Old 02-11-2018, 08:24 PM   #29
D4FD
D4FD's Avatar
Drives: 2015 RS 1.0(Totaled) 2017-BRZHaSNoW
I don't know what a definition file is?
D4FD = DRIVE 4 FUN DAILY
D4FD is offline   Reply With Quote
Old 02-20-2018, 05:23 PM   #30
supercommode
supercommode's Avatar
Drives: 2017 Toyota 86 860 Special Edition
definition file is the .xml file that you have to load into Rom Raider so that it knows how to read your tuning file... might be why you are having trouble with the RR software.
supercommode is offline   Reply With Quote
Old 02-20-2018, 05:26 PM   #31
supercommode
Originally Posted by mizzta21 View Post
would u happen to have the definition file for the k00c?
I tried to share it with google drive. https://drive.google.com/file/d/1TdF...ew?usp=sharing
Let me know if you have trouble accessing it.
The Following User Says Thank You to supercommode For This Useful Post:
mizzta21 (02-20-2018)
Old 02-21-2018, 02:36 PM   #32
fields
fields's Avatar
Drives: DGM '17 PP BRZ
I'm running the Stage 2+ E85 v3.02 tune as of yesterday. My car is fully stock besides a catback. It is seeming to run pretty smoothly. Idle is a little strange; rpm will jump between 950-600rpm but besides that, it's stable. I also changed the Advanced Timing table B to make the car pop at engine load 0.15. So far so good!
fields is offline   Reply With Quote
Old 02-27-2018, 05:05 PM   #33
supercommode
You might not want to run the 2+ E85 tune as it is designed for use with a car that has headers. Having just a catback might be the reason for the strange idle. However, I'm no expert, so take my feedback with a grain of salt.
Old 02-27-2018, 05:41 PM   #34
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
You can safely run the Stage 2+ E85 tune with stock headers. I've done quite a bit of dyno testing with it as well.
Lincoln Logs is offline   Reply With Quote
Old 03-02-2018, 10:36 AM   #35
fields
fields's Avatar
Update: Idle got better over time. Sometimes I'll get a CEL (P0171) for a lean idle when I let the car idle for a bit after a cold start, but once its warm its fine. So far no complaints. Only thing is I noticed that the MPG calculator is definitely off. I go through a tank in 4 days and it shows similar MPG to what i was getting on 93.
Old 03-02-2018, 12:01 PM   #36
steve99
Drives: FT86
If you have stock intake vand your ethsanol content is between 60-90% you should not be throwing lean codes.
check your ltft and also commanded afr vs actual afr during acceleration
to correct mpg readout see here
Correcting In dash fuel economy readout when on E85
On OFT tunes the in dash fuel economy display will read 25-30% off on E85,to correct this adjust the Fuel_Multiplier_Display_Offset Table as per below (original values with 30% added) you may need to adjust this percentage slightly if you find the readout is still differs from actual
Note in your Definition the "Fuel Multiplier Display Offset" Table may be under the "BRZ ALPHA" folder
Full Blown's New Build for the 2015 Season Stage 3 (2.19L motor) + Stage 3 Turbo kit FullBlown Forced Induction 47 06-20-2018 03:38 AM
Innovate Stage 1 Supercharger with stage 2 accessories azynneo Engine, Exhaust, Bolt-Ons 3 08-30-2016 01:32 AM
Exedy Stage 1 Failure: Advice + Stage 2 Questions Pneub Engine, Exhaust, Transmission 4 07-18-2016 10:24 PM
FBM Stage 1 Cams w/ Stage 2 Head Results 743HP! FullBlown Forced Induction 119 03-24-2015 11:16 PM
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 Astroboy Forced Induction 4 03-01-2014 08:29 PM
