View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 07-09-2012, 08:02 PM   #211
excited86
Drives: none
Originally Posted by cobrabyte View Post
I put in some top-end lubricating additive at my last fill-up. I made sure to fuel up when the crickets were singing. I was curious if this would have any effect on the crickets and, if so, how long would it take.
30 seconds. It took 30 seconds for whatever was making a racket to get the lubricant for which it was screaming.
I suspect any brand of top-end cleaner / conditioner will work.
There is still a sound of the DI pump but it's back to how it was when I first picked up the car. A sound similar to a diesel engine.
which one did you use? post a picture?
excited86 is offline   Reply With Quote
Old 07-09-2012, 08:04 PM   #212
erom
Drives: Scion FR-S Raven
I'm hearing this noise for sure and it is embarrassing.
erom is offline   Reply With Quote
Old 07-09-2012, 08:11 PM   #213
fistpoint
Drives: Supercharged Golf Cart
Ya really, he can't just come in here with a possible fix and leave the most important part out...the name of the product!
Cobra: exactly what did you use?
fistpoint is offline   Reply With Quote
Old 07-09-2012, 08:21 PM   #214
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
I will track down the brand name guys. It was something like Resitol or something like that. Damn it, I knew I should have written it down. Give me a few...
cobrabyte is offline   Reply With Quote
Old 07-09-2012, 08:23 PM   #215
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by Chewie4299 View Post
Can anyone with the requisite engine experience chime in on what effects using a very small amount of 2-Cycle oil in the gas tank can have on a modern car engine/fuel system?
If it could be considered harmless then I'll try using some at 500:1 to see test whether or not this lubrication of a washer explanation is accurate.
Sent from my Galaxy Nexus using Tapatalk 2
Just google it but it has to be the ultimate fuel additive for lubrication.
Plenty of people have been doing it for years, in diesels and gasoline engines for its benefits.
Why would you use some upper cylinder additive instead?
I use Valvoline Racing 2 stroke oil.
Try it when the tank's low, wash it in with some fuel. That way you can fill up and dilute it if you are still in a quandry.
sierra is offline   Reply With Quote
Old 07-09-2012, 08:29 PM   #216
sierra
Thank you for actually doing something to prove the point!
Simple problem, simple temporary fix until they use a teflon coated washer or something in the pump.
http://www.underhoodservice.com/issu...ontentid=65858
Old 07-09-2012, 08:33 PM   #217
cobrabyte
cobrabyte's Avatar
Whew. I thought I was going to have a bonehead moment!
Rislone Injector Cleaner
To be clear, I mixed 50ml of 2T oil (Lucas brand) in with the Rislone in the bottle. After reading the rest of the posts here, it seems that the 2T oil is probably what fixed the issue. I didn't feel like just pouring oil into the gas tank without first mixing it with something.
If it comes back (and it probably will), I will try each individually.
Old 07-09-2012, 08:42 PM   #218
cobrabyte
cobrabyte's Avatar
I am going to order some Lucas Oil Upper Cylinder Lubricant/Cleaner, as well. Guess it's worth seeing what works best with the least amount of effort.
Old 07-09-2012, 08:55 PM   #219
roddy
roddy's Avatar
Drives: '13 Ultramarine
Apparently crickets don't like ethanol
This could all be in my head, but I don't think so...
I have been using Ultra 94, which according to Petro Canada/Sunoco, can contain up to 10% ethanol. Yesterday coming back through town after a 100 mile drive, the cricket noise was quite loud. I could hear it while driving slowly through downtown (echoing off the buildings and parked cars...It's embarrassing). I managed to run the tank down to just less than 1/4.
This morning on my way to work, I topped up with Shell V-Power 91 (no ethanol). When I got to work (a few miles through town), the crickets didn't seem as angry. I thought it must just be my imagination. After work, I drove around town for a while, looking for some German Castrol (found it at wally world). I got the car good and warm and can honestly say the cricket noise is almost gone. The clatter of DI is still there, but the "squeak" is MUCH improved.
This could be wishful thinking on my part, but I think I may be on to something. For those with the cricket noise, are you using gas blended with ethanol? If so, try finding some premium that specifically says "no ethanol" on the pump. It may prove to be worth a try.
As a sidenote, I spoke to a diesel mechanic today who has been at it for a long time. He suggested trying some LUCAS upper cylinder lubricant, adding that it is good pump lube, and he has seen it make a difference in pump/injector noise where people use low sulphur diesels when it is not required. I picked up a 5oz bottle today and will keep it in the car to try if the noise comes back. I will post up if anything changes, or if I fill with the 94 again and put the additive in as well.
The Following User Says Thank You to roddy For This Useful Post:
Bonburner (07-22-2012)
Old 07-09-2012, 08:58 PM   #220
Gen
Drives: Scion FR-S
Originally Posted by Shagaliscious View Post
I noticed it for the first time today when I parked my car...had the windows down sitting in my driver seat and I could hear it. I am a little over 500 miles.
Yours must be fairly quiet. I can hear mine sitting in traffic on the freeway, windows up, AC on, with the radio on.
Gen is offline   Reply With Quote
Old 07-09-2012, 09:00 PM   #221
Shagaliscious
Drives: Firestorm FR-S (MT)
Hopefully it stays quiet!
*crosses fingers*
Old 07-09-2012, 09:04 PM   #222
cobrabyte
cobrabyte's Avatar
Mine was this annoying prior to the additives. I'd have to blare the radio to get it out of my head. I don't like driving with my radio on.
Old 07-09-2012, 09:15 PM   #223
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
I know people keep pointing out that Toyobaru have acknowledged the sound and stated that it poses no threat to the mechanical well being of the vehicle. You guys can stop doing so.
Those of us that are concerned about this, at least myself, are no longer worried our engines are going to explode and simply want the horrible chirping coming from the engine bay of our BRAND NEW CARS to stop because many are OCD about sounds in their cars, others think it's embarrassing to pull up to a light in a car that many people notice and like to look at only to have their faces change to a befuddled look when they realize the car is making cricket sounds, and many more of us are worried about both.
I think I'm going to go downstairs and mix a little 2 stroke oil with some gas and pour it into my tank.
Chewie4299 is offline   Reply With Quote
Old 07-09-2012, 09:20 PM   #224
Buggy51
Drives: Put Put
If a washer is not lubricated properly, that wouldn't cause a problem down the line (what's the time frame? 1 year?)? I'm a little skeptical of that train of thought and the idea of adding additives to gasoline seems downright annoying, an additional expense, and shouldn't even be needed in the first place.
Buggy51 is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
