit yes, guaranteed no, the spoke shape matters.
The Following 3 Users Say Thank You to swarb For This Useful Post:
churchx (03-02-2018), Daedex (03-02-2018), Leonardo (03-02-2018)
Old 03-02-2018, 10:15 PM   #3691
Leonardo
Country Boy 4 Life
Leonardo's Avatar
via Imgflip Meme Generator
yeah... No memes in the tech section.... lol.
I LIKE TIRES!
Old 03-03-2018, 12:10 PM   #3692
ragnarokfps
Drives: 2016 BRZ Series.HyperBlue
Hey everyone, I'm wondering what's the maximum tire/wheel size we can safely install on our otherwise stock car? Thanks. Trying to gather information before I buy
ragnarokfps is offline   Reply With Quote
Old 03-03-2018, 07:29 PM   #3693
Leonardo
Country Boy 4 Life
Leonardo's Avatar
17x8 +35
225/45/17
Will safely fit.
I LIKE TIRES!
Old 03-03-2018, 08:41 PM   #3694
carlovestela
Drives: 2015 Firestorm FRS
17x8+35
Or 17x8+44
Lowered with trd springs.
17x8 +35
225/45/17
Will safely fit.
carlovestela is offline   Reply With Quote
Old 03-03-2018, 10:48 PM   #3695
swarb
Originally Posted by carlovestela View Post
17x8+35
Or 17x8+44
+35
The Following User Says Thank You to swarb For This Useful Post:
Leonardo (03-04-2018)
Old 03-04-2018, 01:36 PM   #3696
Rohint75
Drives: 2014 Brz limited SWP
18x9.5 +40 255/35/18
Someone local is selling enkei nt03 18x9.5 +40 with 255/35/18 tires. Will these fit stock suspension with spacers?
Rohint75 is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
