Old 04-12-2017, 11:49 PM   #15
DAEMANO
Time Traveller
Originally Posted by slyphen View Post
what do you mean by popped out? how do you fix it?
Scotty Kilmer shows you here.
[ame="https://www.youtube.com/watch?v=bH98nX8fb6M"]Replacing A Broken CV Axle On Your Car - YouTube[/ame]
Old 04-13-2017, 02:56 AM   #16
Originally Posted by DAEMANO View Post
Lowered on dealer installed springs would still be under warranty. Or OP could swap back his OEM suspension (that'd be his call). It is up for interpretation, but in my book it's better to be safe than very sorry. Surely someone telling him to not have the leak checked out is being a tad reckless with someone else's car & money.
For cryen out loud, @DAEMANO ....... it's just barely a smudge of oil on the axle. It's not like its dripping and all the oil is going to gush out of the differential .....
@slyphen, I suggest you just keep an eye on it and if it gets worse, have the seal replaced.
If you do it yourself (see the video) there is a chance that you will mess up and make things worse.
If you take it to a dealer, there is a good chance they will give you a bunch of grief about your car being lowered.
Keep in mind that this advice is coming from ol humfrz ....... who back in the day bought his daughter a junk 1978 Toyota Celica to drive. I made her park in the gravel beside the driveway because it had a bad oil leak at the front of the engine. Did I fix it .. ?? Noooo, ...... it was easier and cheaper just to put a quart of cheap oil in it every week.
Old 04-13-2017, 06:43 AM   #17
DAEMANO
Time Traveller
I had a similar looking thing. A couple of days later the seal failed (coincidentally, the night before taking it into the shop to get it looked at by a pro.) It ended up costing me a ring and pinion, seals plus labor. Care to lookup the cost of that? No need, it was $1450.00.
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
humfrz (04-13-2017), Surok (02-07-2018)
Old 04-13-2017, 11:29 AM   #18
e1_griego
e1_griego's Avatar
Drives: Many
I picked up a diff on craiglist for $500 with a spare pair of axles included :shrug:
e1_griego is offline   Reply With Quote
Old 04-13-2017, 02:39 PM   #19
DAEMANO
Time Traveller
New parts vs. used parts I assume.
Old 02-27-2018, 09:24 PM   #20
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
HA! the damn thing finally failed. left me stranded 90 miles south of tacoma in bumblefuck nowhere. Wasn't even driving hard at the time, just cruising at 45mph and bam, no power to the rear wheel.
slyphen is offline   Reply With Quote
The Following User Says Thank You to slyphen For This Useful Post:
DAEMANO (02-28-2018)
Old 02-27-2018, 10:49 PM   #21
HA! the damn thing finally failed. left me stranded 90 miles south of tacoma in bumblefuck nowhere. Wasn't even driving hard at the time, just cruising at 45mph and bam, no power to the rear wheel.......
Well, that's a shame.
Bumblefuck, WA ...... oh ya, down around Yacolt ......
You're lucky you got a tow truck to go out there to pick up your car ....... them folks down there are inbred and they don't much like strangers.
Well, lesson learned ....... don't pay no nevermind to some old coot on a car forum .......
I hope you get it fixed up soon.
Old 02-28-2018, 02:25 AM   #22
DAEMANO
Time Traveller
...pics of a hosed CV axle
Boy does that look familiar. Sorry it went... but, knew it would. I'm sure your diff/ring & pinion are a-ok if it wasn't an incredibly violent snap. Get a used axle, and make sure your car isn't lowered more than an inch.
Old 02-28-2018, 02:48 AM   #23
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
I have DSS axles that popped out because the snap ring allowed it to move while driving. I bought new seals, serviced the diff, adjusted the snap ring and put it all back together. It held up well but is starting to do it again...I am going to have to look into raising the diff. Raising the diff will most likely help your situation.
thatfilipinoguy is offline   Reply With Quote
The Following User Says Thank You to thatfilipinoguy For This Useful Post:
Surok (03-01-2018)
Old 03-01-2018, 12:41 AM   #24
slyphen
Drives: Man
All fixed. my race buddy was willing to drive 1.5hrs with a trailer to pick me up. It was a sunday so most shops were closed. my buddy Jason Merritt owns a shop (In-Tune Automotive) in Tacoma and he let us drop the car off there. found a part out on cragislist with 17k miles, bought both axles for $200 and replaced both. Now i have a spare(might not be in best shape) axle, just in case next time it happens at a race.
The Following 2 Users Say Thank You to slyphen For This Useful Post:
DAEMANO (03-01-2018), humfrz (03-01-2018)
Old 03-01-2018, 12:43 AM   #25
slyphen
Drives: Man
my car was lower than i was comfortable with in the rear for about a year, i've since raised it by about 1/2", now the suspension geometry is much better, but i think the damage was down when i was too low.
DAEMANO (03-01-2018), thatfilipinoguy (03-01-2018)
Old 03-01-2018, 01:24 AM   #26
thatfilipinoguy
I only have the eibach pro-kit, and that is enough for the axle to keep popping out. =[
Old 03-01-2018, 03:58 AM   #27
FirstWinter
Drives: Car
How low were you before?
FirstWinter is offline   Reply With Quote
Old 03-01-2018, 04:25 AM   #28
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
Take photos of the axle and send it to DSS. they replaced mine. i put a new axle in and its fine now.
Surok is offline   Reply With Quote
The Following User Says Thank You to Surok For This Useful Post:
thatfilipinoguy (03-02-2018)
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Transmission won't engage any gears.. Diff/Axle is done. Rifle Issues | Warranty | Recalls / TSB 35 03-29-2016 01:36 PM
Rear Diff axle removal xsnapshot Engine, Exhaust, Transmission 11 01-08-2016 01:28 PM
Diff whine with clutch engaged + axle seepage Laika Issues | Warranty | Recalls / TSB 33 10-11-2014 09:16 PM
Possible Leaky Taillight Fix Sco2355 Issues | Warranty | Recalls / TSB 6 02-18-2013 03:26 PM
