Old 02-28-2018, 12:06 AM   #1
frscory
frscory's Avatar
Drives: 2013 scion frs firestorm red
Engine code p0171 and p0441
So i have a greddy turbo kit and got the e-tuning from shiv. He is a great guy and did an awesome job no complaint there but recently i have been getting engine code p0441 and p0171. Idling, p0171 is the only one that comes up but when cruising between 2k-3.5k i get both p0441 and p0171 together. My AFR seems fine when it does pop. I checked the pcv lines under the intake and all is good. I have a grimm speed manual boost control solenoid and a mishimoto catch can. I dont know if its that causing the leak or what. Any input would help! Thanks!
frscory is offline   Reply With Quote
Old 03-01-2018, 03:01 PM   #2
steve99
Drives: FT86
P0171 lean code.
possible exhaust leak near or before 02 sensor, cracked header
P0441 evap purge issue.
check evap purge solenoid if you have repurposed or removed evap purge solenoid you would need to disable that code, if not evap purge solenoid possible faulty or vacuum/boost leak leak
Tcoat (03-01-2018)
Old 03-01-2018, 03:20 PM   #3
frscory
frscory's Avatar
Thanks
P0171 lean code.
Thanks! Ill check it out when i can get a lift for the car. I have been smelling some exhaust at stops so that makes sense. I appreciate the help! I will have p0441 deleted because the manual boost control solenoid plugs in to where the evap solenoid would be plugged into.
Old 03-01-2018, 10:04 PM   #4
steve99
Drives: FT86
Oh a lot of turbo guys have had blow off valve issues where it doesnt shut off correctly check it carefully
Old 02-19-2022, 09:11 PM   #5
Jynx
Drives: 2013 Subaru BRZ
did you ever figure out what the issue was?
Jynx is offline   Reply With Quote
Old 02-20-2022, 06:40 PM   #6
Dude sold his car and left here 3 years ago so I highly doubt you will get an answer.
Old 02-20-2022, 07:06 PM   #7
Jynx
ah what the heck.
Check engine code P0441 Gibson Engine, Exhaust, Transmission 0 11-23-2016 06:39 PM
HELP:CEL and p0171 code ZHoward Engine, Exhaust, Transmission 7 07-02-2015 10:47 PM
Takeda aFe intake cause CEL? Code: P0171. Figo Engine, Exhaust, Transmission 4 11-20-2014 02:45 PM
came home with code p0171 any suggestions fluffy-reindeer-slayer Engine, Exhaust, Transmission 9 08-23-2014 03:40 PM
Error code P0171 P0170 and P171b came up Astroboy Forced Induction 27 04-26-2014 05:29 PM
